RE: Redcat Racing Volcano Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Volcano Thread
Page: <<   < prev  58 59 60 61 62 [63] 64 65 66 67   next >   >>
Login
RE: Redcat Racing Volcano Thread - 8/24/2011 11:59 AM
volcanoman01
Score: 100
Last Login: 6/17/2012
Status: offline
 The dog bones wear grooves in the drive cups that inturn bind up and snaps the pins off the dog bones or just swist them off so if u dont replace the drive cups it will just keep breaking dogbones. If your center dif is turning the drive cups then the problem has to be in the front and rear dif I  would take them out clean, greas and  inspect them .
Hide Signatures
(in reply to Kristoffer_E)
       Post #: 1551
RE: Redcat Racing Volcano Thread - 8/25/2011 9:40 PM
chumly222
Score: 100
Last Login: 8/25/2012
Status: offline
To the guy that was having problems with idle screw vibrating loose. either put some blue loc-tite  on the screw or do what i did. I wrapped some teflon tape around it so  it would fit tighter. hope this helps
Hide Signatures
(in reply to volcanoman01)
       Post #: 1552
RE: Redcat Racing Volcano Thread - 8/26/2011 7:14 AM
R0cky23
Score: 100
Last Login: 9/10/2011
Status: offline
ok so today I was doing some tuning to my volcano s30 and found  some parts rattled off.
1hex screw
1bearing
3 different size washers
I have no clue where they could of come from, tried looking at the scamatics and all around the truck,  I am pretty sure it was off the exhaust side
If anyone could help me it would be great!
Hide Signatures
(in reply to chumly222)
       Post #: 1553
RE: Redcat Racing Volcano Thread - 8/26/2011 10:53 AM
volcanoman01
Score: 100
Status: offline
check your clutch bell
Hide Signatures
(in reply to R0cky23)
       Post #: 1554
RE: Redcat Racing Volcano Thread - 8/26/2011 8:09 PM
R0cky23
Score: 100
Status: offline
 Yep thats what it was.  the outer bearing and washers came off
put it all back on and threw some locktight on it
thanks you
Hide Signatures
       Post #: 1555
RE: Redcat Racing Volcano Thread - 8/26/2011 9:44 PM
volcanoman01
Score: 100
Status: offline
ya glad i could help
Hide Signatures
       Post #: 1556
RE: Redcat Racing Volcano Thread - 8/28/2011 12:19 AM
R0cky23
Score: 100
Status: offline
So when I was unboxing my s30 there was a part with the antenna tube, loocks like its a wire attached to a small box, and it has a little needle on the loop,   anybody know what its for?
Hide Signatures
       Post #: 1557
RE: Redcat Racing Volcano Thread - 8/28/2011 2:55 AM
jeffie8696
Score: 120
Last Login: 5/15/2013
Status: offline
That is called the binding plug, it is used to get the radio to talk to the transmitter if they loose touch.
_____________________________
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
       Post #: 1558
RE: Redcat Racing Volcano Thread - 8/28/2011 3:16 AM
R0cky23
Score: 100
Status: offline
oh ok
so how do I install it? I dont see anything about it in the manual
Hide Signatures
(in reply to jeffie8696)
       Post #: 1559
RE: Redcat Racing Volcano Thread - 8/28/2011 3:45 AM
jeffie8696
Score: 120
Status: offline
http://www.youtube.com/watch?v=_q24Jp0iePo&feature=channel_video_title
Hide Signatures
       Post #: 1560
RE: Redcat Racing Volcano Thread - 8/29/2011 12:47 AM
volcanoman01
Score: 100
Status: offline
redcat went to fm signal so just take the loop out of the wire put the wire through the tube tube fits in the hole the wire cam out of you are good to go
Hide Signatures
       Post #: 1561
RE: Redcat Racing Volcano Thread - 8/29/2011 4:52 AM
jeffie8696
Score: 120
Status: offline
If it looks like this , its a bind plug.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1562
RE: Redcat Racing Volcano Thread - 8/29/2011 12:02 PM
volcanoman01
Score: 100
Status: offline
google HOW TO USE A BIND PLUG ON A RC TRUCK should find a vidio on how to use it .I havent had to use one yet. Shouldent need to use it unless you are changing your radio system.
Hide Signatures
       Post #: 1563
RE: Redcat Racing Volcano Thread - 8/29/2011 5:23 PM
jeffie8696
Score: 120
Status: offline
There is a link in post # 1560
Hide Signatures
       Post #: 1564
RE: Redcat Racing Volcano Thread - 8/30/2011 7:17 AM
R0cky23
Score: 100
Status: offline
ah ok all makes since now,  thanks
Hide Signatures
       Post #: 1565
RE: Redcat Racing Volcano Thread - 8/31/2011 4:01 AM
muddroller
Score: 100
Last Login: 10/10/2011
Status: offline
Need help with my EPX pro.  When I get it Charged up and ready to go , it works great for a bit then goes all herky jerky and doesn't budge without a fight.  Help winters almost here and want to play in the dirt soon!
Hide Signatures
(in reply to AllAboutFunHobbies)
       Post #: 1566
RE: Redcat Racing Volcano Thread - 9/2/2011 1:29 AM
R0cky23
Score: 100
Status: offline
So I need to replace the "Steering Assembaly A" (part number-08425)  I have tried to  take it off and i either get the nut on top off and the screw on bottom screw wont come off or vice versa.  So does anybody know how to take one of them off?  I tried looking on the youtube nd couldnt find anything.
Hide Signatures
       Post #: 1567
RE: Redcat Racing Volcano Thread - 9/2/2011 3:20 AM
jeffie8696
Score: 120
Status: offline
The one on the top , the locknut is the tricky one. Once you get it off you can hold the threaded rod and unscrew the bolt from the bottom.
And when you reassemble it dont overtighten the nut, it will bind up the steering.
Hide Signatures
       Post #: 1568
RE: Redcat Racing Volcano Thread - 9/2/2011 2:34 PM
steveelkin
Score: 100
Last Login: 10/1/2011
Status: offline
 I recently purchased a used Volcano SV from a guy.  I'm a full on n00b at this stuff so I'm going to ask some silly questions!  Nonetheless here's what I got.
Engine Leaks fluid like crazy.  So I need to do some sealing. Is there a guide to sealing these VX-18 engines? And where else could I be leaking fluid from?   My hoses are all good and so is the tank. It most definitely is coming from the engine.   I did make my own gasket for the exhaust manifold so that fixed a lot of my problem.
Annnd  when I full out ran this thing into a tree the other day lol I broke one of the teeth off of the Spur Gear.  It looks like this thing had been upgraded to a metal Spur Gear.  I need to replace it.  But it's looking like the only one that I can find is on Redcat's Website. None of the local Hobby R/C places in Indianapolis carry redcat products... Actually I cant even find a redcat dealer within 150 miles.  And there's a considerable price difference between the plastic and metal spur.  Here are my questions regarding this.
Does the plastic one not hold up?
Is there a third party manufacturer of these? Or a subsitute I could use?
Or is there any way to just full out change the transmission for lets say a Traxxas tranny? Or something that I have more access to parts to?
Like I said I'm a newbie at this stuff so please be gentle. I honestly don't know alot about this thing.
Hide Signatures
       Post #: 1569
RE: Redcat Racing Volcano Thread - 9/2/2011 4:41 PM
jeffie8696
Score: 120
Status: offline
Glow engines are a mess, its just a fact of life.
Check all the bolts on the engine , even the ones under the pull starter.
The gears are cheap enough to have a few on hand , I have not been able to break mine yet but they are not too hard to change if you do.
Metal gears are OK but I dont see that much trouble with the plastic.
Hide Signatures
(in reply to steveelkin)
       Post #: 1570
RE: Redcat Racing Volcano Thread - 9/2/2011 5:05 PM
lakesrunner
Score: 100
Last Login: 3/9/2013
Status: offline
 Possibly the engine is leaking around the glow plug, mine was loose once and it can create a mess. Also check the metal washer for the plug.
 Mail ordering parts is sometimes the best deal, I stocked up on some items just in case.  Take your time when setting the mesh, the plastic spur gear in my opinion holds up very well.
Hide Signatures
       Post #: 1571
RE: Redcat Racing Volcano Thread - 9/2/2011 5:10 PM
steveelkin
Score: 100
Status: offline
 Ill check all of the bolts for sure. Ive got the engine out of the rc so it should be cake. What do you mean by setting the mesh?
Hide Signatures
(in reply to lakesrunner)
       Post #: 1572
RE: Redcat Racing Volcano Thread - 9/2/2011 5:21 PM
lakesrunner
Score: 100
Status: offline
When you put your engine back on, the clutch bell will line up with the spur gear. This needs to be set correctly. For instance,  if too tight the spur gear will be shaved bald quickly. It should be easy to push without any grinding sound. There is a video in the Redcat site on how to do this.
Hide Signatures
       Post #: 1573
RE: Redcat Racing Volcano Thread - 9/2/2011 5:34 PM
steveelkin
Score: 100
Status: offline
ahh, I gotcha.   Man after looking around on this forum it looks like there are a lot of cats that aren't too thrilled with the redcat product. What's up with that?
Hide Signatures
       Post #: 1574
RE: Redcat Racing Volcano Thread - 9/3/2011 12:21 AM
jeffie8696
Score: 120
Status: offline
I think the opinion is that they are so inexpensive they cant possibly be any good. I find them a good value.
They are not made to the same standard of craftsmanship as the higher end brands but they also dont cost as much.
I dare anyone to find a better truck for the same price.
Hide Signatures
       Post #: 1575
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.610RCU1
