*JCB*
CA, USA Status: offline
Submike - the plane is a scratch build from plans by Ernie Heyworth (Super nice guy too!!). I asked him [Ernie] about putting a glow engine on it and he said that a couple people in his area have mounted 30's on them with a little reinforcement. It will have a 53" wingspan once i put the wing tips on. AND I didn't go electric for a number of reasons: too easy, too clean, too quite and most of all for Hobbsy's reason, the fun factor!! Hobbsy, thanks for the suggestion. So are you saying that instead of pressurizing the tank, just leave it vented using the pressure for the pump and use a cline regulator instead of an oscillating pump? remember, i have never used a pump before so i have little clue as to what i am getting myself into! a picture would be greatly appreciated. Other than that, i have set the motor on top of the plane and it appears to be quite top-heavy which is a bit worrysome. And Ed, i have thought about the vibrational forces from having a 4-stroke sitting on top of the wing, and that also worries me. I have taken some precaution however. The cabanes are fiberglassed in, the ribs that the cabanes are attached to are reinforced as much as i could and will be reinforced more once i glue the wing together and get the wing joiner in. It will also have struts on the wings...so hopefully all this will spread out the vibration as you suggested. BTW: Submikester, guess who gets to walk out there with me when i maiden it! you thought I was nervous before!!
_____________________________
"If your head is wax, don't walk in the sun." - B. Franklin
