Joined: 1/7/2002 From: MONTEBELLO, CA, USA Status: offline
They are around 1/5 scale. The prop arc (dia) is around 19" to 20", depending on how your mount them. The pitch can be adjusted by hand.
Its nothing you can't do from what I see here, you just need the right engine prop combination. I have a gear down system, but it is sitting on the shelf on hold. I'm going to try a Moki 2.10 on this 3 blade system.
If you want prop construction details/pics, I'll PM those to you
Joined: 1/11/2004 From: LUGOJ, , ROMANIA Status: offline
Hi Rumen WHAW! Seems to be a 109 club here! Have anny progress on your engine converting? Next wheek-end maiden for biplane. My first Solartex covering/biplane experience ... Your's JIMMY
Hi Jimmy Yes here is like Messer club I don't have progress with my 50cc engine because I think that I can use electrik engine for my plane ,I don't know yet,Maybe I will need brishless motor 3500 W ,I still hesitate.
< Message edited by fokke -- 9/25/2007 9:25:54 AM >
Thanks a lot! I just come back to this project after long dalay. I have to finish the mold for the fuse, and then for wings. Hope to be ready soon, may be month or two. When I have test fly her, will check what is the shipping costs and will let you know what will be. In any case is no problem to make a model or models for USA.
