dfalcon
MT, USA Status: offline
Thanks, that's pretty handy and worth bookmarking. I've already begun to think that I might need a larger pinion at some point in time, when I'm comfortable with inverted hovering enough to try some more intensive 3D stuff. Just by making sense of things on my own, I initially used (motor kV) * (approx. loaded battery voltage) * (pinion teeth) / (spur teeth) = rpm. Using this with 10.5V (I don't expect the motor to be working too hard and drawing the voltage down too much), 9T pinion, 4200kV Himax 2025, and 180T spur, I got 2205 rpm's. I trusted myself and ordered the components based on this information. Then I found an equation here at helihobby, and thought 'Uh, oh!' when I first saw it. But it still gave me the same result: (Target Head Speed x Main Gear Teeth) / (Motor Kv x Voltage x Percent Motor Efficiency) = Pinion Gear Teeth (2000rpm * 180T) / (4200kV * 11.1V * 85% efficeincy) = 9.08-tooth pinion When I've finally advanced beyond the basics, I'll probably go with an 10T or 11T pinion to get somewhere around 2400 to 2600 rpm's. But 9T will be a good starting point for the motor I've got.
< Message edited by thefalcon -- 1/18/2007 4:59:00 PM >
