R.J. Rose Ocala FL
Joined: 6/4/2002 From: Ocala, FL, USA Status: offline
New subject, I found the rudder servo tray (pull/pull) to be a bit undersized for the JR 8611. It was just a little short in both length and width. Normally not a problem, but it is tough to enlarge with a hobby knife with the webbing in place. It took me some time, but I was able to enlarge it without breaking the webbing which is quite delicate. It was more of a scraping action than a cutting action. I didn't want to risk sticking my Dremel down there for fear of making it too large, especially on the length. Also, I chose to use the lower rudder servo trays in the aft fuse for elevator (normally used for rudder push/pull). With the servo arm end of the servo facing aft and by mounting the servo arm upward I was able to get a perfectly aligned geometry using a 2 1/2" Hgr 9 Pro Link and Dubro HD horn set with a ball link on the servo arm. A nice short and tight linkage. Might have achieved the same effect using the upper servo trays and facing the servo arm downward.
_____________________________
RRose, Cincinnati
