RE: 50cc Edge V2 has landed
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: 50cc Edge V2 has landed
Page: <<   < prev  13 14 [15] 16 17 18 19 20 21 22   next >   >>
Login
RE: 50cc Edge V2 has landed - 9/21/2007 3:06:45 AM
charrua
Status: offline
Ok I ended up Ordering the Canister Kit for the DA from Tom,,any tricks I should know on installing it or it's pretty easy to set it up??
(in reply to Tired Old Man)
       Post #: 351
RE: 50cc Edge V2 has landed - 9/22/2007 4:20:05 PM
charrua
Status: offline
ohh another question are you guys covering the TOP compartment when using canisters to where the Fuel Tank will sit?? Won't the Heat afect the fuel tank since th ecanister are located right below it???
(in reply to charrua)
       Post #: 352
RE: 50cc Edge V2 has landed - 9/22/2007 6:01:00 PM
rctom
Status: online
Not necessary. In fact the whole tunnel cover is pretty much not needed, but it makes people feel more comfortable. If you feel the need lay down a piece of balsa.
TF
       Post #: 353
RE: 50cc Edge V2 has landed - 9/23/2007 3:19:15 AM
charrua
Status: offline
quote:
ORIGINAL: rctom
TF
Ok then..what about cutting the Cowling... does it really need it or the holes on the bottom of the fuse where the canister is will be enough for the air to exit and cool the Engine??
Or ould I still cut some small slots on the bottom of the Cowling,,I have open the hole where the Cylinder head stick out a bit.
(in reply to rctom)
       Post #: 354
RE: 50cc Edge V2 has landed - 9/23/2007 2:53:55 PM
rctom
Status: online
The cylinder head should be exposed to clear air flow. The bottom exits in the fuse will allow plenty of air to exhaust, so no other cowl openings ae required. Basically air enters as it flows over the cylinder fins, flows down through the canister tunnel and then exits out the bottom vents.
TF
       Post #: 355
RE: 50cc Edge V2 has landed - 9/23/2007 4:05:23 PM
charrua
Status: offline
that's what I thought!!!!
tks!!!
(in reply to rctom)
       Post #: 356
RE: 50cc Edge V2 has landed - 9/23/2007 4:52:17 PM
charrua
Status: offline
ohh I just finished working on this plane,,I got the Engine mounted with 1/2'' spacers,,had painted the Firewall and canister compratment and guess what I messure the throws on the elevators....hehehehehhe and I get 68deg. up and 58 down ,,,I think that will do just fine!!!! heheheh
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 357
RE: 50cc Edge V2 has landed - 9/23/2007 5:22:01 PM
Redneck Shaun
Status: offline
Dang Charrua,
Are you sure that's going to be enough? I remember you getting mighty close to sticking it in to the top of a tree with the first WH edge.LOL.........
keep the pictures coming. Looking good........
_____________________________
Fellowship of Christian Modelers
www.fcmodelers.com
       Post #: 358
RE: 50cc Edge V2 has landed - 9/23/2007 5:24:32 PM
charrua
Status: offline
quote:
ORIGINAL: Redneck Shaun
Dang Charrua,
....well I can always rehinge and leave a bigger gap and maybe get 70deg. ,,,that should help me get out of trouble faster!!!!
(in reply to Redneck Shaun)
       Post #: 359
RE: 50cc Edge V2 has landed - 9/23/2007 5:42:40 PM
rctom
Status: online
Did you know that paint adds weight?
TF
       Post #: 360
RE: 50cc Edge V2 has landed - 9/23/2007 5:45:30 PM
charrua
Status: offline
I know but it's not much,,,I used to use thined epoxy on my old edge,,paint it sure is lighter,,,
ohh talking about light I cant believe how light this Fuse is,,I weighted after mounting the DA 50 no muffler and it weight arround 9lb,,,Fuse stabs rudder and engine,,,my old fuse with stabs over 7lb!!!!
(in reply to rctom)
       Post #: 361
RE: 50cc Edge V2 has landed - 9/23/2007 8:04:04 PM
charrua
Status: offline
What Color RED is the Red on the EDGE????? Cub yellow I got ,,blue I got what's the RED????
tks
       Post #: 362
RE: 50cc Edge V2 has landed - 9/23/2007 10:20:01 PM
Al Lewis
Status: offline
Plane is really looking great! Like you I know all of the colors but the red (checked back in my e-mails to Tom) so I can't help you there.
Take Offs are Optional, Landings are Really Nerve Racking!! Al Lewis AMA #821623
       Post #: 363
RE: 50cc Edge V2 has landed - 9/24/2007 12:02:31 AM
rctom
Status: online
True red.
TF
(in reply to Al Lewis)
       Post #: 364
RE: 50cc Edge V2 has landed - 9/24/2007 12:30:19 AM
charrua
Status: offline
Cool I just went to a a friend house and he had some red,,,and it was the right one!!!!!
sweet!!!!im sealing the hinges on top with each color to make it look more bad a$$
(in reply to rctom)
