chrobar
IL, USA Status: offline
With the small gear conversion, the engine is moved closer to the center to account for the small gear. If you use the buggy radio tray, the throttle servo can be lowered about a centimeter or more. There is also less rotating mass because you are using less metal in the drive train. Also by using the angle braces on the chassis, a little more flex can be achieved to improve the handling of the truck. When running the small gear you will also need the hot bodies ring and pinion gears for the diffs. These are spiral cut and can make the drive train smoother. Along with all of that, the over all weight of the truck is less. So the small gear conversion, in essence, makes the truck faster around the track.
_____________________________
CEN Matrix TR Arena, Futaba fasst, small gear
