2200mAh battery how do i charge it?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Common Sense RC Support >> 2200mAh battery how do i charge it?
Page: [1]
Login
2200mAh battery how do i charge it? - 1/11/2007 6:16:35 PM
zulugogogo
Status: offline
Hi I have just got a Accu-Cycle Elite charger. I have also bout a battery Link to ebay bought battery if that link does not work then this is the ebay number 160067021941. The battery has a small white connector which I assume is for charging it. I have nothing like that with the charger, what sort of connection is it so I can find it so I can buy one for the charger or is it something else. Please help an idiot (i dont have a heil yet, still waiting so be patient with me). What do I do?
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: 2200mAh battery how do i charge it? - 1/11/2007 6:25:41 PM
Bob Laine
Status: offline
I would suggest you go to the item you bought and ask the seller the question. What are the two plugs for, and which one is used for charging. Myself.......I'd take a volt meter and see which one has the voltage, and I'd change the plugs to whatever radio I'm using. I suspect that one of the plugs will go to the receiver and the other plug is used for charging. You can probably eliminate one of the plugs if you change the other to accept the plug on the switch you intend to use if you use a switch with built in charge receptacle. Still........the best thing would be to ask the supplier. Bob Laine
< Message edited by Bob Laine -- 1/11/2007 6:27:36 PM >
_____________________________
"Georgia on my mind"
AMA 8143 "Leader Member"
(in reply to zulugogogo)
       Post #: 2
RE: 2200mAh battery how do i charge it? - 1/11/2007 6:30:13 PM
guver
Status: online
The Elite charges thru the discharge (using) plug. The 2 wire plug.
The white connector is for cell balancing.
This is an apostrophe ''
(in reply to Bob Laine)
       Post #: 3
RE: 2200mAh battery how do i charge it? - 1/11/2007 6:30:20 PM
lanny2003
Status: offline
The white connector is for using a balance charger or device to balance the cells.
The charger you have will charge it thru the deans (red) connector.
Lanny http://www.poshpottery.com/airplane.html
P-51 Mustang,3DFoamy,ME-109,SPAD Debonair, UltraFly Furious 3D,Formosa
       Post #: 4
RE: 2200mAh battery how do i charge it? - 1/11/2007 6:50:38 PM
zulugogogo
Status: offline
Excellent thanks for that. So I thought I would plug it in and just see what it does (without any battery). I bought the charger from Canada so I used my travel plug popped it in and BANG! Now I will have to get a transformer aswell!
(in reply to lanny2003)
       Post #: 5
RE: 2200mAh battery how do i charge it? - 1/11/2007 7:05:31 PM
Geistware
Status: offline
You can charge two ways.
All three cells as a 3 cell LiPo pack or any two adjacent two wires on the white connector as a single cell.
Be careful of the polarity.
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
       Post #: 6
RE: 2200mAh battery how do i charge it? - 1/11/2007 7:14:02 PM
zulugogogo
Status: offline
so going with the big reg one it the better way for someone who is unsure.
(in reply to Geistware)
       Post #: 7
RE: 2200mAh battery how do i charge it? - 1/11/2007 7:23:28 PM
lanny2003
Status: offline
Yes. That is what I use. To help make your batteries last longer you will need to get a balancer. I bought the Ultra-Balancer from Common Sense RC ( http://www.commonsenserc.com/product_info.php?cPath=38_29&products_id=184 ) and I like it. Works with all my batteries.
quote:
ORIGINAL: zulugogogo
       Post #: 8
RE: 2200mAh battery how do i charge it? - 1/11/2007 8:59:29 PM
zulugogogo
Status: offline
Ok, what is a balancer? why isnt it built in?
       Post #: 9
RE: 2200mAh battery how do i charge it? - 1/11/2007 9:04:24 PM
zulugogogo
Status: offline
I have just seen a charger/balancer for $24.00 and i paid $100 for mine AND i need a balancer! can someone explaine?
       Post #: 10
RE: 2200mAh battery how do i charge it? - 1/11/2007 9:12:26 PM
lanny2003
Status: offline
You got a very good charger for the price. You dont have to use a balancer. I have batteries I have had for months (charged 60 or 70 times) and they still work fine and never been balanced. I just now started flying helis so my battery demand has increased (4 - 2cell, 12 - 3cell lipos). That is why I got the balancer.
       Post #: 11
RE: 2200mAh battery how do i charge it? - 1/11/2007 9:25:49 PM
zulugogogo
Status: offline
Can you explain what the balancer does in simple terms.
       Post #: 12
RE: 2200mAh battery how do i charge it? - 1/11/2007 9:38:09 PM
lanny2003
Status: offline
A Lipo battery has a number of cells. Each cell has a voltage of 3.2 volts or higher. From charging and discharging the voltage in the cells can get unbalanced. A balancer will identyfy the voltage of each cell and bleed off the higher voltage until they are equal.
Basic Lipo info
http://www.commonsenserc.com/product_instructions/basic_TX_lipo_guidelines.pdf
Balancer info
http://www.commonsenserc.com/product_instructions/Ultra-balancer_instructions_final.pdf
       Post #: 13
RE: 2200mAh battery how do i charge it? - 1/11/2007 9:39:30 PM
zulugogogo
Status: offline
Thanks again for your help
       Post #: 14
RE: 2200mAh battery how do i charge it? - 1/12/2007 9:51:25 PM
Geistware
Status: offline
A balancer will charge each individual cell to ensure that each cell is fully charged.
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
