gunfighter
TX, USA Status: offline
Motorman - my bad. I meant to say 126's not the old 125's. As to the magnum, I know some love them (some people love Ford too) but I have had nothing but bad luck with them and will not buy another one. I am not a great fan of OS either if I can get a Saito. However, Due to the twin valve covers on the Saito 100 and 125, I could see that I was going to have to cut up the cowl to install either. Saito 82 probably would fit, but not sure if it had the power for this size plane. I also looked at the OS 91 2 stroke but saw there was an issue with the muffler. So I "settled" for the OS 91 Surpass 2 as the easiest to install for now. I have not given up on the BME 90 gas and may order another cowl and try it at a later date. Construction is proceding rapidly. Should have the airframe completed tonight. I am going to replace some of the hardware in the kit, specifically the control horns and aileron / flap pushrods. I just don't like the way they are installed. They look a little weak. Other than that, I am very happy with the plane so far. Lat us know when you get yours airborne and I will do the same.
