jaejw1
CA, USA Status: offline
quote:
ORIGINAL: darindotson GH 4700, 2S Lipo (Thunder Power 1320 mAh), Quark 33a Pro Car, 19/45 gearing, 70 wt. front, 90 wt. rear, Duratrax Steel CVD's front, Atomic Steel CVD's rear, Atomic ball diffs front and rear, aluminum front knuckles, shocks, and standoffs. Spektrum 2.0 radio and receiver. buy the robinson racing pinion the 19t metric.. just incase you get the 3.2mm shaft.. the motor is a perfect fit.. you will notice a big difference between the two motors.. also is the esc set to lipo high or low.. are you running on dirt or carpet.... what tires?
_____________________________
motor review http://www.rcuniverse.com/forum/m_5643067/tm.htm tire review www.rcuniverse.com/forum/m_6000527/tm.htm
