RE: What LiPo/Charger is everyone running
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Helimax >> RE: What LiPo/Charger is everyone running
Page: <<   < prev  1 2 3 4 [5]
Login
RE: What LiPo/Charger is everyone running - 3/19/2007 11:40:01 PM
DriveWRX
Status: offline
Thanks Heliko!
I will give them a try and see what happens. I'll post my findings when I can. (I don't even have the Axe yet!!! Nor can I do more than hover and drift around a little... )
Thanks for your other post. Good info there!
(in reply to Heliko)
       Post #: 101
RE: What LiPo/Charger is everyone running - 3/20/2007 7:01:08 AM
Heliko
Status: offline
Your welcome, glad to help!
_____________________________
"Gravity is a harsh mistress." The Tick
(in reply to DriveWRX)
       Post #: 102
RE: What LiPo/Charger is everyone running - 3/24/2007 4:25:44 PM
markconsig
Status: offline
I'm also running a TP-425 charger with a TP1320 battery. It's pretty sweet having longer than a 4 min flying time. One question though, how long are these thing supposed to take to charge up. Seems like forever for this high tech gadget.
(in reply to BoysToys)
       Post #: 103
RE: What LiPo/Charger is everyone running - 3/27/2007 7:21:20 PM
rc-jj
Status: offline
i have a question abotu the set-up ( i finally got around to it - been flying the sim and started Radd's and using stock battery) ... i tried to charge with the computer power supply but my balancer http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMGS7
keeps beeping and paperwork accompanying says that it has apower supply problem .... did you have any such problems?
thanks a bunch
I am NewB at Flying ... but a Master at crashing !!!
(in reply to NewAxeCp)
       Post #: 104
RE: What LiPo/Charger is everyone running - 3/27/2007 11:36:27 PM
Heliko
Status: offline
quote:
ORIGINAL: rc-jj
thanks a bunch
My set-up has worked flawlessly (pictured below). What charger are you using with the balancer?
Also if you have a voltmeter check the output voltage of the power supply. It should be 12-14 volts. If it's above or below this then it might cause problems.
Click to see fullsize image.
Click for fullsize
(in reply to rc-jj)
       Post #: 105
RE: What LiPo/Charger is everyone running - 3/28/2007 3:29:55 AM
rc-jj
Status: offline
oooh now i am lost (sorry like i said before i am still such a new-b AND retarded :-) ...double whammy
I am using the Electrify Polycharge balancer http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMGS7
i thought that i connected it directly to the cords off the computer power supply (the clips from the balancer clipped to cords of Power supply)
am i just way off the mark?
       Post #: 106
RE: What LiPo/Charger is everyone running - 3/28/2007 6:26:54 AM
Heliko
Status: offline
Way off! No worries though. The Equinox is used in conjuction with a charger. It gives a conventional Li-Po charger balancing capabilities. The Equinox by itself is not a charger, but merely an adaptor to allow a balancing charge. The Equinox will do a quick balance on it's own, but that's it.
Bottom line. Your still going to have to buy a charger.
Believe me I know this stuff can be confusing. When I bought my Axe 'balancing connectors' were new to me and I had little experience with Li-Po's anyway. I bought a Hobbico MKII charger with a Electrifly 11.1v, 910ma 'Safecharge battery' as recommended by Tower. I charged the battery one time and accidentially ran it down to like 8.9 volts.
When I tried to charge it with the MKII it wouldn't work. I called Hobbico and the tech told me that the MKII was having problems telling whether the pack was a 2 or 3 cell pack. I'd start the charger it'd run for a couple of seconds then shut off. The tech actually told me to keep trying to see if the charger will stay engaged. Yeah right!
Instead I sent them the pack and it must've been bad because they sent me a new one. After reading many people were having problems with these 'Safecharge' packs I returned it. At the same time I found out that packs with balance connectors were the way to go. Knowing that The MKII wouldn't be up to the task I upgraded to the Duratrax ICE charger when I got the Equinox balancer.
To sum it up here's what I learned. If your gonna use Li-Po's get a good quality charger and balancer. The MKII has pretty much been dormant since I got the ICE. Basically a waste of $50. Right now your halfway there you just need to get a good charger. There are many choices. The ICE and Triton series are a good place to start. Good Luck!
< Message edited by Heliko -- 3/28/2007 6:50:40 AM >
(in reply to rc-jj)
       Post #: 107
RE: What LiPo/Charger is everyone running - 3/28/2007 1:26:57 PM
rc-jj
Status: offline
Heliko
much thanks for your explanation - i REALLY do appreciate your patience and explaining things to me so clearly - so i guess it is back to my Hobby store for more supplies - at least i am having fun w/ my flight sim ... i know patience is needed in this hobby and so far i have no regrets.
Again thanks for the help - i'll go shopping, and keep you posted.
have a great day bud
       Post #: 108
RE: What LiPo/Charger is everyone running - 3/28/2007 9:41:37 PM
Heliko
Status: offline
Glad to help.
You got the right attitude.
You just can't rush this stuff that's for sure.
...and yeah let me know how you make out.
Good Luck!
(in reply to rc-jj)
       Post #: 109
RE: What LiPo/Charger is everyone running - 4/4/2007 5:48:53 AM
brickisred
Status: offline
quote:
ORIGINAL: Heliko
So, Heliko, the MK II won't work with a cell balancer? It would be nice if Hobbico or Tower would mention this on their website...
       Post #: 110
RE: What LiPo/Charger is everyone running - 4/4/2007 9:30:47 PM
Heliko
Status: offline
quote:
ORIGINAL: brickisred
The MKII probably will work with the Equinox if you don't run the Li-po's too low. If they're run too low the MKII might have a problem figuring out if the Li-Po is a 2 or 3 cell. Since you can't manually input any selections other than battery type with the MKII your at the mercy of it's automatic sensing circuitry.
< Message edited by Heliko -- 4/4/2007 9:31:13 PM >
(in reply to brickisred)
       Post #: 111
RE: What LiPo/Charger is everyone running - 4/21/2007 3:47:02 PM
rc-jj
Status: offline
Heliko
guess i should do the polite thing and give you feedback on my power pack/ charger woes from way back when.....i (actually more like my brother - although i handed him tools) finally got the power pack up and running but i still had issues. it turned out my battery pack was bad - i called the company and they are sendimg me a new one ..... the worst part is just waiting for it to get here
have a great day and as always thanks a bunch for help and GREAT advice you give.
happy flying
JJ
       Post #: 112
RE: What LiPo/Charger is everyone running - 4/22/2007 8:16:00 PM
SchoooBaka
Status: offline
I bought a DN power 1350 lipo pack for 50 bucks and found a parkzone balancing charger for 33 bucks.
So far I love this setup. The charger peaks the battery in under an hour and I'm getting 7 to 10 minute flight times.
The battery set the cg slightly forward, but not enough to really affect hovering and flight, so I've been running it without adding any additional weight.
(in reply to rc-jj)
       Post #: 113
