Litco Systems Alpha 4
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Litco Systems Alpha 4
Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
Litco Systems Alpha 4 - 2/8/2003 12:36:16 AM
sideshow
Status: online
[QUOTE]Originally posted by rsallen13
for almost $300 and that much hassle I think even the most addicted Giant Scaler could put together a more flexible system at less cost with what is readily available on the market today. [/QUOTE]
Actually you can't.
This has been discussed forever....but this is the reason they are in such high demand. Going back to the NG's (years)......lots of people have stated numerous (hundreds) of times that they were going to come up a better charger for less money....hasn't been done.
It's only two limitations are that it is not a fast charger and it doesn't do lithiums.....and I guess you could count the order process....though I have gotten through 4 times.
Bob
_____________________________
Bob Convery
(in reply to AnthonyI)
       Post #: 76
Litco Systems Alpha 4 - 2/8/2003 1:00:08 AM
rthorne
Status: offline
I didn't send an email to get on the list so I guess I'm not going to get one :-).
I sure get a kick out of all this fun to get a charger.
Rich Thorne
Amarillo, TX
ARS: N5ZC
AMA: N5ZC
       Post #: 77
Litco Systems Alpha 4 - 2/8/2003 1:33:52 AM
rsallen13
Status: offline
[QUOTE]Originally posted by sideshow
Actually you can't.
Bob
[/QUOTE]
I know I will never change the minds of the Alpha 4 faithful. I just find it hard to think that event the Alpha 4 is the end all. Though you do make a very good point for me
1) It is not a fast charger - Neither is the Ace Digipulse and it has 6 ports not 4.
2) It cycles on all four ports independently - Yes it does but is that a necessity or a convenience. A two port cycler will do the job that most of us need to do. And I honestly believe that a lot of RC'ers cycle their batters either to much or the wrong way which may actually shorten the life of the battery.
3) It doesn't do Lithiums - most Nicad chargers don't.
4) Has a host of customizable functions - that is great if you are a techie but most flyers would be better suited to plug and play.
see this thread
http://www.rcuniverse.com/forum/tm.asp?m=507505
Oh and I almost forgot. #5 with the Litco it has almost everything charges and Cycles - Yes and when it breaks down you have really nothing because you have everything in one box.
I hope I have not come across as disparaging the Litco faithful as that is not how this was intended. I had only hope to get a discussion going as to if there was another combination. This may have been beat to death in a previous posting, but I was not involved in that thread and had hope to discuss this further. I will search for the other thread.
[SIZE=1]edit - added section 5[/SIZE]]
< Message edited by rsallen13 -- Feb 7 2003 8:43PM >
       Post #: 78
Litco Systems Alpha 4 - 2/8/2003 1:35:38 AM
Baja170
Status: offline
I am told Sirius makes a 4 output charger called the Quad charger or something like that. ANybody used one?
William
       Post #: 79
Litco Systems Alpha 4 - 2/8/2003 1:43:12 AM
rthorne
Status: offline
I have the quad charger and like it a lot, but like the Litco its pricey. I picked one up last year for around $350 without the power supply.
It will handle 3 x 4000mah nicad or nimh batteries and a transmitter battery at a reduced rate ( I cannot remember the value for the transmitter output) all at the same time.
I use it all the time at the field, I like to top off my batteries before each flight (over kill but I know I have plenty of power).
I then use the Sirius Super Test every so often to cycle the batteries to be sure the batteries are in good shape.
I've been through quite a few chargers and the above setup works for me.
Rich Thorne
Amarillo, TX
ARS: N5ZC
AMA: N5ZC
       Post #: 80
Litco Systems Alpha 4 - 2/8/2003 1:50:10 AM
OldRookie
Status: online
Is the quad charger a peak detection type?
Greg
       Post #: 81
Litco Systems Alpha 4 - 2/8/2003 3:33:04 AM
sfaust
Status: offline
Hey if they cost $99.00 I'd buy one, but for almost $300 and that much hassle I think even the most addicted Giant Scaler could put together a more flexible system at less cost with what is readily available on the market today. [/QUOTE]
I don't understand your comment, 'but for $300, and that much hassle" comment. If you are referring to the extra time it might take you to order one, thats very short sighted. The solution you brought up cost more, and is much more hassle in day to day operation, which is where the majority of your time will be spent. The ordering is a one time affair, while the charging is an ongoing process. Saving 15 minutes a day in charging will offset the hassle of ordering one in about 5 days! If only the stock market or casinos would pay off that quickly!
Consider this. I have 32 batteries to maintain that are in service on my airplanes today. To cycle then with a single port cycler would take me 4 days just to cycle my airplane. With a two port cycler, it would take 2 days to cycle my airplane. With the Alpha, it won't take me any longer to cycle my airplane that it would to cycle a normal .40 or .60 sport glow airplane.
To do 32 batteries with a single port cycler, it would take, well 32 days! To cycle all my batteries 4 times a year, it would take 4 MONTHS of constant cycling and charging. With the Alpha, it would make me 25% of that time. Thats a huge advantage worth paying a little extra for. Being a family man, that time savings is worth a lot to me.
And while some may not mind tending to batteries all night to get everything up and charged, others feel quite the opposite. While I am at an event, there is lots of other things I would rather be doing. Many times my family comes with me, and we spend time together around the motor home. Some events have camp fires and we all sit around and socialize. Many times the pilots get together and go out as a group to a restaurant for dinner. I also partake in night flying frequently, by spotlight, or with on-board lights. And at big events like Joe Nall or the like, there is just way to much going on to want to sit around the motor home and play
move the plug from one battery to another. I'd rather connect everything up and forget about it with the exception of a quick peek before I retire for the night.
Plug and forget is my way of life. Its easy. Its convenient. Its nearly foolproof. And it has saved me a tremendous amount of time over the last 4 years since I bought my first Alpha. Even if I just take a conservative estimate, at 10 minutes saved a day when charging, at 48 flying days a year, for the last 4 years, we come up with 1,920 minutes, or 32 hours!
And for $40 less, the Alpha also gives you more functions, such as peak detect charging, which alone is a great time saver. No wondering if the timed charger can come off charge earlier since the battery wans't fully depleted, and should be full by now. And float and charge for we/gel cells. And its all in one box. Another convenient factor.
So, for the slight hassle of spending some extra minutes going through the order process, and having to wait a while for it to ship, I save myself 32 hours, and $40 to boot! It was finally harder for me to justify spending more money, and spending much more time tending to the charging process, just so that I wouldn't have to send an e-mail at 9am at some date in the future.
Sure, it's not intended for the masses. But if you have a need, there is a substantial time and convenience savings that is hard to over look. And thats why I don't understand your statement, "for $300, and that much hassle". Its cheaper, far less hassle in the long run, and gives me back time to do other things rather than play with wires and batteries.
Connect and forget is great! And well worth the $40 and 32 hours I saved in the process.
Stephen
http://www.StephenFaust.com/giantscalerc - My Hangar
       Post #: 82
Litco Systems Alpha 4 - 2/8/2003 4:03:09 AM
rsallen13
Status: offline
sfaust
I agree with the fact that in your situation the alpha is the way to go.
But the majority of us only charge 4 and at most 8 packs to fly on a weekend. You can only fly one plane at a time. Do you fly all eight every weekend? If you do I think that makes you the exception not the rule. And for the money you have spent and will spend in batteries the Alpha is probably perfect for you.
$40 and 5 minutes of time. Yes if your lucky enough to get one one the first try. You did, great! It was worth your time investment. If you miss then you wait 4 months or go to EBAY and pay over $300.00. 100 units each 4 month run? So how about the rest of us.
I'm not trying to pick a fight or start a flame war with the Alpha 4 owners. So let me change the tack a little.
If there was no Alpha 4 how would you handle your battery maintenance needs for under $300.00? Any suggestion?
       Post #: 83
Litco Systems Alpha 4 - 2/8/2003 5:23:19 AM
sfaust
Status: offline
[QUOTE]I agree with the fact that in your situation the alpha is the way to go.][/QUOTE]
That was all I was saying from the beginning. Its not HYPE to those that have a need, and I demonstrated my need, and the need of many of those I fly with at these events. Its not uncommon for a giant scale pilot to bring two big airplanes, and fly them both. In fact, its fairly normal.
[QUOTE]But the majority of us only charge 4 and at most 8 packs to fly on a weekend. You can only fly one plane at a time. Do you fly all eight every weekend? If you do I think that makes you the exception not the rule. And for the money you have spent and will spend in batteries the Alpha is probably perfect for you.][/QUOTE]
Yes, I fly 8 in a weekend. That's only two planes! I typically bring two giant scale airplanes to a meet, and fly them both during the day. At night, I connect up two Alpha chargers, and forget about them till morning.
And like I said, its not for the masses! But its a perfect fit for giant scale pilots.
[QUOTE]$40 and 5 minutes of time. Yes if your lucky enough to get one one the first try. You did, great! It was worth your time investment. If you miss then you wait 4 months or go to EBAY and pay over $300.00. 100 units each 4 month run? So how about the rest of us.][/QUOTE]
So, you spend 5 minutes trying to send the e-mail, and you miss the list. You try again next time its open. You spend 5 minutes. You again miss. You try again, another 5 minutes, and you make the list. You still only have 15 minutes invested in the effort. Eventually you will get on the list. Even if it takes 10 tries, and 1 hours worth of ones time, if it saves them 10 hours of a year or two, its still a Worthy investment.
I don't know if 100 in a 4 month run is accurate. Its just a number I heard, and I even said to take it with a grain of salt. It could be 4 times that, or much less. I really don't know, nor do I believe anyone else here does.
[QUOTE]I'm not trying to pick a fight or start a flame war with the Alpha 4 owners. So let me change the tack a little.][/QUOTE]
I never felt you were, but did feel you saying it was all hype, and there was easier and cheaper ways to accomplish the same tasks. I was just showing my example of what many giant scale pilots face, and showing the pitfalls with the alternative methods. Its not hype, but a real need.
[QUOTE]If there was no Alpha 4 how would you handle your battery maintenance needs for under $300.00? Any suggestion? [/QUOTE]
Unfortunately, there are trade-offs which need to be made. And it all depends on what things people feel are important. Some will say they need peak detect, while others say its not important.
For my exact needs, the Ultimate Charger II has some merit. The UCII has 8 ports, will cycle all 8 at a time, timed C/10, C/7.5, and C/5 rates. It can charge lead acid starter batteries, and can handle batteries as high as 3000mah. Its kind of like two dumb Alpha 4 units, in that there is no peak detect, and the timed charge is 16 hours. It does have some nice battery maintenance functions. This is a connect and forget setup, but the user needs to spend more time setting up the charge parameters. Since it will charge for 16 hours, and not peak detect, you need to dial down the charge rate to reflect the amount of charge you need to put back in. More up front time programming the charge parameters, but when you are done, you can forget it till morning.
This is the closest I have seen to an convenience of the Alpha if the user wants to put a little head math into the programming. I just ordered one of these, and if it works for me, I'll sell one of the Alphas, and keep the last one just for the workshop and maintenance features. The UCII would then must be a 8 port smart overnight charger. Its $50 more than you r$300 limit, but that is what I would get. I might even supplement it with a Super Nova for fast charging. The UCII and Super Nova would set me back $550, but its still less than the $600 I have invested in two Alpha 4 chargers.
I spend more money than an Alpha 4, and more work, but I do have connect and forget capabilities. So, I also save a lot of time with this solution.
Another alternative, which gets me two ports capable of fast charging to 5amps, and is basically a single port Alpha with 5amp charge is the Super Nova (or similar). Two of these would give me a half Alpha with a higher charge rate. I could charge as a faster rate to help make up the loss of the two extra ports, but I would need to move the charger around from port to port. I then have to tend the batteries. I could start the charge at night, and check it before I went to bed. If it completed, I could move it to the next two batteries. If not, i would have to do that first thing in the morning and not be able to fly until its done. I would also run these during the day to top off the batteries as best I could to minimize the charge time in the evening. Super Novas can cycle, so I get a two port cycler in the process. Less thinking since it will just peak for you, but much slower than the UCII because you only have two ports. This would set me back around $260 or so. I might also opt for the DigiPulse 6 port to pick up the slack with overnight charging. More work involved, and still more expensive than an Alpha 4.
This costs me a bit more than an Alpha 4, but less than the UCII setup. However, I have lots more stuff I have to do to get everything charged.
4 SuperNovas would be an almost ideal setup, since I could fast charge one plane, then switch to the other plane. Minimal work involved, and I could charge one in the evening, and one in the morning. Both would be ready for the next day. However, its about $480, and carrying around 4 chargers is damn inconvenient. I'd rather go with the UCII, and live with the extra time programming.
I't tried some scenarios in the past, thought about other chargers, but these two seem to have the least about of negatives for my situation. But in the end, the one time inconvenience of getting the Alpha was easier than suffering through the above drawbacks on a daily basis, month after month, year after year. And it was the cheapest solution with more features.
These are all for my needs, which I admit is not mainstream. But but by the number of Alphas I see at giant scale events, and the number of fellow pilots that want me to get them one, I'm certainly not alone, and probably fairly typical of GS pilots with multiple GS airplanes.
I'm always open to new suggestions, and would love to dump my Alphas for a good alternative. Heck, I'd probably make a handsome profit in the switch based on what they are selling for on e-Bay.
Stephen
       Post #: 84
ALPHA 4 - 2/8/2003 8:34:52 PM
SPB2POPS
Status: offline
GUYS
I hit the lottery...
Sent the Email at Exactly 09:00:15...and got a July 15th ship date, long time,huh !!
I think I am going to try the Ultimate II, since my son and I have a few bigger planes with all 1650 NiMh batteries.
Hope he still has one left..big investment, but Batteries are critical.
Does anybody have any experince with the Ultimate II ???
Steve
AMA 22299
       Post #: 85
Litco Systems Alpha 4 - 2/8/2003 8:55:14 PM
sfaust
Status: offline
He has a run of 6 more being built this week, and a couple more runs after that. He didn't seem to indicate that he was stopping production and only selling from stock.
I just called him the other day and ordered one. I'm going to try it out and see if I can use it as in conjunction with my Alpha 4. I'll put the UCII in the trailer, as well as use it at the field for overnight charging, and the Alpha in the shop for cycling, maintenance, etc. That will allow me to sell one of the two Alpha's I have, and still end up with more ports than the two Alpha's.
I'll post any comments I have on the UCII after I get some time to run some tests on it, and play around with the interface, etc.
I got a ship date of July 30 on the Alpha 4. So it seems you beat me by 15 seconds, and got in two weeks earlier on the list! I sent my e-mail at 30 seconds after.
What a farce the Litco ordering process is
Stephen
       Post #: 86
Litco Systems Alpha 4 - 2/8/2003 9:27:27 PM
SPB2POPS
Status: offline
Stephen (my spelling too)
I have been trying to Email you...give me a good address,
Ever heard of Simplex...
Anyway I just went back and read the email, I'm trying to send to
you....where you say send The ALPHA Email between
09:00:00 & 9:00:10... I wish I had read it the night before,
and you probably wish that you had remembered.
I purposely waited !!! Dumb
can't get thru to the Dr's website today...do you have a phone number...??
+++++++DONE TALKED TO THE DR, AND NOW WE BOTH HAVE UNITS COMING
Stephen
< Message edited by spb2pops -- Feb 8 2003 6:35PM >
