jmir
NC, USA Status: offline
quote:
ORIGINAL: 3DownLow Try the SFG's and T-wing. Everyone who has tried these mods has reported better high alpha flight tendencies. I know mine wouldn't hover or harrier very well until I added the mods. After adding them, whole other story. Much better harriers, hovers and elevators. Couldn't get it to elevator(well) without them. Believe me I don't like doing extra work to a plane unless it needs it and this one needed it to make it do what I expected it to do. Also try to keep the weight down under 18oz if you can help it. That makes a big difference too. I tried mine out with a 2100 pack and it would pattern fly fine but the 3D suffered with the added weight. My 2 cents. Ditto! I have not tried the T-Wing, but the SFG's really help on 3D maneuvers, especially knife edge passes. Only problem I have is that my e-flite servo on elevator is no longer centering. This is the second one, so this time I will replace with an HS55 and hope it works better. Only other mod, besides using some clear packing tape to strengthen the fuselage, has been to use "Great Stuff" foam which I spread at the weak point on the fuselage (upper part, above the exhaust opening). No more flexing in that area!
_____________________________
Not raining? Not too windy? Guess what I''m doing!
