RE: 50cc Edge V2 has landed
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: 50cc Edge V2 has landed
Page: <<   < prev  14 15 16 17 18 19 20 21 22 [23]
Login
RE: 50cc Edge V2 has landed - 2/15/2008 7:46:08 PM
OverTheEdge
Status: offline
If I remember correctly there is (at work right now otherwise I'd go look for you).... and I think it's more of a balance issue as to the placement of your rudder servo. Both my 540 and a friend of mine have our rudder servo mounted up front with the pull pull setup. He has the da50 and I have the 53toc.... neither of us had balance issues. Very nice flying plane btw.
_____________________________
Keith
Ain't gravity a *itch!
(in reply to funflyer72)
       Post #: 551
RE: 50cc Edge V2 has landed - 2/15/2008 7:53:01 PM
raven7usa
Status: offline
There are two servo locations on each side of the fuselage in the back by the stab. It's recommended to install the rudder servo last, to help you balance on the CG. My 2 elevator servo's are in the back. My rudder servo is under the hatch using a pull-pull setup. On my Edge 540 V2 with the DA 50-R, I had to put my two 6.0v receiver batteries up close to the firewall, and the ignition battery out on the engine box, to get the CG right.
< Message edited by raven7usa -- 2/15/2008 8:52:20 PM >
Run it to the redline. Dieing of natural causes is for sissies.
       Post #: 552
RE: 50cc Edge V2 has landed - 2/15/2008 9:29:56 PM
rctom
Status: offline
quote:
ORIGINAL: funflyer72
Hay all. Is their a bay for the rudder servo under the elev servo? I think Im going to run 5955 back their, on the opposite side of the stock muffler for counter ballance. Just a idea, Im still very much learning, and dont mean to ask dumb questions. Placeing my order this wednesday, edge, DA ect. Very excited.
There is a place for a rear mounted rudder servo, but that will just make the slightly tail heavy situation worse.
TF
       Post #: 553
RE: 50cc Edge V2 has landed - 2/15/2008 10:08:08 PM
Snaer810
Status: offline
Funflyer,
You may want to check the balance on the aircraft before you make the decision to put the rudder servo in the tail. You may end up having to add some weight up front to counter the effect on the CG placement.
I have the DL50 up in front and 5945 rudder servo in the fuse with pull pull and it is balancing almost perfect. I know the DA weight is a bit more, but the moment is so far back in the tail where that servo is being mounted that it may be difficult to counter act.
Good luck and lets us know how it works out.
Mike
Lets go Flyin &....Keep'em in the air!!
       Post #: 554
RE: 50cc Edge V2 has landed - 2/15/2008 11:57:37 PM
funflyer72
Status: offline
Thanks everbody, soulds like I will set up pull pull. Again thanks for the feedback
(in reply to Snaer810)
       Post #: 555
RE: 50cc Edge V2 has landed - 5/10/2008 5:54:50 PM
Captain Randy
Status: offline
I'm still flying my Edge whenever I can. It just gets better.
I did end up selling my WH YAK because I never flew it since I got the Edge.
I don't always have time to pack up my 28% and drive out to the field.
So I built a 2% that I can fly in my front yard.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
"Servo screws vibrate loose!!!"
       Post #: 556
RE: 50cc Edge V2 has landed - 5/11/2008 1:03:24 AM
rctom
Status: offline
Now that's cute!
(in reply to Captain Randy)
       Post #: 557
RE: 50cc Edge V2 has landed - 5/11/2008 3:54:45 AM
ottrod
Status: offline
quote:
ORIGINAL: Captain Randy
That's awesome!!!
I bought my first foamy recently...for the same reasons - but it looks nothing like my Edge!
       Post #: 558
RE: 50cc Edge V2 has landed - 5/11/2008 5:15:41 AM
SunShyne
Status: offline
very cool indeed, can I ask what type of gasket is that around the bottom of the cowl around the engine head? Looks very dressy
http://www.SendTextMessage.net
Revver Bro #86
       Post #: 559
RE: 50cc Edge V2 has landed - 5/11/2008 3:59:39 PM
Captain Randy
Status: offline
It is Fourmost U-trim large 1/4 inch I got from Tower Hobbies:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXG853
(in reply to SunShyne)
       Post #: 560
RE: 50cc Edge V2 has landed - 5/12/2008 1:51:58 AM
grumman-cats
Status: offline
Mine's getting close to being finished. I've got most of the trim work done and I put the base color on the turtledeck and cowling. I'll be installing a g-62 with electronic ignition from rc ignitions in arizona (did a fantastic job). I've found that if I rotate the engine just a little to the right, I won't have to cut any extra holes in the cowling to fit it, this also allows the exhaust header to flow straight back into the canister tunnel which will house my own muffler ( which is not done yet but I hope all goes well with it). My only concern is the uneven weight distibution but I'll put the rudder servo on the opposite side along with both battery packs so hopefully this will not be to much of an issue.
Jim Norton
flying: grumman F8F bearcat, X-TREME aerobat, goldberg SU26, Top flite Seafury
       Post #: 561
RE: 50cc Edge V2 has landed - 5/12/2008 1:54:44 AM
grumman-cats
Status: offline
Here's a couple of photo's of my not yet complete model.
Click for fullsize
Click for fullsize
Jim Norton
(in reply to grumman-cats)
       Post #: 562
RE: 50cc Edge V2 has landed - 5/12/2008 2:33:36 AM
ottrod
Status: offline
quote:
ORIGINAL: grumman-cats
Hey, your Edge is turning out great! Should look awesome in the air!
Keith
       Post #: 563
RE: 50cc Edge V2 has landed - 5/12/2008 3:09:29 AM
Captain Randy
