Jett 1.5" spinner
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> Jett 1.5" spinner
Page: [1]
Login
Jett 1.5" spinner - 1/24/2007 10:11:35 PM
ptxman
Status: offline
Im looking at replacing the 1.5" Tru-Turn spinners with a Jett 1.5" on my 21 size pylon models because the Jett profile shape works a bit better.
- will the Jett backplate accomodate a 1/4 x 28 tpi crankshaft end?
- is there a typical insert ring that allows different (smaller) crank diameters?
- does the locknut/washer come with the spinner set?
- does one spec the locknut thread at the time of ordering or is it even available in different flavours?
- what is the approx weight?
Thx
       Post #: 1
RE: Jett 1.5" spinner - 1/26/2007 8:17:23 PM
bob27s
Status: offline
quote:
ORIGINAL: ptxman
Thx
The Jett spinners are designed for Jett engines (also available for Nelson shafts). They do not mount using the threaded shaft (like a tru-turn). They replace the prop drive, and engage on the drive collet just as the prop drive does. In this way the spinner backplate becomes an integral part of the engine.
Each spinner includes all of the hardware.
I will have to check on the weight ..... but they end up lighter or equal to a tru-turn equivalent.
What engines are you running? If they are collet mounted drives it might be worth asking if Dub can cut the backplate to fit the locking collet on your engine. jett2006@jettengineering.com
Bob
Click to see fullsize image.
Click for fullsize
< Message edited by bob27s -- 1/26/2007 8:19:37 PM >
_____________________________
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to ptxman)
       Post #: 2
RE: Jett 1.5" spinner - 1/28/2007 3:45:10 PM
ptxman
Status: offline
Thanks for the info. I understand now, the Jett spinner is machined with the same integral washer/spinner backplate like Q40/Q500 engines. The Novarossi (and other 21's we race) is the typical drive washer that fits over a tapered collet. Yes, Ill have to contact Dub with dimesnions & inquire.
Click for fullsize
< Message edited by ptxman -- 1/28/2007 3:46:12 PM >
(in reply to bob27s)
       Post #: 3
RE: Jett 1.5" spinner - 1/29/2007 1:30:47 PM
bob27s
Status: offline
Very good.
Let me know how things work out !
Bob
Bob Brassell
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.406RCU1
