RE: New Pacific Aeromodel Clip Wing Monocoupe    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Mikado Logo XXTREME Combo - RTF
Seller:  Hegemonoius
Details:   $2,975.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: New Pacific Aeromodel Clip Wing Monocoupe
Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Login
RE: New Pacific Aeromodel Clip Wing Monocoupe - 3/22/2008 2:06 AM
GaGeeBees
Score: 313
Last Login: 5/12/2013
Status: offline
quote:
ORIGINAL: Tisoy909
Hey guys, can i ask if any of you have the approximate diameter of the Pac Aero Monocoupe's cowl?
Thank you!
Louie
Approximately 8.5 inches. I'd have to take my cowl off to get you a more exact measurement and I just don't feel like doing it
_____________________________
...and then the unthinkable happened!
Hide Signatures
(in reply to Tisoy909)
       Post #: 176
RE: New Pacific Aeromodel Clip Wing Monocoupe - 3/23/2008 3:22 AM
YBP
Score: 100
Last Login: 9/28/2012
Status: offline
quote:
ORIGINAL: GaGeeBees
Take a second look at the Monocoupe airfoil. I'm no aeronautical engineer but it doesn't look flat bottomed to me.
Me neither! Lol.
I was sure it was for some reason.
I guess it´s semi symmetrical. The same applies, though in a slightly less degree.
Lars.
Lars.
Hide Signatures
(in reply to GaGeeBees)
       Post #: 177
RE: New Pacific Aeromodel Clip Wing Monocoupe - 3/23/2008 6:08 AM
GaGeeBees
Score: 313
Status: offline
I think you're right. Semi-symmetrical describes it better and yes, your reasoning still applies. Cheers!
Hide Signatures
(in reply to YBP)
       Post #: 178
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/9/2008 9:37 AM
GBR2
Score: 108
Last Login: 5/25/2013
Status: offline
I followed the instructions and hinged the rudder to the fin already, minus the bottom hinge. Now I'd like to glue the fin/rudder on but find that there is no way to slip the bottom hinge into the rudder and then get the part of the fin that goes into the slot on the stab without cutting away the rear portion of that tab. I haven't glued in the bottom hinge yet as I want to dry fit everything first. Now I find out that without cutting away the tab, it seems impossible to do (short of not having hinged the rudder to the fin earlier as the instructions have you do). If anyone has some super duper answer to this dilemma, I'd like to hear it.
Has any one used an SPE26 in this plane and did you still put the elevator servos in the rear?
Thought about it:
Thinking about it some, I think what I'm going to do about the lower rudder hinge is to replace it with a CA hinge. I should be able to make a slot which would allow the fin tab to key into the slot without having to cut it and still get a hinge at the bottom of the rudder.
< Message edited by GBR2 -- 4/9/2008 5:31 PM >
Hide Signatures
       Post #: 179
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/11/2008 3:58 AM
dgliderguy
Score: 115
Status: offline
GBR2,
I cut a diagonal piece off the back of the fin tab. Not a big deal.... with the bracing wires on there, the fin is not going to come loose ever. Same as you, though, I found this problem too late, and wondered why on earth I didn't just hinge the whole rudder on there after the fin was installed, like I usually do!
BTW, I'll be flying my M'coupe out at Big Birds in Monroe in another week or so. You? Oh, and I've got the SPE26 in mine, too! Elevator servos are up front, where they belong.
Don.
Glider junkies creed: No glider, no lift, no reason to live.
Hide Signatures
(in reply to GBR2)
       Post #: 180
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/21/2008 5:36 AM
mobyal
Score: 110
Last Login: 5/26/2013
Status: offline
quote:
ORIGINAL: GaGeeBees
quote:
ORIGINAL: mobyal
By the way, the EZ Balancer's expensive, but a first-class piece of work, and sure does make things easier w/ the big ones!
Al
I've been wanting one of those for a while now. Will have to make the investment. My planes keep getting bigger and bigger and the ol' Great Planes CG machine isn't up to the task anymore. I had to hang both my flight pack (5-cell sub C and onboard glow pack 4-cell sub C back where you're indicating in order to get mine to balance.
Mine also balanced perfectly aftar I moved the batteries back there.
Reported earlier on problem I was having w/ the Sullivan Glo driver. Called them and sent it back. They emailed me and said it was a bad on/off switch, sent me a new one. Great service, but that one doesn't work either. I must have a bad connection somewhere, so going to pull everything out and bench-test it.
THEN maybe if the weather'll cooperate I can get some flying in.
Al
MobyAl
Hide Signatures
       Post #: 181
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/21/2008 6:01 AM
GaGeeBees
Score: 313
Status: offline
Hey Al,
Hope you get the gremlins chased out of the onboard ignition setup. I flew mine again a couple of weeks ago and am getting closer to having the throws set up the way I want them. It's taken some experimentation. Set up per the manual did not work for me at all and I had to mix in some rudder to eliminate a pretty bad "skid" in the turns. Hope you get some flying weather soon. I'll be interested in reading your flight report. Keep us posted on your progress. Happy landings
Hide Signatures
(in reply to mobyal)
       Post #: 182
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/23/2008 9:19 AM
52jaws
Score: 106
Last Login: 5/18/2013
Status: offline
Can anyone tell me how long the root rib is from leading to trailing edge and where there CG is. Would really appreciate the help.
Thank you
Paul
Hide Signatures
       Post #: 183
RE: New Pacific Aeromodel Clip Wing Monocoupe - 4/23/2008 10:40 AM
TooLow
Score: 120
Status: offline
as per the instructions/plan the CG is 4 1/4" 4 1/2" from the leading edge of the wing at the fuse. Mine balanced right on the alum. spar/joiner and flys fine. Have logged 106 exciting flights so far!
Click to see fullsize image.
Click for fullsize
Nosen Cessna 310 Club #1 Co-founder
Clipped wing "Coupe" Brotherhood #4
Hide Signatures
(in reply to 52jaws)
       Post #: 184
RE: New Pacific Aeromodel Clip Wing Monocoupe - 5/18/2008 10:47 AM
dgliderguy
Score: 115
Status: offline
My Monocoupe had its maiden flight today! Other than the brand-new SPE26 running a bit rough (gotta find out where those air bubbles are sneaking in to the fuel lines!), it flew wonderfully. NOT a beginner's airplane, that's for sure, but lots of fun for those who have some tailwheel time and can fly a quick stick. This thing ROCKS!
As soon as I get the engine running smoothly and reliably, I will take it through its paces rolls, loops, avalanches, outside maneuvers, etc. but until then, I sure do like its responsiveness, and the smooth landings. I can tell I've got a winner here.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to TooLow)
       Post #: 185
RE: New Pacific Aeromodel Clip Wing Monocoupe - 5/19/2008 10:02 AM
dgliderguy
Score: 115
Status: offline
I discovered my fuel draw problem. The tygon fuel line managed to touch against the muffler, and when the muffler got hot, it melted a hole right through the fuel line. That explains my deadstick landing on the last flight of the day! I will re-plumb the lines, and this time I'll be sure they don't get anywhere near the muffler. Live and learn.
Click for fullsize
Hide Signatures
(in reply to dgliderguy)
       Post #: 186
RE: New Pacific Aeromodel Clip Wing Monocoupe - 9/26/2008 9:59 PM
OldFart1
Score: 120
Status: online
Hmm, this looks like a much better home for my G26 than the World Models P-47 I'm building now. I guess I'll have to find another gasser for the -47, maybe the SPE 26
Jeff/LAX
Hide Signatures
       Post #: 187
RE: New Pacific Aeromodel Clip Wing Monocoupe - 9/28/2008 1:33 AM
MormonMike
Score: 120
Last Login: 7/17/2011
Status: offline
You guys need to remember, that Saito 1.80 is a real "gas-hog". Are you sure a Saito 1.50 wont do the job just as good ? I know this thread has been inactive for a little while but I just found out about this plane a couple days ago [ believe it or not ] MM
Hide Signatures
(in reply to John_RedSox)
       Post #: 188
RE: New Pacific Aeromodel Clip Wing Monocoupe - 9/28/2008 3:20 AM
OldFart1
Score: 120
Status: online
That's why I'm going with a gasser - they sip!
Jeff/LAX
Hide Signatures
(in reply to MormonMike)
       Post #: 189
RE: New Pacific Aeromodel Clip Wing Monocoupe - 9/28/2008 3:52 AM
GaGeeBees
Score: 313
Status: offline
quote:
ORIGINAL: MormonMike
A 1.50 would fly it but I'd go with the 1.80. I fly mine with a Saito 1.70 radial and it's a good match, not overpowered at all. If I were starting over, I'd probably think long and hard about going with the Saito FG-36.
Hide Signatures
       Post #: 190
RE: New Pacific Aeromodel Clip Wing Monocoupe - 9/28/2008 6:21 PM
MormonMike
Score: 120
Status: offline
Yes, I understand. This plane is similar to the SIG WACO SRE. Pretty much the same demensions but the weight is off a couple pounds. My point is, I too have had a number of "Gassers" but the vibration is terrible. It just about shook apart my PAC Gee Bee Y so I went with the Saito 1.80. That solved the vibration but it sure is a guzzler. No problem, I'll accept that trade-off. I know, it's a matter of personal prefrence on engines for this. What a beautiful plane/ARF. Now it's just a matter of trying to get hold of somebody at PAC to buy one. Seeya around, MM
Hide Signatures
       Post #: 191
RE: New Pacific Aeromodel Clip Wing Monocoupe - 9/28/2008 6:25 PM
mobyal
Score: 110
Status: offline
You might want to consider an OS160. That's what I have in mine and it's a really good match.
MobyAl
Hide Signatures
       Post #: 192
RE: New Pacific Aeromodel Clip Wing Monocoupe - 9/28/2008 6:46 PM
sseward
Score: 100
Last Login: 10/29/2012
Status: offline
Has anyone put an OS FT-160 twin in this plane? I have one lying around (I bought it for my TF Stinson Reliant....it'll be a while before it's built!) and I love this plane. I think this would have enough power, but I wonder if it fits in the cowl without lots of cutting.
Steve
Hide Signatures
       Post #: 193
RE: New Pacific Aeromodel Clip Wing Monocoupe - 9/28/2008 6:49 PM
MormonMike
Score: 120
Status: offline
Yup, that too has caught my attention. And I just might do that. Ya know, this "Golden Age " bug has really bit me. I just took six fully operational ARF's from my hangar and put them in the surplus room to decomission and strip for parts. And there not little "Kiddy" arf's either. That still leaves me 25 fully operational planes to fly. Scott C. at SIG and his pals are kicking around the idea of making a Waco YMF, nothing solid but the idea is in there heads. I'm "sweating -out " waiting Sunday to end so I can call Monday and get my plane ordered. Gads, you'd think I was acting like a little kid again. MM
Hide Signatures
       Post #: 194
RE: New Pacific Aeromodel Clip Wing Monocoupe - 9/28/2008 6:52 PM
mobyal
Score: 110
Status: offline
I'm not sure. The cowl would probably take it OK, but the airplane's not set up for it as it comes to you. It's designed for an inverted single-cylinder engine so far as the mounts and airflow is set up. Take a look at some of the installs on the thread here.
MobyAl
Hide Signatures
(in reply to sseward)
       Post #: 195
RE: New Pacific Aeromodel Clip Wing Monocoupe - 9/28/2008 7:48 PM
jrf
Score: 105
Last Login: 5/24/2013
Status: offline
sseward: The cowl is about 8" wide but it curves in at the front a little. There is a cooling air exit all the way around the cowl at the rear and if you trim the dummy engine as a baffle (as the manual says) to direct the incoming air to the cylinders of the twin, it should cool OK.
Jim
Hide Signatures
       Post #: 196
RE: New Pacific Aeromodel Clip Wing Monocoupe - 9/28/2008 7:57 PM
GaGeeBees
Score: 313
Status: offline
Some of you may have seen this already but for those that haven't, here's the link to a short video of the Saito 1.70 radial running. It's a great fit and very clean install and flies the plane really well. It's also very low in vibration. I get a little transitioning out of idle as I give it throttle but it's not much. Can't beat the sound of a round engine.
http://www.rcuvideos.com/video/Monocoupe-Radial-wmv
Hide Signatures
(in reply to jrf)
       Post #: 197
RE: New Pacific Aeromodel Clip Wing Monocoupe - 9/28/2008 8:15 PM
sseward
Score: 100
Status: offline
Thanks for the replys! I went and measured the FT-160 and it looks like it's about 7.5 inches wide. I'm not worried about the firewall mounting of the exhaust because I already have the Keleo FT-160 pipes that I had bought for the Stinson Reliant. I'm worried that with .5inch to spare, that the cylinder heads might be close near the taper at the front of the cowl since the FT-160 has a very short shaft. That's why I was wondering if anyone had tried it....I hate being the guinea pig!
Of course, if I buy the plane and the FT-160 doesn't work out, then I could by the Saito 170 radial! After watching GaGeeBees' video...that thing sounds great!
Steve
Hide Signatures
       Post #: 198
RE: New Pacific Aeromodel Clip Wing Monocoupe - 9/29/2008 2:46 AM
GaGeeBees
Score: 313
Status: offline
Just back from another day of flying the Monocoupe. The more I fly it, the more I like . The little radial runs great and just starting it up draws a crowd. I'm still tweaking the control throws but am getting close to where I want it. I've added some expo to the ailerons and ended up mixing in a bit of rudder as the tail has a tendency to drop in the turns if I'm less than wide open throttle. A little rudder mixed in really helped eliminate the adverse yaw. I continue to be amazed at how slow this airplane will land. Whatever Pac Aero did to make it fly better they really nailed it. I have mine set up with flaperons and droop the ailerons about 30 degrees for landing. It slows down very nicely. Wonderful airplane!
Hide Signatures
       Post #: 199
RE: New Pacific Aeromodel Clip Wing Monocoupe - 9/30/2008 3:11 AM
rcten
Score: 100
Status: offline
sseward, the cowl is 9" in diameter as per the article in Model Aviation 2008.
hope this helps
Rcten
Hide Signatures
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.914RCU1
