RE: New Pacific Aeromodel Clip Wing Monocoupe    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: New Pacific Aeromodel Clip Wing Monocoupe
Page: <<   < prev  10 11 [12] 13 14 15 16 17 18 19   next >   >>
Login
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/12/2009 4:14 PM
rcar4
Score: 125
Last Login: 5/14/2012
Status: offline
quote:
luscombe8E
Thanks, I will look forward to the pics! Since I got mine, the honey do list got very long. Is it because spring is here, or am I paying for the plane all over again :-) I am not in a hurry, want to get it right so it will become my favorite plane too.
Thanks again,
Rcar4
Hide Signatures
(in reply to luscombe8E)
       Post #: 276
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/12/2009 4:59 PM
luscombe8E
Score: 100
Last Login: 3/12/2012
Status: offline
I think its extremely easy to fly. It is completely stable at all speeds too. I have a feeling that no matter what i will always own one of these. ha
Hide Signatures
(in reply to rcar4)
       Post #: 277
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/12/2009 7:19 PM
rcar4
Score: 125
Status: offline
Do you use flapperons for landing, or is it needed?
Hide Signatures
       Post #: 278
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/12/2009 8:14 PM
rcar4
Score: 125
Status: offline
Started ironing mine out, pretty wrinkled. The ends of the black pin stripe like to curl up, do they needed glued in some way? I was a little disappointed to see the top fuselage windows are nothing but covering. Maybe a little nit picky of me, all in all I love what I see.
Hide Signatures
(in reply to rcar4)
       Post #: 279
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/12/2009 8:48 PM
jrf
Score: 105
Last Login: 5/24/2013
Status: offline
They are not "needed" for landing, but they work so well that I always used them. If they are set up according to the manual, they slow the airplane down a little, but the main thing is that they seem to lock it into the perfect 3 point attitude on approach. The pilot just needs to use the throttle to control the glide slope. They also eliminate some of the wing rocking that can happen at really slow speeds or in rough air.
Jim
< Message edited by jrf -- 4/12/2009 8:54 PM >
Hide Signatures
(in reply to rcar4)
       Post #: 280
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/12/2009 8:56 PM
luscombe8E
Score: 100
Status: offline
I made a plexiglass window for the top of my monocoupe.. It looks pretty cool i think. I didnt program mine for flapperons. Mine will just hang there on landing so i never even thought about using them. I personally dont think flapperons are needed. My coupe lands so slow if ya work it. I always slip mine on landing so if you dont like doing that then flapperons might be for you. It sure does look cool in the air. i think its worth every penny you sink in it!
Hide Signatures
(in reply to jrf)
       Post #: 281
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/12/2009 9:47 PM
GaGeeBees
Score: 313
Last Login: 5/12/2013
Status: offline
I've never felt like I needed flaperons. I do have them programmed in and will use them once in a while but it lands just as well without them. I prefer to land on the mains and let it roll out until the tail drops versus trying to three-point it. The plane will do either one very well.
_____________________________
...and then the unthinkable happened!
Hide Signatures
       Post #: 282
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/13/2009 7:29 PM
rcar4
Score: 125
Status: offline
quote:
ORIGINAL: luscombe8E
Can you share some pics of your plexi window.
Hide Signatures
       Post #: 283
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/14/2009 8:54 AM
rcar4
Score: 125
Status: offline
quote:
GaGeeBees
Thanks, I will program it in, but I think I will not be using it much either.
Ron
Hide Signatures
(in reply to rcar4)
       Post #: 284
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/17/2009 8:54 AM
rcar4
Score: 125
Status: offline
I was getting ready to trace around the rudder and trim the covering to 1/16 of the line and look what I found
[image]001.jpg[/image] OK, I don't know if the image will show. There is not enough covering on the horizontal stab and there is balsa showing all the way around the vertical stab. I am a little disappointed as I have already epoxied the horizontal stab in place. Emailed pacific areomodle and have not heard back. Oh, and no the horizontal stab is not upside down, actually I did trace around the underside and trim the covering.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to rcar4)
       Post #: 285
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/17/2009 2:17 PM
Lifer
Score: 148
Last Login: 5/23/2013
Status: offline
rcar4,
Had the same issue with mine needing covering to patch the area in front of the rudder. The guy at PAC acted as though it was the first he had heard of it. Reluctantly, he sent me some scrap covering to patch the area. Took about a month. I am not impressed with this level of customer service, particularly on a premium-priced ARF. The plane also had damage to the bottom of the fuselage that I discovered when I took it out of the box. I requested a replacement but was refused.
Nice plane, but I cannot reccomend dealing with them.
Hide Signatures
(in reply to rcar4)
       Post #: 286
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/17/2009 3:56 PM
rcar4
Score: 125
Status: offline
Lifer,
Thanks for the info, I will let you know how it works out for me. I am not going to stop the build to wait on covering. I will take the rudder to the LHS and see if they can help me match the color with something off the shelf.
Hide Signatures
(in reply to Lifer)
       Post #: 287
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/17/2009 11:54 PM
GaGeeBees
Score: 313
Status: offline
quote:
ORIGINAL: Lifer
rcar4,
Wow! That's not been my experience with Pacific Aeromodel at all. They've been very responsive and quick to help anytime I've needed anything. I've got their 82" Gee Bee Y and the Monocoupe and would highly recommend them. My dealings with them have been outstanding in every way.
Hide Signatures
(in reply to Lifer)
       Post #: 288
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/18/2009 2:55 AM
Lifer
Score: 148
Status: offline
GaGa,
I'm glad you had a good experience. In fact, that was what I was anticipating. The facts revealed themselves. I like the look of the planes the company offers, but I felt compelled to relay the story.
That's what I really like about RC Universe, it's buyer driven. Everybody can have a bad day, but what I experienced was over a month long so I came away with a lesser opinion of the company. I still like the plane!
Hide Signatures
(in reply to GaGeeBees)
       Post #: 289
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/18/2009 5:06 AM
jrf
Score: 105
Status: offline
According to the Monocoupe instruction manual, page 16 "The stab has a long bare strip on the bottom and a short bare strip on the top."
Was yours different? It not, it sure sounds like you put it on upside down.
Of course that doesn't excuse the delay in getting it taken care of. But if you spoke to the Chinese fellow, I can imagine he would have some difficulty figuring out what your problem was.
The believe the covering is Sig Aerokote.
Jim
< Message edited by jrf -- 4/18/2009 5:13 AM >
Hide Signatures
(in reply to rcar4)
       Post #: 290
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/18/2009 4:37 PM
rcar4
Score: 125
Status: offline
Jrf,
The bottom of the horizontal stab Is unmistakable, large area of uncovered area to sit on the saddle in the shape of a triangle. The top is a narrow strip to accommodate the rudder. Still no contact from Pacific Areomodel, left voice mail early yesterday A.M. and email. If I could get a part number for the covering I would just go buy a roll!
Thanks for all your guys input!
Have a GREAT weekend,
Ron
Hide Signatures
(in reply to jrf)
       Post #: 291
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/18/2009 5:39 PM
Jim T
Score: 100
Last Login: 11/12/2010
Status: offline
quote:
ORIGINAL: rcar4
Jrf,
Ron
That points out one of the things I like about Aeroworks kits..........they include a nice piece of each color of covering used. There's got to be loads of scraps they could include. These aren't cheap kits, they should be more responsive. I was going to get one of these when I get my Carden done, but am having second thoughts. Please keep us posted on how things go for you.
Jim
Hide Signatures
(in reply to rcar4)
       Post #: 292
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/18/2009 6:15 PM
rcar4
Score: 125
Status: offline
I still think the quality is very good, just a small issue. This is why customer service is so important, bad reputation can cost you customers. Everyone that has one seems to love them, I am sure I will be one too. A guy at our club told me to contact a fellow named Jim at pacific, he is going to get me his personal phone number. He said he had trouble getting a hold of the Asian fellow and now he deals strictly with Jim, that solved his issues. I am going to give him a call when I get his number, will let you know.
Hide Signatures
(in reply to Jim T)
       Post #: 293
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/25/2009 3:27 PM
rcar4
Score: 125
Status: offline
Sorry been busy and not able to give you an update. Finally got a few emails from pacific areomodel, they said they were out of the office last week and apologized. The next email I received was to tell me I installed the horizontal stab upside down. I emailed them back with my explanation in post 291, and the followed up with a picture.[image][/image]
The photo seemed to do the trick and I received this reply:
Ron,
You are right, we would send you some covering, but we do not have in stock. We will get some more, but it will take some time (about 3 days).
I will send this picture to the Mfg in China.
Thank you
Pacific Aeromodel
Johnson
I got Jim's number from my friend but have not needed to call him as things seem to be getting corrected. I would never post anyone's phone number here but if someone is having trouble and needs it you can pm me.
Click for fullsize
Hide Signatures
(in reply to rcar4)
       Post #: 294
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/29/2009 8:35 AM
rcar4
Score: 125
Status: offline
Quick update, received my covering today. Very fast responds once the problem was reported, thanks P.A.
Hide Signatures
(in reply to rcar4)
       Post #: 295
RE: New Pacific Aeromodel Clip Wing Monocoupe - 5/3/2009 4:58 AM
RHarding
Score: 140
Last Login: 12/27/2012
Status: offline
Is anyone out there using a multi cylinder engine on the Pac Aero Clip Wing Monocoupe. I'm thinking maybe the OS 300 twin. I know the gas engine would be cheaper but I'm thinking sound.
Richard
Richard
Monocoupe Brotherhood #36
Hide Signatures
(in reply to rcar4)
       Post #: 296
RE: New Pacific Aeromodel Clip Wing Monocoupe - 5/3/2009 6:31 AM
GaGeeBees
Score: 313
Status: offline
quote:
ORIGINAL: RHarding
Richard
Saito 1.70 radial. http://www.rcuvideos.com/video/Monocoupe-Radial-wmv
OS 3.00 would be a gracious plenty. The 1.60 Gemini would pull it around quite well. But, you can always throttle back
Hide Signatures
(in reply to RHarding)
       Post #: 297
RE: New Pacific Aeromodel Clip Wing Monocoupe - 5/3/2009 2:35 PM
SteveD-RCU
Score: 101
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: GaGeeBees
quote:
ORIGINAL: RHarding
Richard
Your 1.70 is running well,what fuel/prop are you using?I haven't maidened mine yet,got too busy last summer.
Steve
Click for fullsize
Steve Daly
MAAC #14007
Hide Signatures
       Post #: 298
RE: New Pacific Aeromodel Clip Wing Monocoupe - 5/3/2009 7:22 PM
GaGeeBees
Score: 313
Status: offline
quote:
ORIGINAL: SteveD-RCU
quote:
ORIGINAL: GaGeeBees
quote:
ORIGINAL: RHarding
Richard
Steve
Hey Steve,
Fuel is Omega 15% with a couple extra ounces of castor added. Prop is a Pro Zinger 16x8. Best of luck with your maiden. You'll really like how well it flies.
Hide Signatures
(in reply to SteveD-RCU)
       Post #: 299
RE: New Pacific Aeromodel Clip Wing Monocoupe - 5/4/2009 2:44 AM
RHarding
Score: 140
Status: offline
Re: 1.70 radial. Are you having any problems keeping the lower left cyl. firing?
Richard
Richard
Hide Signatures
       Post #: 300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.109RCU1
