Bridi Killer Bee
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> Bridi Killer Bee
Page: [1] 2 3   next >   >>
Login
Bridi Killer Bee - 1/16/2007 5:25:08 AM
2slow2matter
Status: offline
I've searched and didn't come up with much. Anyone out there built/flown this bird? I acquired one over Christmas from a guy who was selling out. Got a good deal on an un-opened kit. I'm looking forward to building it. I was thinking of a zenoah 38 or something along those lines for power.
Anything to look out for during the build or while flying it? Instructions are impressive. i think they almost filled up the front AND BACK of a piece of paper. basically says heres the kit. Get some glue and put her together.
It's ok, though, this is definitely not my first build. I was just wondering what to expect when I start it next month.
_____________________________
From a pile of sticks they are born, to a pile of sticks shall they return.
       Post #: 1
RE: Bridi Killer Bee - 1/16/2007 5:26:43 AM
2slow2matter
Status: offline
Sorry, forgot to hit the notify button.
(in reply to 2slow2matter)
       Post #: 2
RE: Bridi Killer Bee - 1/16/2007 5:39:12 AM
Herb Brown
Status: offline
I have a Bridi Killer Bee, built from a Bridi kit and powered with a Zenoah G-38. It's easy to build and easy to fly. It is not a 3-d machine, but will do all of the basic aerobatic maneuvers.
I use it as my weekend flyer, just to keep the thumbs in practice.
You will enjoy.
none
       Post #: 3
RE: Bridi Killer Bee - 1/16/2007 3:57:59 PM
2slow2matter
Status: offline
Cool.
Thanks, what I wanted to hear!
You wouldn't happen to have any pictures of it, would you?
(in reply to Herb Brown)
       Post #: 4
RE: Bridi Killer Bee - 1/20/2007 4:35:51 AM
badger5964
Status: offline
2slow2matter,
Looks like we could get a build thread on the killer bee going. I'm about half done and looks like one or two others to start see this thread a few posts started on the Bridi Killer Bee.
http://www.rcuniverse.com/forum/m_4067945/tm.htm
       Post #: 5
RE: Bridi Killer Bee - 1/29/2007 4:45:31 PM
cloud Walker
Status: offline
here are some pitchers of my killer bee. I built the killer bee in 2004. It has a Saito 180 in it and Hitec 425 Servos and a six volt battery in it . It is fun to fly. Mel
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 6
RE: Bridi Killer Bee - 1/29/2007 11:24:41 PM
BigBird1
Status: offline
quote:
ORIGINAL: Herb Brown
You will enjoy.
I've got a question...I've got the same kit..and haven't started it yet and have a Poulan 46 that CH converted for me laying around..is their enough room to possibly stuff it in..or would it be too much.
BB1
I never met a Chaos I didn't like
       Post #: 7
RE: Bridi Killer Bee - 1/30/2007 12:14:08 AM
WhiteRook
Status: offline
does it come with a hardware package?
(in reply to cloud Walker)
       Post #: 8
RE: Bridi Killer Bee - 1/30/2007 12:24:18 AM
BigBird1
Status: offline
quote:
ORIGINAL: typhoonfury
Nope, you are on you're own their..
BB!
(in reply to WhiteRook)
       Post #: 9
RE: Bridi Killer Bee - 1/30/2007 3:52:23 AM
2slow2matter
Status: offline
No hardware at all. Some plastic pieces, but that's it. Cloud--that is one good looking bird. Thanks for the pics. Any pics of it flying?
badger,
a build thread would be awesome. unfortunately, I'm still over a week from finishing my wife's kadet, and then I have another kit that is in line first. It will most likely be mid March before I can start. I would love if you would make one (if indeed you are building yours right now). I would follow it religiously.
Thanks.
happy flying
(in reply to BigBird1)
       Post #: 10
RE: Bridi Killer Bee - 1/31/2007 1:27:10 AM
badger5964
Status: offline
OK
Here is a couple pictures from a previous post on the fuselage.
I did cut in the lightening holes, changed out 1/2" triangle stock for 3/4" and added 1/2" triangle stock in corners of rear fuselage.
I also choose 1/8" sheet on top forward section of fuse. This looked alot easier than planking with 1/8 x 1/4 peices provided. I still used those on the curvy part as the 1/8 sheet does not bend well or easy.
The ST 3250 mounted to the firewall would be way short. I used a 5" hole saw and a 3" hole saw to make ring shaped peices from 1/4 plywood. I stacked these to make a forward firewall for the radial mount of the ST. I also added another 1/4" sheet to double up the existing firewall, making it a whole half inch thick. If I was to do over I would double up the firewall. This added alot of extra weight.
The plans call for stringers on the turtle deck. I never liked this look so I purchased thinner stringers, trimmed the formers 3/32 and used 3/32 to sheet plank the turtle deck.
Pictures show the rough sanded results.
Click for fullsize
Click for fullsize
       Post #: 11
RE: Bridi Killer Bee - 1/31/2007 2:58:06 AM
badger5964
Status: offline
I made some progress over the last two weekends, the first significant progress since Christmas.
Finished sheeting the right wing half and fabricated the servo mounts.
I applied about a 3-1/2" wide center 1.5 oz fiberglass ribbon to top and bottom center joint. The plans call for at least a 5" wide sectiion of glass but the instruction say this is not necessary as the plywood dihedral support will handle all the load. Bridi needs to tighten up here instruction sheet. At just two pages it has to be accurate and the fix can't be more then a simple edit in a word processor.
I did not like how this thing fitted up when joining the two halves. Plans call for building the left wing half, including the dihedral support. The right wing spars, ribs, trailing sheeting are built then this partial is added to the dihedral support and the left wing. It is do able, but unweildy.
I do not like mounting my aileron servos as shown on plans. Plans show mounting to rails "flat", where the whole servo protrudes from wing. I like to mount mine on their side to an access plate. Only the servo arm protrudes. I think it looks neater, this is just my preference, plan detail works just fine also.
The access plate and servo mounts are next on schedule.
The spars are just 3/8 square balsa which I felt was light but others thought it OK. However since I'm putting power above recommended I ran 1/4" carbon TOW along top and bottom spars from center leaving last two rib bays unreinforced. First application of this stuff and I am quite surprised how strong and stiff it makes the wing.
The landing gear mounts do not fit as nice as I would have liked. Without alot of trimming they would stick out of the wing form. I spent alot of time cutting and trimming so they would fit under the sheeting.
Crudely took out three circle like lightening holes in each rib. Brass tubes, brad points, forster bits, unibits I have found nothing to cut large circular holes in balsa sheet neatly and easily. Brass tubes dull after just a few holes. Great Planes has done a nice job with a couple tools for builders like their slot machine and dead center hole locater. I may write them with suggestion to invent a decent hole saw for balsa. There is a thing called a tile hole saw with diamond grit for teeth. Too large and expensive but something along that line, I think, would work.
Ribs are not laser cut but sanded to shape. Makes for a nice fit. But also means there are not alignment tabs on ribs similar to what I've seen on Four Star, Hog Bipe and Contenders. One must draw a center line down the each rib them block them so they are parallel. Not hard or inaccurate but just adds some time to build.
The trailing edge is just a peice of rectangular stock. It does not match the airfoil profile and the rib height at attachment width varies the taper of the wing so one has gaps between it and the trailing edge sheeting. I added a thin strip to the stock and sanded to shape of airfoil so no gaps would be present between it and the sheeting.
I wanted to try Robart hinge points so I added some scrap to the interior of trailing edge at the appropriate spots. The plan stock here is thick enough to support CA or pinned hinges but not the Robarts.
Test fit of wing on fuse shows a large step in profile from trailing edge of wing to fuse. Also the chord taper mates to a flat fuse section so there is a large gap. I intend to fill the gap and feather some balsa onto the fuse for a smooth match to the wing. Plan calls for a 1/32 ply plate to cover this but I wanted a slicker appearance. This also lead me to purchase a Robart Incidence Meter. The wing looks like it is parallel to the datum line as shown on plans. However the ill fit leads makes me question the incidence and this is a good excuse to purchase another tool. Hope the LHS has one.
This is my first tapered wing and being this is a more advanced construction I had expected a more difficult build then previous experience. However I give the wing engineering a "D+". The landing gear mounts could have been closer to final shape, 1 point off. The wing trailing edge/sheeting/rib joint cannot be sanded to shape without adding addtional material, .5 point off. The poor fit at the fuse/ wing trailing edge shows poor engineering also, 1 point off. The manual gets another 1/2 point deduction. Given what one can do today with a word processor, digital camera and a cheap printer some effort needs to be given. Oh almost forgot, Bluejay charged me $5 for a replacement manual. A little cheap when I would think could be emailed to me.
Still have to fabricate the stabilzers, elevators and rudder. Here are some pictures.
(in reply to badger5964)
       Post #: 12
RE: Bridi Killer Bee - 1/31/2007 3:01:29 AM
badger5964
Status: offline
Fat fingered something on picture upload. Here they are:
Click for fullsize
Click for fullsize
       Post #: 13
RE: Bridi Killer Bee - 1/31/2007 3:53:05 AM
