RE: Cen Matrix Tr Arena
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Traxxas 1/16 E-Revo VXL - RTR
Seller:  kdogg0331
Details:   $400.00   |  3/14/2010   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> RE: Cen Matrix Tr Arena
Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: Cen Matrix Tr Arena - 1/31/2007 5:06 AM
Mystikal8885
Score: 100
Last Login: 2/26/2010
Status: offline
I took apart my engine today and it looks good, the piston and sleeve is so tight that the piston pushes the sleeve out of the crank case when it reaches TDC.
Make sure you wash out your pipe, you wont want any dirt that may be in there to get into your new engine.
I bought the Starter box, is there a backplate that replaces the pull start assembly?
What's up DahlELama, haven't heard from you in a while. What new tricks have you been up to?
< Message edited by Mystikal8885 -- 1/31/2007 6:25 AM >
_____________________________
Atlanta Model Boaters
IMPBA District 13
Hide Signatures
(in reply to Shark413)
       Post #: 126
RE: Cen Matrix Tr Arena - 2/1/2007 5:37 AM
Shark413
Score: 100
Last Login: 3/5/2010
Status: offline
Look what arrived in the mail today, a brand new OS 30VG w/RS. I hooked it up (after I took it apart and cleaned it) and while I was at it I also installed the CEN alloy racing clutch shoes (red) and 1.1 springs. Some notes on the engine install. 1) I was able to use the stock CEN motor mounts but they hit the Roto Start flange and I had to mill a 1mm groove in the mount. 2) the stock mount sat a little too low and the Roto Start hit the chassis, I was going to mill a small slot in the chassis but I was in a hurry so I used a few washers to get a little more clearence. 3) Clutch Bell sticks out about 1mm more than the stock motor, very close to the spur but no contact. 4) I had to rotate the carb, spin the fuel intake around and adjust the carb ball mount to clear the chassis brace.
New engine
Mounted in the car and ready to go.
Kyosho ST-RR Brushless / Losi 8ight 2.0 Brushless / Jammin CRT.5 Brushless / Associated SC10
Hide Signatures
(in reply to Mystikal8885)
       Post #: 127
RE: Cen Matrix Tr Arena - 2/1/2007 5:45 PM
s5lin
Score: 106
Last Login: 12/28/2007
Status: offline
Shark, that OS 30 VG is a monster. I have one thats an EB Mod OS 30 in a 1/7th scale buggy. The thing still accelerates like a raped ape. Even with gearing thats taller than stock. I think you'll be very happy with that motor.
Oh yah, if youre shopping for clutch shoes, the blue CEN clutch shoes would be better for a truggy than the red ones. The blue ones are heavier (slightly) and meant for truggies. Part number is GSS16.
Rip up the tracks with that Arena TR!!!!
< Message edited by s5lin -- 2/1/2007 5:49 PM >
Hide Signatures
       Post #: 128
RE: Cen Matrix Tr Arena - 2/1/2007 6:15 PM
Shark413
Score: 100
Status: offline
s5lin, thanks for the info I will check out the blue clutch shoes. Since the "reds" are lighter, maybe I will use the 1.0mm springs. Can't wait to fire up this motor. It came down to the Picco .28 and the OS 30vg, I got a good deal on the OS plus I like the roto start feature (backup to my starter box). Also I have a OS 18TM in my Revo and it runs great and is very easy to tune.
Hide Signatures
(in reply to s5lin)
       Post #: 129
RE: Cen Matrix Tr Arena - 2/1/2007 10:40 PM
annie_himself
Score: 100
Last Login: 3/9/2010
Status: offline
The tank looks to be in normal config. Just like on my Matrix.
Saldly, 98% of teens have switched to rap music, if you're part of the other 2% that like real hip-hop put this in your sig.
Hide Signatures
       Post #: 130
RE: Cen Matrix Tr Arena - 2/2/2007 12:15 AM
s5lin
Score: 106
Status: offline
When he flipped the fuel intake, he's talking about the little brass fuel intake on the carb. Not on the tank. Annie_himself, I think you thought he said the tank's fuel intake was flipped around.
Yah for most 1/8 cars and trucks, the engine always comes with the fuel nipple the wrong way for me. Always gotta flip that sucker around. I got a Radical 628 in my truggy and that engine hauls serious A!!!!! Set that engine up with a novarossi longer header/ mugen msr1005 pipe. Had to use a 15T clutch bell to tame the sucker down in terms of torque. But I like that Picco .28 as well. Got one in another truggy that was built before I got the CEN. Puts out good power, but I think the Radical is stronger everywhere in the powerband.
Actually now that I think of it, quite a few Matrix TRs I've seen around here have the Radical (OPS made). For an upcoming magazine review, I know one of the editors got the radical for this TR, another buddy got one, I got one. Not to mention Andy Smolnik is also running one.
Oh yah if you want a Radical Engine give Headrush Hobbies a call if ur looking for a Radical Engine. Got a decent price from him on the Radical Engines. As you can tell I kinda got more motors than I do cars. hahaha.
Hide Signatures
(in reply to annie_himself)
       Post #: 131
RE: Cen Matrix Tr Arena - 2/2/2007 8:52 AM
Shark413
Score: 100
Status: offline
Ok another update for those thinking of changing out the engine. Like I said in my earlier post, there were a couple of issues 1) with the stock motor mounts in the stock position the bell is very close to the spur 2) the motor has to sit higher to clear the roto/pull start housing. I added spacers to raise the motor so it fits but I found out now the flywheel is too high and my starter box wheel won't reach it. I originally was going to mill a slot in the chassis for clearence but got lazy and just used spacers to raise the motor. After the flywheel/starter box problem I decided to do it right. I milled out a "T" shaped slot in the chassis about 1.5 mm deep. This gave the motor clearence so I didn't have to use the spacers, now the motor sits at the stock height and the flywheel now reaches the starter box wheel. I also discovered those CEN guys were pretty smart. At first I thought the stock motor mounts were symmetrical, but I discovered that if you flip them around they move the motor back about 1.5mm, which lined up my clutch bell and spur perfectly. Now the new motor sits in the chassis just like the old stock motor.
< Message edited by Shark413 -- 2/2/2007 8:53 AM >
Hide Signatures
(in reply to s5lin)
       Post #: 132
RE: Cen Matrix Tr Arena - 2/3/2007 12:40 AM
s5lin
Score: 106
Status: offline
Hey Shark. The motor mounts are like for a good reason. I don't know if you knew or not, but some engines have a slightly different crankcase mount position. Such as Picco and Novarossis are the two standards.
The Picco spacing and the Novarossi are actually different. If you notice some aftermarket part manufacturers actually use two different spacing plates. One meant for piccos and one meant for Novas. I am not sure which mount pattern OS used.
But, once again, go RIP with that Arena TR and the OS 30!!!!!!!
Hide Signatures
       Post #: 133
RE: Cen Matrix Tr Arena - 2/3/2007 2:21 PM
supertib
Score: 161
Last Login: 3/16/2010
Status: online
quote:
ORIGINAL: s5lin
I am curious about the Radical.... stronger then a Picco 28 wow thats impressive.... is it smooth or is it a beast, and what kind of run times you getting ?
seeing is believing !
Hide Signatures
(in reply to s5lin)
       Post #: 134
RE: Cen Matrix Tr Arena - 2/5/2007 5:43 PM
Shark413
Score: 100
Status: offline
s5lin, I ran the OS 30vg this weekend and you are right, insane power. Had some issues with it running rich which I could not figure out (rich but running temps of 240-250). This was hurting the accelleration big time. Sent you a PM with more info.
Hide Signatures
(in reply to s5lin)
       Post #: 135
RE: Cen Matrix Tr Arena - 2/6/2007 12:40 AM
RGX Blade
Score: 100
Last Login: 1/28/2009
Status: offline
needle settings are way off.......
sounds like your low speed is Lean and high speed is rich...
it happens .....
do this it will run funny but this is only to get you back in the "BallPark" settings....
bottom out your high speed needle "SLOWLY" to where it just stops do not keep going ...
now back out to the recommeded setting for the high speed needle....if your not sure most manufactures will have it out 3 to 3 1/2 turns out....or Flush with the needle body...
now back out the low speed needle out a few turns...
it's going to run funny, but were gonna get it tuned for ya...
ok, now set the "Idle Screw" a little high so the ventrui is open more...
we'll reset this later.....
if you have a box this will help Majorly!!!
now start the car you'll have to keep on the throttle cause may stall.....
and keep te Igniter on as well.......(just for now)
now i'll "Assume" you have already run some tanks through it????
and plug is good and Clutch is in good shape or new??
so, while it's on the box and do not set the low speed yet.........
keep hitting the gas and "Slowly" lean out the high speed needle......
the it will want to bog while your hitting the gas so do not worry about that yet....
if it is not bogging when you hit the gas richen up the low speed for now.....
remember it's going to be a Bear to keep at idle so do not worry on this as yet as well....
when you have the high speed close you'll know as when it hits the end of it's power band
it will have a crazy high pitch....every motor is a little different but you'll know...
as it will want to wind out!!! now do not stay on the throttle no load on the motor too long could snap the crank...
now back it out about "3 clicks" or 3 hours as they say....if not sure think of the high speed needle as the hours on a clock...12 is at the top 6 is at the bottom 3 O'Clock is at th right and 9 O'clock is to the left....now "Where ever the Needle is sitting pick that point and back out 3 hours....
now best thing from here is to go to the track where you may be running...
if this is not practical
we'll move on....
now once the high speed is "Close" we'll set the low end needle
start the car again.....get it up to a warm temp but not over 220 etc........
but at least warm etc....run for about a minute or so....
now, turn in the low speed in about an hour and goose the throttle let it settle if it dies no problem were trying to get to the good setting....
now keep turning in a little at a time to where it wont die you'll also notice it will want to idle much higher...back out the idle scew a little so the motor is not reving out.....
if not idleing higher no worries it's just still rich ........
now during this time can be running up and down street etc....
this will be much better to do this.....
and keep checking the temp....run up and down in a long straight "Listen"
to see how it sounds...should be nice and "Crisp" at "Speed"
if it is running pretty fast and the temp is low then leave it alone 200 to 240 is fine....
now set the rest of low end settings....
bring car in peg the throttle a few times not too long!!!
if the car idles high then drops in a few seconds...
turn in the low speed in a click...
set it back down run it in the street for a a few seconds.....
bring back in rev it up a few seconds....
listen to the Idle....if it idles high then drops turn in the low speed another click....
if during this time you did not need to do any settings, then lower the Idle screw just to the point where the Clutch doesn't engage the bell.....
then you can also check the low speed by pinching the fuel line as well...
if when you pinch close to the inlet....if it speeds up right away and wants to die...low speed is too lean... if you pinch it and runs more than 5 seconds it's a little rich.....
but make sure you have set the High speed needle "First".....
the high speed needle "Dictates" the overall total amount of fuel comming into the car....
if still having some problems can also write us at Razorgrafix23@hotmail.com
hope this can help......
Oakley | RGX Racing /KM Machining | GRP / ACE Engineering
Hide Signatures
       Post #: 136
RE: Cen Matrix Tr Arena - 2/6/2007 4:00 AM
Shark413
Score: 100
Status: offline
Blade, thanks for the info. I will definetly reset and perform the steps you mentioned.
Hide Signatures
(in reply to RGX Blade)
       Post #: 137
RE: Cen Matrix Tr Arena - 2/7/2007 9:52 AM
RGX Blade
Score: 100
Status: offline
well i only hope it can get ya rolling....
sometimes can be Frustrating..let us all know if it works for ya....
Hide Signatures
       Post #: 138
RE: Cen Matrix Tr Arena - 2/8/2007 5:01 AM
HeadRush ROB.21
Score: 100
Last Login: 2/23/2007
Status: offline
blade are you going to best of west finals this weekend????
by the way its Robert lol
ROBERT H. CEN racing
SPONSORED BY: HeadRush Hobbies
Hide Signatures
       Post #: 139
RE: Cen Matrix Tr Arena - 2/9/2007 10:00 AM
RGX Blade
Score: 100
Status: offline
Only if your Gonna Be there......
i'll bring the bellcrank just in case if ya did not get one just yet....
painting a Show car for a Magazine with it's Matching Chopper....i'll see how far i am
been working day and night on this...
if i am pretty far along yea....we'll head n out...
Hide Signatures
(in reply to HeadRush ROB.21)
       Post #: 140
RE: Cen Matrix Tr Arena - 2/9/2007 2:54 PM
HeadRush ROB.21
Score: 100
Status: offline
well then ill see you there sir cause you no im going RAIN or SHINE loll
hahahha
yea well hope you get pretty far on and show up.........its the finals man you have to show up lol
yea well hope to see you there
Hide Signatures
       Post #: 141
RE: Cen Matrix Tr Arena - 2/9/2007 9:03 PM
Mystikal8885
Score: 100
Status: offline
Sooo, the Arena really pissed me off today. I got Gene Hickerson's diff kit and decided to install it today. Used a heat gun, pliers for a firm grip and a hex and the damn screws wont go loose for nothing. Now i'm stuck using an EZ out to get the screws out. I'm in the process of removing them. I'll let u guys know how that went. The truck is awesome so far, dont let me misleading you, I love it... it's those screws that are a pain in the butt.
IMPBA District 13
Hide Signatures
       Post #: 142
RE: Cen Matrix Tr Arena - 2/10/2007 12:37 AM
RGX Blade
Score: 100
Status: offline
yea, i'll try and go...i placed pretty high in the "A's last couple"
man last one i broke!! i was bummed...LOL...
was a Hub pin!?!?!?! how the heck do those ever break??? havent broken one of those since the 2000 worlds in Vegas!!!
but that was with the GX-5 RGX truggy...finally got the new RGX diffs in the the O'l TR
i'll see how it rides....hehehehehe....
was pretty strapped with the Kyosho's but these are made for it....
hey ya Rob gotta send ya some of these....
Hide Signatures
       Post #: 143
RE: Cen Matrix Tr Arena - 2/10/2007 12:39 AM
RGX Blade
Score: 100
Status: offline
Hide Signatures
       Post #: 144
RE: Cen Matrix Tr Arena - 2/10/2007 5:22 AM
HeadRush ROB.21
Score: 100
Status: offline
blade why would you send me a pen....lololol
what is it i cant tell from here lol
Hide Signatures
       Post #: 145
RE: Cen Matrix Tr Arena - 2/12/2007 1:14 AM
RGX Blade
Score: 100
Status: offline
no Silly.....
shock piston.......it is a "Dual Layered" 2 stage piston some of us are checking out..
it's kinda hard to see???
i'll try and send better pics.....
Hide Signatures
       Post #: 146
RE: Cen Matrix Tr Arena - 2/12/2007 5:18 AM
HeadRush ROB.21
Score: 100
Status: offline
just bring it to revs on sat. and ill check it out
Hide Signatures
       Post #: 147
RE: Cen Matrix Tr Arena - 2/12/2007 6:12 AM
MBX5T Maniac
Score: 100
Last Login: 11/13/2009
Status: offline
RGX, you gotta make some of those for the MBX5T
My toys: LST, Mini Inferno, XX-CR, GrassHopper, RC10, Rustler, MBX5T Prospec, Mugen MST-1
Hide Signatures
       Post #: 148
RE: Cen Matrix Tr Arena - 2/12/2007 11:03 AM
RGX Blade
Score: 100
Status: offline
i think they will fit???
but never really thought about it??? good tip thanks...
if they do maybe i'll toss over a set?
i'll let everyone know in a day or 2
Hide Signatures
(in reply to MBX5T Maniac)
       Post #: 149
RE: Cen Matrix Tr Arena - 2/13/2007 3:46 AM
dooks88
Score: 100
Last Login: 3/17/2008
Status: offline
Just wanted to share some photos of my Martix TR RTR. I love this truggy and am looking forward learning how to make it even better. Let me know what you think.
< Message edited by dooks88 -- 2/13/2007 5:51 AM >
Hide Signatures
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.113RCU1
