OH Momma Look what I have done to the Topflight Contender
Tower Hobbies
Logged in as Guest
  Printable Version
Ziroli Stuka - laser lizard cut short kit - Kit
Seller:  laserlizard
Details:   $99.98   |  8/27/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Kit Building >> Kit Manufacturer Direct Support Forum >> OH Momma Look what I have done to the Topflight Contender
Page: [1]
Login
OH Momma Look what I have done to the Topflight Contender - 1/22/2007 2:15:46 PM
Blade47
Status: offline
Just a little kit bashing this winter ..just finished this nice kit with a "T" tail ..balanced weight 6.3 Lbs...mounted GMS .47 on it side with a Du-bro Vibe Motor mount ... Ailerons 1/2" wider at the tip and some other small mods.
cheers
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Pete
Revver Brother #93
       Post #: 1
RE: OH Momma Look what I have done to the Topflight Co... - 1/26/2007 4:26:02 PM
Blade47
Status: offline
Here is the build link if you want to check it out
http://www.rcuniverse.com/forum/m_5119063/mpage_1/key_/tm.htm
Pete
Revver Brother #93
(in reply to Blade47)
       Post #: 2
RE: OH Momma Look what I have done to the Topflight Co... - 1/26/2007 4:40:00 PM
IFlySlowPlanes
Status: offline
That's pretty cool! How strong will the stab be in that position? Also, when you fly it, it'll be interesting to note how much longer your takeoff runs will be compared to a conventional tail setup (ask Piper Lancer and Tomahawk owners about that!). Still, enhances the looks a bit. Good job!
       Post #: 3
RE: OH Momma Look what I have done to the Topflight Co... - 1/26/2007 5:44:07 PM
Blade47
Status: offline
The stab is mounted with 3/4" tri stock on the bottom attached to the fin ( Glued and Pinned ) the attached surface area is larger then what it would have been stock... I have a Strikemaster Modded with a T tail and there is little or no difference to the take off run ...still... it will be fun to try this one out.
I have not flown the stock configuration stab so I can not compare ... as long as it gets into the air I will be happy
Pete
Revver Brother #93
(in reply to IFlySlowPlanes)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.234RCU1
