Q40 mount bolt pattern
Tower Hobbies
Logged in as Guest
  Printable Version
Touchstart Remote Controlled Autostart Engine .61 ASP COLLECTORS !!!!!!!!!!!!!!
Seller:  vidal_felipe
Details:   $499.00   |  7/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> Q40 mount bolt pattern
Page: [1]
Login
Q40 mount bolt pattern - 1/24/2007 7:30:48 PM
ptxman
Status: offline
Regarding the pre-drilled aluminum Q40 motormount with 3 firewall mounting holes on the ring. Can you tell me the hole center dimensions that the bolt pattern is manufactured to? ie, are they a radial/angular dimension from the center of the ring or some nominal horiz/vert distance apart? Im trying to daw up a cad template to match.
       Post #: 1
RE: Q40 mount bolt pattern - 1/24/2007 9:15:21 PM
bob27s
Status: offline
Let me check on the information.....
Bob
_____________________________
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to ptxman)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU1
