Installation procedure for AFPD model downloads
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> Installation procedure for AFPD model downloads
Page: [1] 2 3   next >   >>
Login
Installation procedure for AFPD model downloads - 1/10/2007 12:55 PM
rajul
Score: 100
Last Login: 11/21/2009
Status: offline
Here's a 5-step guide on how to install downloaded AFPD aircraft models from the various free websites. This is a drag-and-drop method which I find is easier and faster, compared to unzipping.
When you have completed the download of an aircraft model, you will see a zip file on your desktop. An example is shown below.
Click to see fullsize image.
Click for fullsize
< Message edited by rajul -- 1/10/2007 1:46 PM >
_____________________________
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
Hide Signatures
       Post #: 1
RE: Installation procedure for AFPD model aircraft - 1/10/2007 12:57 PM
rajul
Score: 100
Status: offline
Double click on the zip file to open it. You will either see a single folder.......
Click for fullsize
< Message edited by rajul -- 1/14/2007 1:55 AM >
Mike Marks
RCU Moderator
Hide Signatures
(in reply to rajul)
       Post #: 2
RE: Installation procedure for AFPD model aircraft - 1/10/2007 12:59 PM
rajul
Score: 100
Status: offline
.......or you will see a set of files. Leave the zip file open on your desktop.
Click for fullsize
Mike Marks
RCU Moderator
Hide Signatures
(in reply to rajul)
       Post #: 3
RE: Installation procedure for AFPD model aircraft - 1/10/2007 1:00 PM
rajul
Score: 100
Status: offline
Now double click on My Computer->Local Disk (C)->Program Files->IPACS->Aerofly Professional Deluxe->Aircraft
Click for fullsize
< Message edited by rajul -- 1/10/2007 1:43 PM >
Mike Marks
RCU Moderator
Hide Signatures
(in reply to rajul)
       Post #: 4
RE: Installation procedure for AFPD model aircraft - 1/10/2007 1:12 PM
rajul
Score: 100
Status: offline
If your zip file has a single folder, use your mouse to drag and drop (or copy and paste) that folder into the "Aircraft" folder.
Click for fullsize
Mike Marks
RCU Moderator
Hide Signatures
(in reply to rajul)
       Post #: 5
RE: Installation procedure for AFPD model aircraft - 1/10/2007 1:15 PM
rajul
Score: 100
Status: offline
If your zip file has a set of files, you will have to create a new folder inside the "Aircraft" folder and give it the same name as the zip file. For example, if the zip file is "rExtreme.zip", then the new folder name should be "rExtreme". Then use your mouse to drag and drop (or copy and paste) all the zip files into the new folder
Click for fullsize
Click for fullsize
< Message edited by rajul -- 1/18/2007 1:41 AM >
Mike Marks
RCU Moderator
Hide Signatures
(in reply to rajul)
       Post #: 6
RE: Installation procedure for AFPD model aircraft - 1/10/2007 1:25 PM
rajul
Score: 100
Status: offline
Double click on the new model folder to check if there are any .wav sound files in it. Select all the .wav files with the mouse, right click on the selection, and cut. Click the back button in Windows, right click on the "Sound" folder, and paste all the .wav files into it.
Close all open windows and you're all set! You should be able to load and fly the new aircraft model in AFPD.
Click for fullsize
Click for fullsize
Mike Marks
RCU Moderator
Hide Signatures
(in reply to rajul)
       Post #: 7
RE: Installation procedure for AFPD model aircraft - 4/8/2007 4:54 PM
rajul
Score: 100
Status: offline
Addendum: Some of the newer model downloads may come as an executable file. That actually makes life a whole lot easier. All you have to do is the double click on the zip file to extract it, then double click on the .exe file to install the model. The installation will be done automatically.
Click for fullsize
Click for fullsize
Click for fullsize
Mike Marks
RCU Moderator
Hide Signatures
(in reply to rajul)
       Post #: 8
RE: Installation procedure for AFPD model aircraft - 6/16/2007 11:54 AM
E.Gerry
Score: 100
Last Login: 11/18/2009
Status: offline
rajul,
Your installation procedure is very clear and I have followed it exactly (using both a single folder and separate files) but the model ( acromaster_jw) does not appear on the list of AFPD aircraft.
Within the "aircraft" folder the "acromaster_jw" folder is not sorted into its alphabetic place.
Can you help me further please?
Gerry
Hide Signatures
(in reply to rajul)
       Post #: 9
RE: Installation procedure for AFPD model aircraft - 6/16/2007 11:57 AM
rajul
Score: 100
Status: offline
Gerry, can you provide me with the download link for the acromaster_jw? Thanks
Mike Marks
RCU Moderator
Hide Signatures
(in reply to E.Gerry)
       Post #: 10
RE: Installation procedure for AFPD model downloads - 6/16/2007 12:38 PM
E.Gerry
Score: 100
Status: offline
rajul,
Thanks for the quick reply. www.rc-sim.de Go to Downloads > AFPD Planes then page 6.
Gerry
Hide Signatures
(in reply to rajul)
       Post #: 11
RE: Installation procedure for AFPD model downloads - 6/16/2007 1:08 PM
rajul
Score: 100
Status: offline
Gerry, I tested the acromaster_jw and it works fine using the outlined procedure. Do you see the acromaster_jw folder in the AFPD aircraft folder? What version of AFPD do you have 1.8.0.25 or 1.9.7.11? Did you install any addons?
Click for fullsize
Click for fullsize
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 12
RE: Installation procedure for AFPD model downloads - 6/16/2007 1:40 PM
E.Gerry
Score: 100
Status: offline
Hi again rajul,
1) the acromaster_jw folder is in the AFPD Aircraft folder. and the files are inside this folder.
2) I have AFPD 1.8.0.17
3) I don't have any addons.
Gerry
Hide Signatures
(in reply to rajul)
       Post #: 13
RE: Installation procedure for AFPD model downloads - 6/16/2007 1:42 PM
rajul
Score: 100
Status: offline
The aeromaster_jw file was written for version 1.9.x.x of AFPD. Try and see if this works:
Go to the aircraft directory C:\Program Files\IPACS\AeroFly Professional Deluxe\aircraft and open the aeromaster_jw folder.
Look for the .tmd file and open it with a text editor like notepad or word
Now you need to alter this line in the .tmd file:
// aerofly professional --------------------------------------------------------
// file: xxxxxxx.tmd
// version: 1.9.0 <<<<<<<<ALTER THIS LINE TO: // version 1.8.0
// type: 20
// lock: 0
Then click save
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 14
RE: Installation procedure for AFPD model downloads - 6/16/2007 2:03 PM
E.Gerry
Score: 100
Status: offline
rajul,
You'r a star!!!
The Acromaster is up and flying!
Many thanks.
I shall keep this thread handy for future reference.
Gerry
Hide Signatures
(in reply to rajul)
       Post #: 15
RE: Installation procedure for AFPD model downloads - 6/16/2007 2:06 PM
rajul
Score: 100
Status: offline
LOL! I would also suggest that you download and apply the 1.8.0.25 update patch. There's a link provided in one of the stickies.
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 16
RE: Installation procedure for AFPD model downloads - 6/28/2007 5:39 AM
asabache55
Score: 100
Last Login: 7/10/2008
Status: offline
talk you muy buen aporte amigo gracias!!
Panther====> 145 webra
Mistic 3d Fun fly====> 46 tundher tiger
Hide Signatures
(in reply to rajul)
       Post #: 17
RE: Installation procedure for AFPD model aircraft - 12/13/2007 5:49 PM
Phantom 1
Score: 100
Last Login: 8/8/2009
Status: offline
quote:
ORIGINAL: rajul
Am I reading this right? Shouldn't I click copy first, then cut or what? Am I to understand that file needs to be deleted in the new model folder?
Hide Signatures
(in reply to rajul)
       Post #: 18
RE: Installation procedure for AFPD model downloads - 12/13/2007 11:32 PM
rajul
Score: 100
Status: offline
Hi Phantom, not all downloads have .wav files in the model folder. If there are any, then you'll have to transfer them to the sound folder.
Mike Marks
RCU Moderator
Hide Signatures
(in reply to Phantom 1)
       Post #: 19
RE: Installation procedure for AFPD model downloads - 12/14/2007 5:16 AM
Phantom 1
Score: 100
Status: offline
I know. I just thought you meant copy, instead of cut in your instructions. Sorry.
Hide Signatures
(in reply to rajul)
       Post #: 20
RE: Installation procedure for AFPD model downloads - 12/31/2007 1:40 AM
k2bdv
Score: 100
Last Login: 6/29/2009
Status: offline
I did exzactly what u said to do and then i open aero fly and the plane is not in there, i just dont understand why.
Does it matter if i have windows vista?
Hide Signatures
       Post #: 21
RE: Installation procedure for AFPD model downloads - 12/31/2007 9:26 AM
rajul
Score: 100
Status: offline
Hi k2, there's no difference with vista. Can you post the link for the plane you downloaded? Thanks
< Message edited by rajul -- 12/31/2007 3:26 PM >
Mike Marks
RCU Moderator
Hide Signatures
(in reply to k2bdv)
       Post #: 22
RE: Installation procedure for AFPD model downloads - 6/6/2008 7:51 PM
lamreht
Score: 100
Last Login: 6/17/2008
Status: offline
Rajul,
I have version 1.11.07.09 of AFPD, running on Vista. How do I edit the TMD file so my downloaded planes and secnery will show up?
Thx in advance,
RK
Hide Signatures
(in reply to rajul)
       Post #: 23
RE: Installation procedure for AFPD model downloads - 6/7/2008 12:37 AM
rajul
Score: 100
Status: offline
RK, which models did you download and how did you install them? What is the exact problem you are facing?
Mike Marks
RCU Moderator
Hide Signatures
(in reply to lamreht)
       Post #: 24
RE: Installation procedure for AFPD model downloads - 6/7/2008 2:52 AM
lamreht
Score: 100
Status: offline
Rajul,
Thanks for getting back to me. Here is the info you asked for:
I downloaded 4 models from http://arthur.heim.at
"which models did you download?"
AS_BLUESHARK_AFPD
AS_NURI-E_AFPD
AS_PIPERJ3_AFPD
AS_S-39_W_AFPD
"how did you install them?"
I downloaded them to C\username\documents\aircraft. Once I found them I then opened the files and followed the instuctions. They unzipped and went into the aircraft folder in AFPD.
"What is the exact problem you are facing?"
I renamed them and they show up in the folder, but when I start the program they don't come up. I did read something to the affect of changing the version # in the TMD file, but have not done that til I know that's what I should really do.
Thx
RK
Hide Signatures
(in reply to rajul)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.906RCU1
