RE: Speed Freaks Wanted
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: Speed Freaks Wanted Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
Login
RE: Speed Freaks Wanted - 12/6/2003 3:22:21 AM
vicman
Status: online
Don't know about Steve, but I used to live in the very low 11s and high 10s on my old 73 CB750. Then I moved down south where they only race in circles and ran the Legends and Dwarf Car series for a few. Gave all that up for this. Building and flying with my little boy KILLS anything I did on a track.
_____________________________
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
(in reply to Rudeboy)
       Post #: 251
RE: Speed Freaks Wanted - 12/6/2003 3:34:19 AM
LUDS96
Status: offline
This was my true love. Just cost way to much to maitain for just a Sunday flyer.
Click to see fullsize image.
Click for fullsize
(in reply to vicman)
       Post #: 252
RE: Speed Freaks Wanted - 12/7/2003 2:17:18 AM
vicman
Status: online
I am instantly suffering from plane envy.
(in reply to LUDS96)
       Post #: 253
RE: Speed Freaks Wanted - 12/7/2003 6:27:44 AM
willflyforfood
Status: offline
"Hi, my name is Joey, and I am a Speed Plane Addict.
I have been a Lover of Speed Planes for about 4 years,
and with the help of the Revvers Brotherhood I hope to
make my planes even FASTER !!!
Don't let my wife/girlfriend see this....I promised her I
would "tame it down a bit". : ( heh heh heh )
Dont have a pic right now but will try to get one up
(in reply to Flyboy Dave)
       Post #: 254
RE: Speed Freaks Wanted - 12/7/2003 7:21:15 AM
Razor-RCU
Status: offline
Whatcha flyin'?
Welcome--!
(in reply to willflyforfood)
       Post #: 255
RE: Speed Freaks Wanted - 12/7/2003 5:46:17 PM
willflyforfood
Status: offline
Iv'e got a p-51 that I am am flying right now, building a dominator 500 with an MVVS q-500 .40, and a shrike w/ a JETT BSE .21. TOO MUCH POWER IS JUUUUUSSSSSSST ENOUGH! I am also in the process of designing the cleanest fastest airframe I can possibly make, My physics professor is helping me with some airfoil design and I hope to have something unreal when I get done, its taking some time but I would like to see something in the 300 range
Joey
(in reply to Razor-RCU)
       Post #: 256
RE: Speed Freaks Wanted - 12/7/2003 6:08:12 PM
Mac-
Status: offline
Hi fellas!
This is my Rapier and ready to rap!
Normally flown on a .40 with a 9 x 8.
On a .53 2-stroke she will easily achieve 100+ mph!
Click for fullsize
Click for fullsize
       Post #: 257
RE: Speed Freaks Wanted - 12/7/2003 6:55:38 PM
rifleman3754
Status: offline
Is that a Magnum 52 XLS?
If so, run a 9-6, it will do 18k on the ground. Get rid of that plastic spinner or it will come off in the air. Go to turn turn or comp. Make sure your muffler is epoxied toghter, it will also come apart.
(in reply to Mac-)
       Post #: 258
RE: Speed Freaks Wanted - 12/7/2003 6:57:59 PM
rifleman3754
Status: offline
You can do all you want to your design, but you will never hit 300 unless it is powered by a turbine. I tried
       Post #: 259
RE: Speed Freaks Wanted - 12/7/2003 8:21:07 PM
Mac-
Status: offline
My Rapier has a low-cost standard Thunder Tiger GP.42 2-stroke fitted originally with a 10 x 6 Master prop. This produced around 11000 rpm with a prop braking speed of about 50 mph! So even in a dive the Rapier would only achieve 50 mph before prop braking occurred. By changing to a Master 9 x 8 the TT .42 produced just over 10000 rpm but now with a prop braking speed of around 70 mph the model is much faster and will easily achieve 70 mph in a shallow dive.
Too date the model has made around 30 flights with its existing setup without problems. It requires 6mm of up trim on the elevons to act as a reflex wing section due to the drag from its delta wing configuration. Engine is cut for final approach and stalls are non-existant!
(in reply to rifleman3754)
       Post #: 260
RE: Speed Freaks Wanted - 12/7/2003 10:07:56 PM
rifleman3754
Status: offline
I would imagine you would see that much perfromance out of a Jett 21 on a shrike 10.
You want perfriomance put a Sx32 OSMax or Rossi 2.2Hp. 21 eng on a Shrike 10 and see 150plus. You will have to modify the spars
       Post #: 261
RE: Speed Freaks Wanted - 12/8/2003 1:27:29 AM
Flyboy Dave
Status: offline
willflyforfood....
....Joey, welcome to the Speed Freaks Brotherhood. ....
....Official.... "Revver" # 53, is yours....
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
       Post #: 262
RE: Speed Freaks Wanted - 12/8/2003 3:51:03 AM
vicman
Status: online
Flyboy Dave,
Allow me to thank you for the fine thread management. And the smile (smirk) it puts on my face every time another member of the brotherhood comes clean with his deamons.
Keep up the great job!!
       Post #: 263
RE: Speed Freaks Wanted - 12/8/2003 4:09:26 AM
willflyforfood
