JB COMP
Joined: 11/23/2006 From: Navarre, FL, USA Status: offline
Here check out how a tuned pipe works http://www.bukupower.com/animatecorrect.aspx if you get a low end pipe for a engine that has all its power in the mid or top then the engine gona run bad, or not the best. you get a pipe for thats best for the engine you run then regear to the track, like I run on a tight track, and I'm running a STS 21B which has good mid-top so I got a JP-3 which is a good mid-top pipe and I geared for the track.
_____________________________
LX Comp: STS21B, JP-3, DX3.0 - CRT: STS 30 Rev2 or Mach 427, STS 0702, DX3.0 - T-maxx: TRX2.5 Airtronics. BlueBird.
