markind
CA, USA Status: offline
Glad to hear you had a great first experience with this model, all the preparation does really pay off. Did you get some time on the simulator before the maiden? Any pics? I did not fly this weekend but I did get the fuselage on the test bench and ran a quarter tank of fuel through my Evo .52. I played with the valve settings but really the main thing was THE PLUG. With the stock recommended HAN3011 plug, she runs smooth, has a smooth idle-to-WOT transition, and give more high end power. Sweet! She ROARS again! Very slight vibration noticed, and it varied depending on the RPM, so I will put the spinner and prop through the balancing procedures tonight. That should clean it up. Next, I will try to get the minimum reliable idle speed down a bit. More playing with the lower needle bar. Weather looks bad but I should get her flying again in a week or two...
