RE: Project BF-109 E 4 1/5
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
VAILLY AVIATION HAWKER TYPHOON - RTF
Seller:  TSHARK203
Details:   $4,200.00   |  3/14/2010   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Project BF-109 E 4 1/5
Page: <<   < prev  27 28 [29] 30 31 32 33 34 35 36   next >   >>
Login
RE: Project BF-109 E 4 1/5 - 8/18/2008 8:29 PM
fokke
Score: 100
Last Login: 3/19/2010
Status: offline
Yes Bill that is it
this is my progress
Click to see fullsize image.
Click for fullsize
_____________________________
http://fokkerc.flugmodel.net/
Hide Signatures
(in reply to Evil_Merlin)
       Post #: 701
RE: Project BF-109 E 4 1/5 - 8/22/2008 12:50 PM
fokke
Score: 100
Status: offline
Hi guys ,this is the resolt after my play with the pump
Now I must to make mould of this niches........
Hide Signatures
       Post #: 702
RE: Project BF-109 E 4 1/5 - 8/22/2008 2:32 PM
Evil_Merlin
Score: 120
Last Login: 3/21/2010
Status: online
Holy smokes Fokke, those wheel wells are incredible!
Hide Signatures
(in reply to fokke)
       Post #: 703
RE: Project BF-109 E 4 1/5 - 8/22/2008 3:04 PM
fokke
Score: 100
Status: offline
What is this expression ""Holy smokes "" I don't know it
on this pictures I paint the area what I'll cut when the composite detail is ready
Click for fullsize
Hide Signatures
       Post #: 704
RE: Project BF-109 E 4 1/5 - 8/22/2008 4:23 PM
Evil_Merlin
Score: 120
Status: online
Holy Smokes means like VERY VERY GOOD!
Honestly looking at those detailed wheel wells, I almost couldn't tell it was a model.
You did fantastic!
Hide Signatures
(in reply to fokke)
       Post #: 705
RE: Project BF-109 E 4 1/5 - 8/22/2008 4:55 PM
JIMMYMUGUREL
Score: 100
Last Login: 3/20/2010
Status: online
Hello Rumen
Verry fine details on the wells.
Looks verry realistic.
Your's
JIMMY
Hide Signatures
       Post #: 706
RE: Project BF-109 E 4 1/5 - 8/23/2008 3:15 AM
at-6 texan
Score: 100
Status: offline
Hi Fokke...yes!!!..an very big beauty work!!!.......but how much heavy this?....
http://img208.imageshack.us/my.php?image=2008p38ir2.jpg
Hide Signatures
(in reply to JIMMYMUGUREL)
       Post #: 707
RE: Project BF-109 E 4 1/5 - 8/23/2008 7:31 AM
fokke
Score: 100
Status: offline
Hi at-6 texan,actually I don't care for the weight ,because I will make epoxi mould for this pieces
Hide Signatures
(in reply to at-6 texan)
       Post #: 708
RE: Project BF-109 E 4 1/5 - 8/23/2008 7:08 PM
at-6 texan
Score: 100
Status: offline
ok!!! no problem Fokke!!!!...
Hide Signatures
(in reply to fokke)
       Post #: 709
RE: Project BF-109 E 4 1/5 - 8/24/2008 11:19 AM
fokke
Score: 100
Status: offline
Guys ,I'll stop buiold airplanes and will start play LOTTO,I must to win some money for this .This is some between car and airplane from WWI I whan it
http://www.youtube.com/watch?v=kTYiEkQYhWY&feature=related
http://www.youtube.com/watch?v=SVhluVe2z5Q&feature=related
http://www.youtube.com/watch?v=nndA_NCRpI4&feature=related
< Message edited by fokke -- 8/24/2008 11:30 AM >
Hide Signatures
       Post #: 710
RE: Project BF-109 E 4 1/5 - 8/24/2008 12:40 PM
at-6 texan
Score: 100
Status: offline
hi Fokke..am sorry for this.....but i don't things so an good idea!!!...you can stop the build aereoplane for the moment,but if you play at Lotto i things this is an bad idea....
Hide Signatures
(in reply to fokke)
       Post #: 711
RE: Project BF-109 E 4 1/5 - 8/24/2008 5:36 PM
Slow Low
Score: 100
Last Login: 3/13/2010
Status: offline
I remember seeing a material from Japan that reacted to force. They put a knitted hat on a watermelon and hit it with a hammer - no damage. That might be a good material property for this application. Building cars like airplanes - who'd have thought...
Could the Central Limit Theorem be the root of all things?
Hide Signatures
(in reply to fokke)
       Post #: 712
RE: Project BF-109 E 4 1/5 - 8/25/2008 3:16 PM
fokke
Score: 100
Status: offline
Hi guys ,I can't choose what engine to use for this Emil ,...........I can choice of several engines ,the first is 50 cc gass engine :
Spec.
Displacement: 52cc
Weight: 1584g
Carburettor: (Japanese Walbro) Diaphragm & Butterfly valve.
Prop Speed: 1700 ~ 7800rpm
Max power: Over 3.2kw
Suggested prop: 20x8, 20x10, 22x8 or larger
Ignition: DC-CD (6v)
Mixture: 25:1 to 40:1
Bore/Stroke: Unknown x 31 mm
Size: 170mm long, 215mm wide, 215mm high (Including baffle)
Mount hole: 64mm x 64mm
Price 187 $
His price is good but is toooooo large for my airplane ,the second is this glow engine 32 cc ,he is small ,light the price is the same http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFV82&P=M
who to buy ...?
Click for fullsize
< Message edited by fokke -- 8/25/2008 7:48 PM >
Hide Signatures
(in reply to Slow Low)
       Post #: 713
RE: Project BF-109 E 4 1/5 - 8/25/2008 6:45 PM
Evil_Merlin
Score: 120
Status: online
I've been thinking of giving one of those 52cc engines a try as well Fokke. They are cheap enough that if the motor is junk I am not out a small fortune. The company that makes those engines also makes a 26cc.
Hide Signatures
(in reply to fokke)
       Post #: 714
RE: Project BF-109 E 4 1/5 - 8/25/2008 7:06 PM
Sundance2018
Score: 100
Last Login: 1/4/2010
Status: offline
I'd go with the gas engine myself....and then I'd add the scale exhast stacks from either http://www.jtecrc.com/scalefuntionalexhausts.htm or http://www.keleo-creations.com/
Hide Signatures
(in reply to fokke)
       Post #: 715
RE: Project BF-109 E 4 1/5 - 8/25/2008 8:28 PM
fokke
Score: 100
Status: offline
Thank you Ok guys ,52cc gass ,but the engine is too large,I can't put it in the Emil
The glow engine is small and light ,and is 3.2 HP......... and I think that will be good ,,,,,,,,?
< Message edited by fokke -- 8/25/2008 8:49 PM >
Hide Signatures
(in reply to Sundance2018)
       Post #: 716
RE: Project BF-109 E 4 1/5 - 8/25/2008 9:02 PM
Evil_Merlin
Score: 120
Status: online
You would be better off with a Moki 1.8 or 2.1 Rumen. The Super Tigres are a pain to get perfect in the midranges.
The Moki's are Hungarian motors and are very much stump pullers (meaning plenty of power to do anything you want), and are very easy to tune.
http://www.mokiengine.com/
Hide Signatures
(in reply to fokke)
       Post #: 717
RE: Project BF-109 E 4 1/5 - 8/26/2008 3:18 AM
lz-23
Score: 100
Status: offline
Yep, MOKI are great engines, as long as you can swallow the price tag - 1.8 is running for around $570...
Hide Signatures
       Post #: 718
RE: Project BF-109 E 4 1/5 - 8/26/2008 4:00 AM
Evil_Merlin
Score: 120
Status: online
Glow ones are typically half that price.
Hide Signatures
(in reply to lz-23)
       Post #: 719
RE: Project BF-109 E 4 1/5 - 8/26/2008 5:11 AM
lz-23
Score: 100
Status: offline
Well, I got this prices from nearest dealer of Moki to Bulgaria - Romania. They list 1.8 for 1366 RON which translates to quoted price. I bet they can be found for much less in here.
Hide Signatures
       Post #: 720
RE: Project BF-109 E 4 1/5 - 8/30/2008 5:07 PM
fokke
Score: 100
Status: offline
Hi again guys
I made moulds
and this is my new (old ) Radio-ТИП 10 ПТ-263 from tank T-34/85
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by fokke -- 8/30/2008 6:52 PM >
Hide Signatures
(in reply to lz-23)
       Post #: 721
RE: Project BF-109 E 4 1/5 - 8/30/2008 9:31 PM
JIMMYMUGUREL
Score: 100
Status: online
Hello Rumen
For a fine engine for your Emil, you can do a search for the 35ccm glow from OS Max ( BGX ).
I have heard only good words about it .
It's light, powerfull ,not so expensive and IT'S AN OS MAX !!!
http://shop.lindinger.at/product_info.php?cPath=1130_1149&products_id=12408
Good luck!
JIMMY
Hide Signatures
(in reply to fokke)
       Post #: 722
RE: Project BF-109 E 4 1/5 - 8/30/2008 10:20 PM
wulf190
Score: 100
Status: offline
Hi Rumen,
I agree w/ Jimmy on the OS BGX. I have one in my 190A, my buddy has one in his 190D, and I have a fresh new one waiting to put in my Aeronautica 109E when she's ready . They're very reliable, and it powers even my 26lb 190 pretty well, so it's got some hustle to it.....and it will fit in there pretty well from what I can make out on the plan set that I finally got printed out a couple months back. The build looks great as always.
Mike
Hide Signatures
       Post #: 723
RE: Project BF-109 E 4 1/5 - 8/31/2008 2:48 PM
fokke
Score: 100
Status: offline
I am ready with moulds
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to wulf190)
       Post #: 724
RE: Project BF-109 E 4 1/5 - 8/31/2008 2:50 PM
Evil_Merlin
Score: 120
Status: online
Oh wow Rumen, those came out VERY nice.
Hide Signatures
(in reply to fokke)
       Post #: 725
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.344RCU1
