.50LX Vs .60LX
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> .50LX Vs .60LX Page: [1]
Login
.50LX Vs .60LX - 1/20/2007 1:55:45 AM
propjets4me
Status: offline
Hi I might be able to purchase an old whiplash down here, and I have alot of pattern engines..which aren't suited...
could you indicate which would be the prefferential engine, while listing the difference apart from the obvious displacement..lol
I imagine the .60 LX would turn more prop but is this needed on a whiplash
failing that I might build my own version of a diamond dust...
thanks
Frank
       Post #: 1
RE: .50LX Vs .60LX - 1/21/2007 3:09:57 PM
bob27s
Status: offline
Hi,
Thanks for writing. Either the 50LX or 60LX will make the whiplash/dust planes move quite nicely.
Both engines are designed to run appx the same 17,500-19000 rpm range (ground peak rpm)
The 60LX does hold its own a bit more on the top end. Easily turns a 9x9, and we prefer to run the 8.8x9 Q-500 prop on it. With the RE version on a full pipe, one of the best props is the 8.8x9.25 clipped down to about 8.25" diameter.
The 50LX is more at home with the 8.8x8.75, and a clipped 8.8x9 - so it runs great, but you give up about one prop size.
Choice of engine comes down to what you might want to use it for later on
Bob
_____________________________
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to propjets4me)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU1
