RE: STS Engines
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> RE: STS Engines
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: STS Engines - 12/31/2007 2:49:33 AM
46u
Status: offline
I do not recommend the Drake method unless you are a pro driver that gets their engines for free!
_____________________________
Rebel Racing, Sponsored by, Byron Fuel Looking for a new engine sponsor!
(in reply to j_blaze)
       Post #: 76
RE: STS Engines - 1/1/2008 2:48:03 AM
j_blaze
Status: offline
you are absolutely right, but i'm hardly a pro, i'll keep doing it until something goes wrong. i just want to keep posting the progress cause sts engines have been accused of needing like a whole gallon to break in the engine, i just want people to see there is another option that works, if you dare.
CASTER K8T Pro - GO 21 R-Spec/RB WS7III, JR, DX3R
Caster Zx1-R (soon) - ????
(in reply to 46u)
       Post #: 77
RE: STS Engines - 1/1/2008 2:53:47 AM
JB COMP
Status: offline
my 21B was not bad to break-in, or had any problems, but its the new 30's that most people have the problems with.
j_blaze, lmk how many gallons you get on your engines with this break-in method, I might try next time I break-in an engine. (which will be a while, since I don't drive a lot anymore )
LX Comp: STS21B, JP-3, DX3.0 - CRT: STS 30 Rev2 or Mach 427, STS 0702, DX3.0 - T-maxx: TRX2.5
Airtronics. BlueBird.
       Post #: 78
RE: STS Engines - 1/1/2008 8:52:23 AM
Kemo
Status: offline
quote:
ORIGINAL: JB COMP
Kemo, most likely the priceing of the new S21T will be close to the same as the MKii if not more.
I wont be stocking anymore STS engines... i haven't heard from my distributor for a long while, and thats not a good sign. I'll be stocking Go Tech engines from now on because of this.
There are only 10 types of people in this world: those that understand binary, and those that don''t.
AMA: 722748
(in reply to JB COMP)
       Post #: 79
RE: STS Engines - 1/1/2008 5:04:59 PM
46u
Status: offline
I have talked to several that have not heard from Mark at STS Micro Engines in quite a while and if you look on his site he sure is out of stock on a lot of items. I sure hope he is OK and would let people know what is going on!
(in reply to Kemo)
       Post #: 80
RE: STS Engines - 1/1/2008 5:22:26 PM
JB COMP
Status: offline
Mark and http://nitrocountryrc.com/index.php have most of there STS stuff out of stock.
(in reply to 46u)
       Post #: 81
RE: STS Engines - 1/1/2008 5:47:51 PM
46u
Status: offline
Maybe they are letting their stock get low for the end of the year inventory for taxes. Mark does not even have anything about the new S21T on his site.
       Post #: 82
RE: STS Engines - 1/1/2008 6:03:00 PM
JB COMP
Status: offline
I talked to the guy at www.projectzen.net and he said he has no problem getting STS stuff, that where they get there stuff from way not be a legal place, sorry got to run, so if any thing not spelled right.
(in reply to 46u)
       Post #: 83
RE: STS Engines - 1/13/2008 2:22:03 PM
j_blaze
Status: offline
woah, had a bit of an incident yesterday. throttle servo locked up, of course at wot, ant hyper st jumped the track and flipped upside down, wheels ballooning. the engione was screaming to the point that is leaned out and sputtered. i shut it down, took it home and the pinch is still very good, should the incident damage the compression at all? i had a cheepo engine do the same thing when my hyper 7 battery fell out, of course at wot. i'll have it out again as soon as the servos arrive tomorrow.
       Post #: 84
RE: STS Engines - 1/16/2008 3:24:06 AM
j_blaze
Status: offline
ok, switching out clutch shoes i checked the second d21b and it has an air leak in the front bearing. i have a new bearing. i have the case in the oven and the new bearing in the freezer, right. pop out the old one pop in the new one, done, right.
       Post #: 85
RE: STS Engines - 1/16/2008 3:59:23 AM
JB COMP
Status: offline
Mark and nitro country are still out of stock on most of there STS enignes, looks like www.projectzen.net may be the only STS dealer in the US.
       Post #: 86
RE: STS Engines - 1/16/2008 7:10:27 PM
JB COMP
Status: offline
anyong know anthing on why those 2 places are still out of stock?
46u have you heard from Mark?
       Post #: 87
RE: STS Engines - 1/16/2008 9:34:48 PM
46u
Status: offline
From what Mark told me he is having problems getting parts and engines from STS. Not sure what the problem is but he is not happy and not sure he will keep selling STS products. There was a similar problem with GO engines a while back and engines as well as parts where hard to get.
       Post #: 88
RE: STS Engines - 1/16/2008 9:39:06 PM
JB COMP
Status: offline
the guy at projectzen, said he gets his stuff direct from the manufacture, and he has no problem getting his stuff.
(in reply to 46u)
       Post #: 89
RE: STS Engines - 1/17/2008 1:47:54 AM
j_blaze
Status: offline
i got mine on ebay, rc-mall but it did come from taiwan or hong kong or somewhere very far. took about 10 days total. the engine was quitin last time out at wot so i checked i for air leak. can ia use a small amount of gasket maker silicone stuff/sealer around the front bearing and shaft?, or is that a dry fit?
       Post #: 90
RE: STS Engines - 1/17/2008 2:06:15 AM
46u
Status: offline
Never use sealer on my front bearing or crank shaft.
Rebel Ra
