Is this servo dead? Solved!
Tower Hobbies
Logged in as Guest
  Printable Version
208oz Servo
Seller:  monstertruck2000
Details:   $48.95   |  10/8/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Is this servo dead? Solved!
Page: [1]
Login
Is this servo dead? Solved! - 1/15/2007 11:19:47 PM
twoturnspin
Status: offline
Hi,
I have 3 x HB-56 in my TRex cyclic. I have had two crashes where at least one of my servos were damaged. Gear replacements have been easy enough but I now have two servos that when I power up without gears inserted I find that the little metal gear that goes down into the motor of the servo is continuously running.
Is this servo dead or is this a fault that can be rectified?
All the best, Simon
I'm updating my post because I found the answer myself and thought it might help someone else in the future. The metal gear inside the case seems to need resistance to centre. I installed a new gear set and found that the servo work just fine again.
< Message edited by twoturnspin -- 1/18/2007 5:32:07 AM >
_____________________________
Check out www.qpfa.org.au for info about aerobatics in Queensland
Wife:How many more planes do you need? Me:One more.
       Post #: 1
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.359RCU1
