How to Cut Tire Foams
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Rock Crawlers >> How to Cut Tire Foams
Page: [1]
Login
How to Cut Tire Foams - 1/16/2007 4:01:10 AM
Acs_guitars
Status: offline
When building a crawler you want your tires to be soft enough to grip the rocks, but still support the weight of the truck. There are several ways to modify the foams to do this… cut the foam in half, pie cut the foams, or do a star pattern as I am going to show. For me, this method yields the best results.
The first step is to use a marker and divide the foam in to 4 even sections.
Then 8...
Then 16.…
And finally 32...
Then mark a circle about ¼ to ½ up the side of the foam.
Then with a sharp pair of scissors, cut from the outside edge of 1 line to the inner diameter (you drew) on the next line over. Then from the next line back down to a point with the previous cut.
It should look like this…
Do this all the way around and it will look like this…
And you will have this left over.
This takes a bit of time, but will give you the extra bite on the rocks you need.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Acs_guitars -- 1/16/2007 4:07:51 AM >
_____________________________
Originator of the Web Crawlers Association WCA# 0001
AMA # 880471
       Post #: 1
RE: How to Cut Tire Foams - 1/16/2007 7:11:19 PM
Reiko
Status: offline
Another A+ how-to. Thanks for the info!
~Reiko~ RCU Car Forums Moderator
"It is just another day, the shame is gone;
Hard to believe that I have let it go"
- Christina the Lovely
(in reply to Acs_guitars)
       Post #: 2
RE: How to Cut Tire Foams - 1/17/2007 12:33:24 AM
Rc EnthuSiasTs
Status: offline
i was wondering how to get that pattern, thanks for the how-to!
Mr.pibb+Red Vines=Crazy Delicious
(in reply to Reiko)
       Post #: 3
RE: How to Cut Tire Foams - 2/17/2007 3:09:52 AM
proteus1377
Status: offline
Awesome how-to! This is great info considering a crawler is up in line for one of my next 2 RC builds.
XXX-T MF2 Mamba 6900Kv
**Comming Soon**
(in reply to Rc EnthuSiasTs)
       Post #: 4
RE: How to Cut Tire Foams - 3/2/2007 5:10:37 AM
aircruiser
Status: offline
first off thanks for the write-up! It was a big help today.
Second, I did this to my moab 2.2s and use an xacto knife to all doing the cuts to moabs. I also got a tear in the foam and when I was putting it back in the tire it ripped in half so I stuffed some paper towel in the crack and hopefully it will solve the issue.
TA02-STAMPEDE-TLT-RS4-RC18MT-MINI MAULER-RC10T--STRYKER B-SUPER CUB-COMMANDER 2-SCOUT-NEW BRIGHT HUMMER H2 (NOT SO STOCK)
(in reply to proteus1377)
       Post #: 5
RE: How to Cut Tire Foams - 3/20/2007 9:46:25 PM
coy5840
Status: offline
this is how I like to cut my foams.
Vertical Smile.. Ultimate comp crawler.
(in reply to aircruiser)
       Post #: 6
RE: How to Cut Tire Foams - 3/20/2007 10:54:25 PM
andrewhendler
Status: offline
coy5840, is that a "secret" chassis I spy. I cant pm you but I did spot it right?
all I smoke is rubber.
(in reply to coy5840)
       Post #: 7
RE: How to Cut Tire Foams - 12/10/2007 10:20:18 PM
Username: Unavailable
Status: offline
Yeah what the hell is that in the background? it looks badass! PICS!!!!!
(in reply to andrewhendler)
       Post #: 8
RE: How to Cut Tire Foams - 3/20/2008 9:48:54 PM
SFC K
Status: offline
Here is what I used for foams. Team Trinity "Bomb Three" inserts. You also need Multi stage tire glue so the triple stage foams stay together. Careful as to what glue you use or the foams won't flex. What I like about this setup is that the tire flexes more and you get a solid tire patch to what ever surface you run them on. The foams are wide enough for sidewall strength too. Best way to describe it is an inner run flat system. You can see the difference in the size in the pictures.
Click for fullsize
Click for fullsize
(in reply to Username: Unavailable)
       Post #: 9
RE: How to Cut Tire Foams - 5/2/2008 10:49:14 PM
madmax22
Status: offline
how do you do this with black foams ?
They call me "butthead".......
(in reply to SFC K)
       Post #: 10
RE: How to Cut Tire Foams - 5/3/2008 1:22:20 AM
drevil
Status: offline
quote:
ORIGINAL: madmax22
You mean to mark the lines? How about a white or silver paint marker?
Mike
R/C Truck News - http://www.clodzone.com
(in reply to madmax22)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
