HELP Please!!!!!!!!!!!!!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> HELP Please!!!!!!!!!!!!!!!
Page: [1] 2   next >   >>
Login
HELP Please!!!!!!!!!!!!!!! - 1/10/2007 3:30 AM
TannerReagan
Score: 100
Last Login: 8/21/2007
Status: offline
I have just recieved a Tornado BB and i thought it would be more simple than it really is . I have a problem. Whenever i start the car the wheels spin very fast and the engine will rev up by itself. The car also acts like it wants to take off without me. When in neutral the car doesn't stop it just keeps driving at high speeds.Any suggestions?? I'm a begginer so please help, thanks Tanner
_____________________________
Tanner Reagan
Hide Signatures
       Post #: 1
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 3:34 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
make sure the throttle trim is in the center position, if it is then take off the air cleaner and look blow the opening of the carb and you will see a screw with a spring on it, turn this counterclockwise to lower the idle. this should do the trick, the opening should be about 1mm.
MAKE SURE YOU PUT THE AIR CLEANER BACK ON BEFORE YOU START IT AGAIN.
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to TannerReagan)
       Post #: 2
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 4:15 AM
TannerReagan
Score: 100
Status: offline
i tried your suggestion but i can't get the engine to start. The exhaust has gas coming out when i pull the starter. I asked my dad and he said it is probably to rich. Do you know how to make it stop coming out and how to get it to start, by the way the glow plug has been charged
Tanner Reagan
Hide Signatures
(in reply to ehroof)
       Post #: 3
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 4:21 AM
ehroof
Score: 105
Status: offline
take the glow plug out, put it in the ignitor and make sure it light up bright, i didnt mean the glow plug ignitor was not good i mean the glow plug itself, they go bad alot during break in. Turn the high speed needle 1/4 turn clocwise and see if that helps. also check out the engine troubleshooting thread above this one
Hide Signatures
       Post #: 4
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 4:23 AM
nitrospeed33
Score: 100
Last Login: 2/19/2007
Status: offline
cant charge a glow plug, lol but maybe you mean the ignitor. i dont know what could cause this. i think you just need to set the throttle trim perfect. the throttle is obviously open too much in nuetral, and during break in the engine shoudl be rich, and a little fuel will come out of the exhaust, dont worry about that. hope you get it workin.
Hide Signatures
       Post #: 5
bluecaka69
Score: 100
Last Login: 8/6/2012
Status: offline
WHat ABout Clutch Spring
first post will explain everything to check it right here http://www.rcuniverse.com/forum/m_4207842/tm.htm
Bodies By Blue-Airbrushes Bring Out The Artist In All Of Us!!
All About Fun Hobbies
Hide Signatures
       Post #: 6
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 4:26 AM
ehroof
Score: 105
Status: offline
i was thinking that but he said the engine was revving.
Hide Signatures
(in reply to bluecaka69)
       Post #: 7
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 5:18 AM
TannerReagan
Score: 100
Status: offline
yeah it kinda revs by itself whenever i am just holding it in the air, and it just keeps running whithout evening idling. I don't even touch the remote and it does it by itself
Tanner Reagan
Hide Signatures
       Post #: 8
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 5:22 AM
TannerReagan
Score: 100
Status: offline
My car does not have the LSN or HSN so i cant mess with those screws because it is the 4wd 2spd. tornado bb. I just can't wait until i get it working so then i can go have a blast. When I first got it going last night, the car just took off and ramped off a curve on the side of the street, the aluminum bottom scraped the ground sparks flew everywhere and it landed in bushes. I thought it was awesome, and it didn't even scratched up or anything except for the bottom a little bit.
Tanner Reagan
Hide Signatures
       Post #: 9
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 5:25 AM
Chubbysdad
Score: 100
Last Login: 12/22/2009
Status: offline
of course it has the lsn and the hsn. That is how you tune your car. Has nothing to do with 4wd. Look through the posts. It will show pics and how to tune.
Cen truggy, Bigfoot 1/5th, Cen buggy, Mg16, Redcat Earthquake, Redcat Drifter
Hide Signatures
       Post #: 10
ehroof
Score: 105
Status: offline
your engine has to have a high and low needle. every nitro has at least on needle.
Hide Signatures
       Post #: 11
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 5:27 AM
TannerReagan
Score: 100
Status: offline
ok, thanks for telling me that because since i'm kinda new to this i just looked at the engine and didn't see the screws, and in the manual it didn't say anything about them.
Tanner Reagan
Hide Signatures
       Post #: 12
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 5:29 AM
Chubbysdad
Score: 100
Status: offline
remember only a little turn at a time and then run it. It will take a few to take full effect. Patience is the key..
Hide Signatures
       Post #: 13
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 5:34 AM
zack221
Score: 100
Last Login: 1/20/2013
Status: offline
here is a pic of the needles
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Chubbysdad)
       Post #: 14
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 5:36 AM
TannerReagan
Score: 100
Status: offline
i keep going outside and trying it over again, the engine just seems like it doesn't want to start now. I had it running earlier today after school, but i didn't drive it, i just was trying to fix the problem but now it wont start at all, and by the way how long should the glow plug or whatever charge?
Tanner Reagan
Hide Signatures
       Post #: 15
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 5:38 AM
Chubbysdad
Score: 100
Status: offline
THe intial time let it charge overnight.
You might have too much fuel in the motor now. Take out the glow plug, and pull start a few times to get the extra fuel out of the motor. Then put it back in. Try to see if the glow plug is glowing orange, before putting back in. Then you will know if your ignitor is charged.
Hide Signatures
       Post #: 16
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 5:39 AM
TannerReagan
Score: 100
Status: offline
yeah my engine has those screws, thinks for showing me the pic it helped alot. Should i turn down the low speed and see if that makes it stop taking off when i first start it.
Tanner Reagan
Hide Signatures
       Post #: 17
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 5:40 AM
TannerReagan
Score: 100
Status: offline
and do u have to use the ignitor every single time to start it, i have been.
Tanner Reagan
Hide Signatures
       Post #: 18
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 5:41 AM
zack221
Score: 100
Status: offline
here you go
lsn-ccw richens and cw leans
hsn-cw leans and ccw richens
idle-cw opens and ccw closes
Set air gap of throttle 1.5 mm,(idle screw), HSN Cw til it bottoms out then 3 1/2 turn CCW. LSN Flush with the throttle housing + 1 turn cw. Try to start, will be runnin really rich, if it starts. Turn down idle speed, then adjust HSN cw til you have good acceleration to idle. if your idle speed rises, turn it down. May have to do a couple times. Last adjustment LSN, turn cw slowly til idle speed starts to rise. when it rises you're running lean, turn it CCW till idle speed just drops. Blip the throttle you should be acceleration ok with some smoke coming from the muffler.Lean the HSN 1/8 turn CW till your satisfied.
< Message edited by zack221 -- 1/10/2007 5:42 AM >
Hide Signatures
       Post #: 19
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 5:42 AM
Chubbysdad
Score: 100
Status: offline
No. That is not what the lsn is for. Take off your air filter and check your carb opening. It should be like 1 mm. You can close it a bit.
Hide Signatures
       Post #: 20
ehroof
Score: 105
Status: offline
did you do what i told you in my first post to your quesiton? and yes you have to use the ignitor everytime you start it.
Hide Signatures
       Post #: 21
zack221
Score: 100
Status: offline
yea you have to use the ignitor ever time or it wont start
Hide Signatures
(in reply to zack221)
       Post #: 22
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 5:43 AM
Chubbysdad
Score: 100
Status: offline
Yes you have to use it. If you dont, the plug wont glow and the car wont fire.
Hide Signatures
       Post #: 23
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 5:45 AM
TannerReagan
Score: 100
Status: offline
yes, the throttle trim on my controller has a factory setting place on it and that is what i have had it on whenever i messed with it, it made it just go faster and stuff so i set it back
Tanner Reagan
Hide Signatures
       Post #: 24
RE: HELP Please!!!!!!!!!!!!!!! - 1/10/2007 5:46 AM
ehroof
Score: 105
Status: offline
did you turn the idle screw counter clocwise after you put the throttle trim to the center?
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.863RCU1
