509thBoomer
WA, USA Status: offline
quote:
ORIGINAL: RC-Captain quote:
ORIGINAL: 509thBoomer My official 1st flight(s) report. Raptor #1: Mine with the "WA" on the tail. Powered by an OS 55AX. I needed zero weight to balance it. I had an 12X7 prop and 15% Cool Power. All I can say is wow!!! She took off in about 12 feet and climbed for the stars. On max rate with -30 on the expo she flies like a dream. Stalls straight ahead and lands nice and slow (that is compared to my F-4). The plane will not knife edge but will do everything else that this type of airflame should. On a scale of 0-10 for funness, I would give it a 9.5. Very well built and fun to fly plane. Perfect for being a hot dog and fast if you want it to be (here comes the tuned pipe)!!! Raptor #2. My buddies F-22 that I built for him (behind my Phantom). Powered by an Evolution .46, 15% Cool Power, and the 3 blade prop that came with it. This bird had the flaps down, anti-tip stall thingies and a touch of weight in the nose. I made the 1st flight as well, and as a 1st airplane I would be a little worried as it might be a little fast, that being said it does stall straight ahead as it should and lands very slow. Maybe I am used to fast, point and fly airplanes but with all the trainer stuff added the plane seemed mushy. On a 0-10 scale for learning I would give it a 6. My buddy decided to wait until there was zero wind to fly his as the Fairchild AFB cross wind was in full effect today. you didn't think we would think your buddies plane would rate as high as yours did you ? I knew it would not be as fast but being I put both of the together I did not expect there to be as much of a diffenence. On that note I took all of his training stuff off and noticed it flies "normal" now.
_____________________________
Phil Fairchild AFB WA
