RE: STS Engines
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> RE: STS Engines Page: <<   < prev  18 19 20 21 [22] 23 24 25 26 27   next >   >>
Login
RE: STS Engines - 7/3/2008 6:24:22 AM
james1212
Status: offline
i got the sts d28 pro 5 port truggie motor # 2809. i got it on ebay at rc mall in hong kong for 118.00 plus 10.00 s/h. i finished hot breakin fully today and had throttle endpoint adjustment set at 60 out of 120 and this motor is awsome even with rich setting. it almost pulls whellies in my xtm mammoth st with stock two speed .
(in reply to jaywax)
       Post #: 526
RE: STS Engines - 7/3/2008 6:27:59 AM
james1212
Status: offline
i dont know why my motor came with all black crank but i dont care for 118.00 this is the best motor for the money hands down. i am very impressed with my sts d28 pro 5 port triggie motor #2809. i think will keep up with the itallians jobs anyday. sts motors rock!!!!!!!!!!!!!!
(in reply to james1212)
       Post #: 527
RE: STS Engines - 7/3/2008 6:32:35 AM
james1212
Status: offline
repeat i got my sts d28 pro 5 port truggie motor #2809 from rc mall in hong kong on ebay buy it now price for 118.00 plus 10.00 s/h . not rc mart like i posted a couple days ago. repeat rc mall not rc mart.
       Post #: 528
RE: STS Engines - 7/3/2008 6:39:17 AM
james1212
Status: offline
sory about the goof up 1 more time rc mall on ebay not rc mart. rc mart is where my brother got his hyper 21 8 port race with black crankcase and boost tube for 139.00 plus 10.00 s/h. it has 2.7 hp at 38000 rpm instead of regular hyper 21 8 port 2.5 at 38000rpm .
       Post #: 529
RE: STS Engines - 7/4/2008 5:02:33 PM
jaywax
Status: offline
quote:
ORIGINAL: james1212
Dude you got ripped on the sale. The engine you bought is the D28M 3 port monster truck engine with a standard backplate. All the older versions of the 28 and 30 came with black crank shafts. Do not go by that #, because it is false adverstisement. I went to rcmall and compared it to nitrocountry rc and sts website. They now sell the older versions with a standard backplate. It looks like the newer 5-port, but it is not. My 5-port came with silver crankshaft. Go to nitrocountryrc and look at the older version of the 28. It has a black crank shaft. The newer version is just called the D28, not D28M. The M stands for monster truck. Also, that was the reason your engine was so cheap ($118). All the 5-ports 28 are much higher than the price you qouted. It sucks, but that is what happened. Go to this website and click on the 28 section and look at the standard engine and compare it to the Team engines. You will see the crank shafts. http://www.stsrc.com.tw/index.php
< Message edited by jaywax -- 7/4/2008 5:10:49 PM >
_____________________________
Mugen MBX5T Prospec w/STS S21T***KO Propo EX-10 Helio w/Spektrum Pro Module
       Post #: 530
RE: STS Engines - 7/4/2008 10:47:07 PM
ugly duck
Status: offline
I don't know that the colour of the crankshaft is a very good indicator of how many ports the kid has - things change from time to time throughout a production run - maybe he's got an earlier version when they still had some black crankshafts on the shelf, or maybe you got one that didn't get the black treatment. Claiming that RC Mall is ripping people off knowingly based entirely on the lack of a silver crank is pretty daring. For him to pull the head will tell him if it's a 3 port or a 5 port pretty efficiently.
Sponsored by Redcat-Vancouver
Email: westcoasthobbies@shaw.ca
       Post #: 531
RE: STS Engines - 7/5/2008 11:59:12 PM
james1212
Status: offline
mine is the d28 pro 5 port race truggie motor #2809 . i took it apart it has the 5 port sleeve and piston . p/s looks like the picture on sts website just dosent have polished crank. i know it is the 5 port becauce it has 5 ports plus exhaust port. and the head only says sts 28. the sts d28m says it right on the head.i did my research i have a 5 port just with black crankshaft. it hits good rpm too not like a three port.
(in reply to ugly duck)
       Post #: 532
RE: STS Engines - 7/6/2008 12:04:06 AM
james1212
Status: offline
the 5 ports on my sleeve look exactly like sts website. the exhaust port on block looks the same . the head has some shine on the sides the d28m head is all grey with no shiney parts. my head only says sts 28 the d28m head says sts d28m rite on it.
       Post #: 533
RE: STS Engines - 7/6/2008 12:16:25 AM
james1212
Status: offline
my sts d28 pro also came with the 2 carb restrictors i believe the d28m 3 port dose not come with the carb restrictors
       Post #: 534
RE: STS Engines - 7/6/2008 12:23:39 AM
james1212
Status: offline
also my d28 pro 5 port came with the black throttle ball on carb not the gold one like on the d28m 3 port. so i did not get ripped off maybe i got the new one. i just got it in the last couple weeks. but it has 5 port plus exhaust so i think i got a steal this motor rocks high rpm all day .
< Message edited by james1212 -- 7/6/2008 12:48:12 AM >
       Post #: 535
RE: STS Engines - 7/6/2008 12:44:01 AM
james1212
Status: offline
one more thing my box for the sts d28 pro 5 port came in has the info sticker on the side that says as so
  • #2809 monster 28 engine
  • type:rear exhaust w/o pull start
  • cylinder contents:4.6cc
  • bore/stroke: 18;80/16:80(m/m)
  • carburetor:2 needles slide 8 mm
  • crankshaft:14 mm sg type
    • piston/sleeve: abc type 5-ports
    • glow-plug: normal
    • weight:374g
    made in taiwan
on the bottom it has serial bar and #2809 did your box for your sts d28 pro 5 port truggie motor list the info like this thanx for info.
< Message edited by james1212 -- 7/7/2008 5:09:35 AM >
       Post #: 536
RE: STS Engines - 7/6/2008 1:08:34 AM
james1212
Status: offline
i also have different ? can my dad fit proline road rage 40 series tires on stock tmaxx rims. my dad seems to think so . i told him no they wont fit.any info helpful. thanx.
       Post #: 537
RE: STS Engines - 7/6/2008 3:32:16 AM
JB COMP
Status: offline
quote:
ORIGINAL: james1212
This is the "car engine" forum, this question would be better suited in the "traxxas MT" forum, but to answer you, no the 40 series will not fit the standard maxx size wheels. The standard maxx wheels are 3.2 inches and the 40 series is 3.7 inches.
LX Comp: STS21B, JP-3, DX3.0 - CRT: STS 30 Rev2 or Mach 427, STS 0702, DX3.0 - T-maxx: TRX2.5
Airtronics. BlueBird.
       Post #: 538
RE: STS Engines - 7/7/2008 6:32:01 AM
james1212
Status: offline
the d28m #2805 with standard backplate does look like the d28 pro 5 port #2809 after doing some research, but it has a three port sleeve. mine is a 5 port sleeve it just has black crankshaft.
< Message edited by james1212 -- 7/7/2008 6:34:21 AM >
(in reply to JB COMP)
       Post #: 539
RE: STS Engines - 7/7/2008 7:09:29 AM
james1212
Status: offline
quote:
ORIGINAL: jaywax
quote:
ORIGINAL: james1212
       Post #: 540
