R.J. Rose Ocala FL
Joined: 6/4/2002 From: Ocala, FL, USA Status: offline
Do not expect a performance increase from electronic ignition, it's not gonna happen. But you will have better mid range response, easier starting and a better idle. Also you may have that G62 over-propped. It likes to rev, a 22-10 is a better choice. Per Tom's comments above, and inputs from other G62 owners, it would appear that performance is not the reason to go to electronic ignition. We used a Zinger 24 X 6 prop on the "Charity Flyer" BTE Super Flying King and the G62 churned out about 6700 RPM. This was the best Zinger prop for this large, heavy slow flyer. Probably not the best prop in the market place but it worked for us. Barry - I don't know the difference in weight between the cannister and pitts mufflers, but my V2 Edge came out at 15.6 # using three 1650 mah 4.8 packs. My guess is you will be right at 16# with the equipment you listed.
_____________________________
RRose, Cincinnati
