46u
GA, USA Status: offline
quote:
ORIGINAL: ben_rc Cool thread I have a Sav with an STS .28 engine, love it, but I have temperature problems.... I will go for about 4-5 minutes, doing 1/2 throttle speed runs, and come back, and sometimes the temperature is at 280-300F. Why is this? I can't be lean, as i richened the HSN by 1/8th a turn to compensate for running on grass.... Any ideas? And also, it won't wheely like some of the ones I've seen, they put no effort in at all.....mine, I have to use a kerb or something Thanks Ben * Oh - and I also still have all 3 head shims in place, and I'm running 25% O'Donnells fuel, OS#8 Glowplug Anything else you need to know? Have you sealed the engine? STS takes a standard long plug and the OS plug is a short plug. How much fuel have you run through it so far? My STS 3 port 28 in my Savage even running on grass does not get that hot. If you look at the instruction sheet they list recommend head shimming for different nitro contents. One other thing are you running O'Donnell race blend or the Ready 2 Run? The race blend is fine and the Ready 2 Run has to much oil which can cause over heating.
< Message edited by 46u -- 3/7/2008 3:15:28 AM >
_____________________________
Rebel Racing, Sponsored by, Byron Fuel Looking for a new engine sponsor!
