MOTORMAN37
WI, USA Status: offline
quote:
ORIGINAL: smarkfagan I haven't flown mine yet this season but I remember from last season the Saito 91 seems to barely hold my RV4 in the air. The plane comes in at around 12 Lb (if I remember), and I think I'm using a 13-7 prop. Near full throttle just to hold cruising speed and altitude. Wondering if there's something wrong with the engine or it isn't tuned properly.. Engines aren't my thing yet, still learning. Also I recall hearing that you can send a Saito somewhere and they'll check it out and tell you if something's wrong, etc. Any help/suggestions/etc much appreciated. Thanks Steve Steve, The only problem I see is that your Saito .91 is far under propped (over revving with to small of prop). Put a APC 14-6 on it and the performance will really improve. The APC 14-6 is the bench mark prop recommended by Horizon Hobbies "The US importer and service center" for the est overall performance. Motorman37 This is the general specs from Horizon with there basic prop recommendations of a APC 14-6 which by the way out performs all other Brand 14-6s. The APC 14-6 has been my favorite prop on .91's for years. Specs Type:4-stroke Displacement:.91 cu in (15.0 cc) Bore:1.11 in (28.20 mm) Stroke:0.94 in (24.00 mm) Cylinders:Single - Chrome Plated Engine (Only) Weight:19.6 oz Crankshaft Threads:M7 x 1mm Benchmark Prop:14 x 6 Zinger @ 9,100 Prop Range:12x8 - 15x6 RPM Range:2,000 - 11,000 Fuel:10% - 30% Synthetic Mounting Dimensions:116 x 60 x 117 mm Muffler Type:Cast Cylinder Type:AAC Carb Type:Barrel, 2 Needle Valve Crank Type:Ball Bearing
< Message edited by MOTORMAN37 -- 4/3/2008 5:42:48 PM >
