close call
Tower Hobbies
Logged in as Guest
  Printable Version
Team Losi Muggy - RTR
Seller:  PastorVee
Details:   $1,100.00   |  10/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> The Clubhouse >> close call
Page: [1]
Login
close call - 1/21/2007 9:38:55 PM
zx32tt
Status: offline
I had a really close call with a Coverite iron last night. I had finished a small covering repair and I thought, unplugged the iron. A couple of hours later, the smoke alarm goes off. Apparently I had unplugged the wrong cord, and the iron was still on. Not only that, the iron was in full contact with a formica top desk. I think the temp control took over and tried to get the iron up to the desired temp, and in the process melted the whole works. I now have a reminder on the desk to double check and ALWAYS unplug the iron.
Z
       Post #: 1
RE: close call - 1/21/2007 11:03:32 PM
Phlip
Status: offline
Wow. I HATE when that happens. I guess it's a good reminder to always use your little aluminum stand, too.
Phil
_____________________________
If the truth were self-evident, eloquence would be unnecessary.
Cicero (106 - 43 BC)
(in reply to zx32tt)
       Post #: 2
RE: close call - 1/21/2007 11:08:44 PM
DavidAgar
Status: offline
If your memory is like mine, my iron is usually plugged into a timer as I have a habit of walking off and leaving it on. Set it for whatever time you think you are going to need, and if you forget, it goes off on it's own. Good Luck, Dave
If the screw ain't loose then things ain't normal.
Dave Agar
AMA#97144
(in reply to Phlip)
       Post #: 3
RE: close call - 1/22/2007 2:44:08 AM
bofrcr
Status: offline
Hey guy! >"THAT"< is a VERY good idea!!
quote:
ORIGINAL: DavidAgar
(in reply to DavidAgar)
       Post #: 4
RE: close call - 1/22/2007 2:46:30 AM
bofrcr
Status: offline
A question: is the amp capacity of the timer enough?
quote:
ORIGINAL: DavidAgar
       Post #: 5
RE: close call - 1/22/2007 4:02:23 AM
JPGale
Status: offline
quote:
ORIGINAL: bofrcr
quote:
ORIGINAL: DavidAgar
If a timer works off the mains then its amp capacity should be enough, if not then just buy one that is, If these things can run electric lights and other things then they should be ok with a covering iron.
James
James Gale - Team Norred Aero Products #78 www.t34racing.com
(in reply to bofrcr)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.531RCU1
