RE: Cen Matrix Tr Arena    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> RE: Cen Matrix Tr Arena Page: <<   < prev  25 26 [27] 28 29 30 31 32 33 34   next >   >>
Login
RE: Cen Matrix Tr Arena - 3/11/2008 4:45 AM
chrobar
Score: 100
Last Login: 4/16/2012
Status: offline
Hey TR arena, I did not dremel anything..When I had the stock knuckles, I dremeled a bit, but with the new CNCs, I didn't dremel anything. The C hubs are still completely stock.
_____________________________
*Team Terribles* CEN Matrix C-1 FRE, Sportwerks V2 .21, JP3 pipe, Futaba FASST...Soon to be R2 FRE
Hide Signatures
(in reply to trarena)
       Post #: 651
RE: Cen Matrix Tr Arena - 3/12/2008 9:06 PM
Rebeldude
Score: 100
Last Login: 5/13/2013
Status: offline
quote:
ORIGINAL: chrobar
Ok, well you can take A LOT of approaches to it. The most beneficial would be to go to 17mm. But since you already got 23mm wheels, don't worry about it until you wear out the tires.
1) Try and contact the people I told you about, that will probably be the smartest thing to do.
2) Do some kind of mods yourself like grinding down the 23mm hubs so that the hole the pin goes through is closer to the edge..(this way you can shim the hubs similarly like the 17mm ones and get the same result)
3) You can drill new holes in the arm that are a little closer to the diff, thus pushing the CVD farther into the diff, which is your goal ultimately.
4) You can probably think of a new idea to mod things, too. One thing that I was kind of curious about was if you can get longer CVDs. You can look around on the net and check out specs.
5) An idea I just remembered would be to limit the uptravel on the shocks. It's sooooo easy, just put a small length of fuel tubing on the shock shaft..because you know the reason the CVD is falling out is because the arm moves so far up that it pulls the CVD out. This is definitely the easiest and cheapest fix...do it.
Tom
One more fix that CEN told me I could do was change the lower shock rod end to the Genesis GS232. This will do the same as #5 above and limit up travel. I have to make a decision soon because I am getting them off the shelf now that the weather is getting nice. I just ordered 2 of the sportwerks back plates so I can go full time starter box. I have also e-mailed those guys you suggested about the new lower arms.
Just heard back from CEN, man that was quick, here was what they told me in relation to the new lower arms:
quote:
It’s the same part number; we just changed the mold and made it shorter
< Message edited by Rebeldude -- 3/12/2008 9:11 PM >
2 Matrix TR Arena, 2 Brushless FT RC10T3
Hide Signatures
(in reply to chrobar)
       Post #: 652
RE: Cen Matrix Tr Arena - 3/12/2008 10:48 PM
*FULL-REVS*
Score: 100
Last Login: 1/8/2010
Status: offline
thanks for sorting that rebeldude.... i wonder when they changed the mould? will see if my surplier has the new ones... i imagine id be able to tell by measurement weather or not they are the new ones....
Life is all about ass,Your either coverin it,Kissin it,bustin it,kickin it,tryin to get a piece of it,or just behavin like 1
Hide Signatures
(in reply to Rebeldude)
       Post #: 653
RE: Cen Matrix Tr Arena - 3/13/2008 1:02 AM
Rebeldude
Score: 100
Status: offline
Yeah, I wonder how much shorter they are? Won't this mess with the handling since the stance will be more narrow? Just a thought. I guess the cost to change the mold on the dogbone was greater, that would seem like the right thing to do. Has anyone ever tried to find a dogbone that is just a bit longer or change to a CVD style setup?
Hide Signatures
(in reply to *FULL-REVS*)
       Post #: 654
RE: Cen Matrix Tr Arena - 3/13/2008 12:43 PM
trarena
Score: 100
Last Login: 6/12/2009
Status: offline
quote:
[Yeah, I wonder how much shorter they are? Won't this mess with the handling since the stance will be more narrow? Just a thought. I guess the cost to change the mold on the dogbone was greater, that would seem like the right thing to do. Has anyone ever tried to find a dogbone that is just a bit longer or change to a CVD style setup?]
Rebeldude
The change is only a few mm so doesn't affect the handling much at all. Before I got the new arms though I changed the outdrives to the hardened stainless steel Savage ones which are just a little longer and that stopped the dogbone from being able to 'pop' without having to make any other adjustments to the shocks or shock ends. Worked a treat even before I changed to the 17mm hex matrix buggy setup.
< Message edited by trarena -- 3/13/2008 12:55 PM >
C2X PRO BCE Arena, Ninja CEO B01A & MRT GRP .21, 2053 FLR pipe, Hitec 5955TG & ACE 1313, DX3R, Proline LPR, Rulux rims
Hide Signatures
       Post #: 655
RE: Cen Matrix Tr Arena - 3/15/2008 2:03 AM
Andrew Smolnik
Score: 100
Last Login: 8/17/2010
Status: offline
As TRarena stated the arms are 2mm shorter which actually have proven to help the trucks handling in a positive way. Shorter arms have proven to provide more traction in the truck.
Andrew Smolnik<br>CEN Racing / VP Pro USA<br>Genka Trading Corp.<br>Team Manager<br>R & D Dept.<b
Hide Signatures
       Post #: 656
RE: Cen Matrix Tr Arena - 3/16/2008 6:48 PM
pooldoc
Score: 100
Last Login: 4/27/2010
Status: offline
Can we get a part# for the new shorter arms, Thanks Pooldoc
Hide Signatures
(in reply to Andrew Smolnik)
       Post #: 657
RE: Cen Matrix Tr Arena - 3/17/2008 12:00 AM
*FULL-REVS*
Score: 100
Status: offline
picked up my new arms yesterday.... and they are definantly shorter.... i measured it at 3mm shorter though... i had the part number but put the packaging in the bin sorry...going to put them on and give it a run... will let ya's know how it goes
Hide Signatures
(in reply to pooldoc)
       Post #: 658
RE: Cen Matrix Tr Arena - 3/17/2008 8:29 AM
trarena
Score: 100
Status: offline
I think you will find it was a running change so the part number is the same (MX307).
Hide Signatures
       Post #: 659
RE: Cen Matrix Tr Arena - 3/17/2008 11:50 AM
*FULL-REVS*
Score: 100
Status: offline
and they work a bloody treat i REALLY tried to get it to drop a shaft today.... and they are definantly in there!!!!
Hide Signatures
       Post #: 660
RE: Cen Matrix Tr Arena - 3/18/2008 4:25 AM
chrobar
Score: 100
Status: offline
Do you see any better steering full revs? I think I'll get me a set to check it out too..the front of the truck is actually a little wider stock, so the new arms would be great.
Hide Signatures
       Post #: 661
RE: Cen Matrix Tr Arena - 3/18/2008 10:11 AM
*FULL-REVS*
Score: 100
Status: offline
i couldnt tell you if its "better" as such as i havent put it on the huddy yet so camber and toe etc was set by eye... but i also noticed the front was quite a bit wider than the rear and have heard of people running a 1/2" off set on the rear only... the new arms definantly pull those front wheels in which in theory should make it turn in faster being a shorter wheel base width, will put it on the huddy this weekend and give it a run.... and report back here
Hide Signatures
       Post #: 662
RE: Cen Matrix Tr Arena - 3/18/2008 5:19 PM
Rebeldude
Score: 100
Status: offline
Does anyone know what the total length of the new arm is? I asked Amain if they had the new arms and they responded with this: "I check our stock, and there is no ID saying if they are shorter a-arms. The ones that we have measure from center pin to center pin is 143mm " If no one knows for sure I will have to wait until I can measure mine. Just thought someone would know already. I have to order mine and amain is 2 dollars cheaper per pair and I need 2 pair.
Hide Signatures
       Post #: 663
RE: Cen Matrix Tr Arena - 3/19/2008 3:03 AM
trarena
Score: 100
Status: offline
If they have measured them accurately from centre pin to centre pin then I think you will find that they are the new shorter arms. Might pay to send an email or pm to Andy to make sure.
Hide Signatures
       Post #: 664
RE: Cen Matrix Tr Arena - 3/21/2008 3:41 AM
wriffwraff
Score: 100
Last Login: 11/12/2012
Status: offline
a mild vid of me running my cen matrix truggy http://www.youtube.com/watch?v=qY71yKOkGRA i say mild because the new engine has just under a gallon on it, so it ain't all that, you know? anyways, it's footage and that's always good. so, another half gallon or so on the new engine and it should wake up. i've been foolin' around with the gearing to get an education. in this latest vid, i'm running a 12T bell, so the top end is short. i just wanted to try a 12T, for torque, during the first gallon or so on the new engine. i also tried a 14T and it hauls with that gearing down the stretch. having tried a few, looks like cen got it right with the stock 13T gearing, in terms of torque and top end balance. so with that experience, a new 13T is in the mail, along with the kyosho center drive-train conversion... good times ahead
also, just yesterday, it appears that cen posted a new video... if it's the new truggy, i wonder what's new http://www.youtube.com/watch?v=9gRsZaACv_4
edit: os pictured, but i'm actually running a .21 axe rossi. i decided to defer the os for now.
< Message edited by wriffwraff -- 3/22/2008 4:32 AM >
Cen Matrix TR Arena | BCE Edition
Hide Signatures
       Post #: 665
RE: Cen Matrix Tr Arena - 3/21/2008 5:42 AM
wriffwraff
Score: 100
Status: offline
one other thing... i've been researching the " ofna big bore " shocks online today and they spec at 16 mm's. the stock cen shocks spec at 16.5 mm. so, it appears that the stock cen shocks are .5 mm's bigger, yet some are " upgrading " to the ofna 16 mm big bores? please weigh in if you know something about the ofna big bores. i mean, what am i missing? i should add that i really like them because they are threaded.
Hide Signatures
(in reply to wriffwraff)
       Post #: 666
RE: Cen Matrix Tr Arena - 3/21/2008 6:43 AM
chrobar
Score: 100
Status: offline
I think that CEN measures the shocks on the outside of the shock bodies, while Jammin measures them in the inside. There's no way that the CEN shocks are bigger than the Jammin ones.
Hide Signatures
       Post #: 667
RE: Cen Matrix Tr Arena - 3/22/2008 11:11 PM
ewing61
Score: 100
Last Login: 9/1/2008
Status: offline
do yall run your arenas without the ride height spacers? I took mine off (12mm rear, 6mm front) and it seems to make the ride height way too low, less than 1 inch ground clearance. I run 60wt oil all around with green springs. Just wondering because it seems like alot of yall run without preload spacers, so I wanted to know if any other mods are necessary.
I just upgraded the center and rear diffs to cross pin style, and am running the lsd with 80wt gear oil in the front diff. This thing really handles like its on rails now. not very many people run the matrix where I'm from, so this forum is a life saver.
Cen Matrix TR Arena
Futaba FASST 3PM
Hide Signatures
       Post #: 668
RE: Cen Matrix Tr Arena - 3/22/2008 11:53 PM
trarena
Score: 100
Status: offline
Hi ewing, i assume you mean the preload spacers on the shocks? I run without them when i am using my red mugen springs with 450F and 400R oil and shocks set to upper most position on shock tower and middle position on lower arm. When I run the CEN blue springs (softer) i run 500F and 450R and i drop the shock position on the towers down one position. Still middle position on lower arm. I will sometimes use a team vtx 2mm preload spacer on rear with this setup. I don't use the CEN green springs.
Hide Signatures
(in reply to ewing61)
       Post #: 669
RE: Cen Matrix Tr Arena - 3/24/2008 7:24 AM
spartan8892
Score: 100
Last Login: 7/8/2008
Status: offline
hey guys what is a good tuned pipe i could use on the matrix tr??
Hide Signatures
       Post #: 670
RE: Cen Matrix Tr Arena - 3/24/2008 7:06 PM
ewing61
Score: 100
Status: offline
well my stock cast knuckles have officially stripped out. pretty annoying. Looking forward to not dropping screws all the time after I get the cnc ones. on another note, does anyone run 1/2 offset wheels? I started running some 1/2 offset prolines and the truck is almost as wide as it is long.
Cen Matrix TR Arena
Futaba FASST 3PM
Hide Signatures
(in reply to spartan8892)
       Post #: 671
RE: Cen Matrix Tr Arena - 3/24/2008 10:55 PM
ewing61
Score: 100
Status: offline
Well here's my truck
Mostly rtr with futaba 3pm 2.4, jr 9100t, airtronics 94758z, roto-start...
Cen Matrix TR Arena
Futaba FASST 3PM
Hide Signatures
       Post #: 672
RE: Cen Matrix Tr Arena - 3/24/2008 10:58 PM
chrobar
Score: 100
Status: offline
I run 1/2 offset losi rims. It doesn't seem too wide, there are truggies at the track that are wider. The time you would want your truck to be shorter and narrower is if your track is small and technical. With a bigger track, wide is fine, but hey, my track is a 120 X 65 ft indoor and 1/2s are fine.
Hide Signatures
       Post #: 673
RE: Cen Matrix Tr Arena - 3/25/2008 1:37 PM
trarena
Score: 100
Status: offline
quote:
ORIGINAL: ewing61
CNC hubs and carriers are a must IMO. I have converted to 17mm hex and can only runs 1/2's if i don't run extended hubs (can only be 450mm wide where i race).
Hide Signatures
       Post #: 674
RE: Cen Matrix Tr Arena - 3/25/2008 4:37 PM
nomobux
Score: 105
Last Login: 5/26/2013
Status: offline
Did a search with no luck. Anyone got a link or info on a air filter set up for the SH28 If I turn the stocker to get to the Hi speed, it hits the brakes and visa versa. Something up and angled a bit. No lhs anywhere near me. TIA
< Message edited by nomobux -- 3/25/2008 6:13 PM >
" I GOTTS NOMOBUX "
Hide Signatures
       Post #: 675
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.094RCU1
