RE: Ultimate CX2 Mod Guide
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> RE: Ultimate CX2 Mod Guide
Page: <<   < prev  1 2 3 4 [5] 6 7 8 9   next >   >>
Login
RE: Ultimate CX2 Mod Guide - 3/28/2007 3:54:08 PM
makatron
Status: offline
the dx7 is the only one capable to bind with the blade cx2 receiver cause its dsm2 and dx6 is dsm
but you can use an AR6000 with your blade cx
_____________________________
I fly................therefore i exist
The more you Crash........more you wanna mode your bird
(in reply to armycopter)
       Post #: 101
RE: Ultimate CX2 Mod Guide - 3/28/2007 11:33:17 PM
armycopter
Status: offline
That figures... I knew I should have bought the DX7 originally!
(in reply to makatron)
       Post #: 102
RE: Ultimate CX2 Mod Guide - 3/29/2007 12:07:32 AM
mrasmm
Status: offline
With your stock charger it will likely take 2 hours to charge because it probably only charges at either 650mA or 500mA. The battery can be charged in 1 hour if you have the right charger, and most chargers are made to charge in 1 hour. I just mentioned in another post that I have no idea why e-flite has a 800mAh battery and a 500mA charger... unless it is a saftey margin type thing for beginners.
Thanks for mentioning the FMA stuff. I went to look it up because I am putting a post together on lipo's, and I ran into a wonderful resource over there. Anyways this is the adaptor you need, and you should be able to get it anywhere you can get FMA stuff
http://www.fmadirect.com/detail.htm?item=2196§ion=45
I don't think you can adjust the throttle except with the throttle trim. If you have a nice computer Tx you can do it just fine, but with the stock setup I think it is non-adjustable.
quote:
ORIGINAL: vphan13
Hey guys,
I have 3 questions for you guys.
Where can I get the E-Flight Node Adaptor to work with this Charger? I looked on the link but still am not sure which one I need
Secondly, how long does it typically take you guys to charge your lipo with the stock charger? My LHS said I should be able to get a full charge in about an hour, but its been consistantly 2 hours. I've got about 5 charges on the one included lipo.
Lastly, on my throttle trim, I have to be at past halfway before I get any speed on the blades, where can I adjust this properly.
----FMA Direct CellPro 4S Balance Charger----
-Safely Charges Batteries in 50 min vs 2 hours
-Can Charge Pack Immediatly After Discharge (No cooling needed)
-Can Restore Overdischarged Packs
-Idiot Proof Automatic Charging Method
-Requires E-Flight Node Adaptor or Battery Pack Balance Node Change
I don't always check every thread I respond to, so feel free to PM me
(in reply to vphan13)
       Post #: 103
RE: Ultimate CX2 Mod Guide - 4/2/2007 3:05:07 AM
xanaphyst
Status: offline
you may want to add this to your mod list:
www.bladecxpro.com
"Can't this thing go any faster? "
(in reply to mrasmm)
       Post #: 104
RE: Ultimate CX2 Mod Guide - 4/2/2007 4:36:20 AM
glockgreg
Status: offline
Hi to everyone! my ? is where do you buy the extended inner&outer shafts for the cx2. will my micro heli upper & lower heads still work? I hope it does keep the blade strikes from happening! I am a cnc machinist by trade and have come up with my own upgrades for my cx2 with little program time however lots of r&d. I make dental equipment at work so there is lots of T6511 and 7075 aluminum around to use. I will be posting pics soon and offer parts, or your own ideas and ill machine it for you?. however my last problem I am working on is blade strikes my cx2 performs so much better I am more aggressive with the moves that I hope all my work wasnt for nothing I guess I got carried away I should have put that time into my cp-pro or mini titan e-325. but I just love my cx2 for indoor fun and with Oregon weather so "iffy" I have spent more time with it than any other this year..........thanx
(in reply to heyok)
       Post #: 105
RE: Ultimate CX2 Mod Guide - 4/2/2007 6:25:42 AM
makatron
Status: offline
WE DO NOT WANT bladecxpro in our mods list since those guys just rebrand stuff and resell it at higher price
they suck!!
(in reply to glockgreg)
       Post #: 106
RE: Ultimate CX2 Mod Guide - 4/5/2007 11:41:44 PM
ArrowNaughtic
Status: offline
this thread is too valuable to let slip in the back of this forum. Any new mods come out yet? Ya guys are slipping......
_________________________________________________________________________________
Of all the things I ever lost..................................... I miss my mind the most!
       Post #: 107
RE: Ultimate CX2 Mod Guide - 4/6/2007 9:07:05 PM
BCKoots
Status: offline
I read somewhere of a mod that will help get better forward flight, anyone done any mods like this?
Drive it till it's broken.
(in reply to ArrowNaughtic)
       Post #: 108
RE: Ultimate CX2 Mod Guide - 4/8/2007 7:42:19 PM
Blackjack52
Status: offline
Well authored and informative thread. It mirrors the main CX2 thread quite nicely. I'm new to the heli thread here, but not rotary/fixed wing; I have experience with the DF36Z, Trex, B-52G, and MH53J, but can't fly those anymore.
Only recommendation for the first post is to add a link to the other CX2 threads. NOTE: If you don't edit the first thread for a certain time, it won't let you change it.
Reading these threads has turned me in the direction of this bird vice the XRB SH and Helimax EZ.
Here go the questions: I already know the mods I want to incorporate when I get mine.......but not sure about the following:
1.) Who has installed the alum swashplate? I'm curious to know if this mod allows more authority when using the 4th horn hole. Will it allow further travel when using the 4th hole?
2.) Does the alum longer inner shaft cancel clacking, or is it still possible? I would think the flybar paddle mod would mostly negate the clacking.
3.) Deleted
4.) Has anyone used the complete CXPro Upgrade Kit?
5.) BZYGUY01.........how is the CP battery config working out?
6.) Does the tail shroud fit back on if you have the CF tail boom mod?
7.) How much heat transfer occurs from the lipo to the motor, due to proximity of the pack and motor/s?
8.) Up to what dimension pack will fit in this bird? 1000mAh 15c if they can be had!
9.) Alum rotor head mod allows use of the stock blades?
10) Is it possible to slightly elevate the swashlate higher on the shaft to prevent binding when using extended horn holes? Or can the struss below the swashplate be modified? Or does the swashplate come in contact with the blade grips? If so, they can be filed down to prevent binding.
11) Deleted
12) How much gyro authority trim is available with the 4-in-1? Can I dampen, or have 0 gyro input? Will make doing a modified Immelman maneuv much easier.
Really needed mods I figure are:
a) Heat sink
b) Alum rotor head
c) Alum swashplate
d) Alum extended inner shaft
e) CF tail boom
f) MegaPack 15c 850mAh
g) Remove flybar retention screw
h) Dunam Vrtex Flybar
< Message edited by Blackjack52 -- 4/10/2007 3:18:09 PM >
Splittin' them Hydrogen Atoms
38.4mph 12cell SV
(in reply to neilt6)
       Post #: 109
RE: Ultimate CX2 Mod Guide - 4/10/2007 12:37:12 AM
Blackjack52
Status: offline
Is the alum upgrd inner alum shaft (EFLH1240) an extended shaft? If not, is the Dynam Vortex inner shaft extended? If not, anyone know where to get one?
Thanks.
38.4mph 12cell SV
(in reply to Blackjack52)
       Post #: 110
RE: Ultimate CX2 Mod Guide - 4/16/2007 3:58:54 PM
ArrowNaughtic
Status: offline
Blackjack, I took the aluminum upper hub off my eflight inner shaft and installed it on the vortex inner shaft. Nice fit, and smooth flying!
Of all the things I ever lost.......................................... I miss my mind the most!
       Post #: 111
RE: Ultimate CX2 Mod Guide - 4/16/2007 5:21:23 PM
fishjunky
Status: offline
Arrow, is the vortex shaft longer?
}:{> --Accept the challenges so that you may feel the exhilaration of victory.
       Post #: 112
RE: Ultimate CX2 Mod Guide - 4/16/2007 9:58:55 PM
Blackjack52
Status: offline
Thanks ArrowNaughtic.
Anyone....I want to mod the flybar, but want to know if anyone has already done this.
Looking for some info on a modified stock flybar using the Helimax AXE EZ flybar ends. But first, it seems the stock flybar ends would have to be unhooked off (looks like they're hooked into place onto the stock ends). After removing the stock ends, the "hook" would have to be cut, being careful to ensure the same amount of material is removed from both sides, for balance. Then, it's just a matter of filing a small groove for the hex screw to dig into, and of course follow this with a quick balance.
Does this sound about right?
A plus to this mod I would surmise, having a shorter flybar, will get rid of some of the clacking.
I've heard pros/cons to using the Dynam Vortex flybar over the AXE mod. Anyone....anyone...Feris?
Thanks.
38.4mph 12cell SV
       Post #: 113
RE: Ultimate CX2 Mod Guide - 4/19/2007 8:48:51 PM
atcspaul
Status: offline
just tried out my new mega batterie from heli direct and all i can say is wow. it is like having a new bird. before if i took it to say 8 feet and cut the power and reaplied it would bounce lightly of the ground with the new battery it dosnt even make it half way to the ground and is flying again. power diference is unbelievable. i ordered late in the day and they still shipped it that day and had it withen 2 days. i am very pleased gets an A++++++++ from me
       Post #: 114
RE: Ultimate CX2 Mod Guide - 4/19/2007 10:22:04 PM
Black
