Mustang Exhaust
- Kit
Seller:tony-howard Details:
$35.00
| 9/21/2008
| Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
I don't know Evill ,on the plane ( draw) the weight is 9 kg ,but I think that is too much ,now my fiberglass fuse is 2 kg but this is too much ,I think that the second fuse will be around 1.5 kg . So fuse now is 2 kg ,the rudder is 45 gr the horizot stab is 110 gr ,the horizont. flap is 32 gr =2187 gr I don't know the wing what weight will be ...........
< Message edited by fokke -- 6/16/2008 9:49:01 AM >
ON, CANADA Status: offline
Rumen - you're a true artist. I can't believe how fast things are coming together for you over there! Are you dreaming of the maiden flight yet? - keep feeding those elves man
