RE: Redcat Racing Volcano Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Volcano Thread
Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Login
RE: Redcat Racing Volcano Thread - 6/20/2007 5:32 AM
05mustang05
Score: 100
Last Login: 1/18/2008
Status: offline
**UPDATE** Put a new traxxas servo on it, and wow... it will it fly! Everything is running grrrreat and perfect. Thanks again!
Hide Signatures
(in reply to ehroof)
       Post #: 201
RE: Redcat Racing Volcano Thread - 6/20/2007 5:37 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
great bro, have some fun!!!!!!!!!!
_____________________________
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to 05mustang05)
       Post #: 202
RE: Redcat Racing Volcano Thread - 6/21/2007 6:55 AM
05mustang05
Score: 100
Status: offline
I am extremely satisfied with my purchase. I finally got to run it today and take it off some jumps. Man this truck can take a beating and keep right on going!! I flipped it so many times today and a few times I was POSITIVE that I broke something... but nope! Everything is intact. I did however manage to crack the body... no biggie. Oh, and I also cut 2 holes in the body... one for the pull start, and one for the glow plug igniter. I got tired of taking the body off the start it. Overall... GREAT TRUCK, and amazing forum!
Hide Signatures
       Post #: 203
RE: Redcat Racing Volcano Thread - 6/21/2007 7:06 AM
AllAboutFunHobbies
Score: 100
Last Login: 11/10/2011
Status: offline
That's good to hear. Hope you have hours and hours and hours of fun and excitment.
Dealer for..Redcat, Traxxas, Associated, Cen, Racers Edge, RD Logic, Losi, HPI, E-flight, Himoto, Venom, Heli-Max, O.S...etc
Hide Signatures
       Post #: 204
RE: Redcat Racing Volcano Thread - 6/23/2007 12:06 PM
leemunger
Score: 100
Last Login: 4/29/2009
Status: offline
I got my truck off Ebay and broke it in. On 1/2 of the 5th tank during break in I lost all the screws on the pull start. Luckily I found some of the same size screws in some old computer crap and installed them with lock tight. Which gear or gears is everyone stripping? Ive caught 2 rocks in the big plastic gear so far. Also what brand of failsafe do you guys use? I bought one off Ebay and today it would make my throttle servo not respond. I had to cycle the switch on the reciver for it to start working again. After awile of running it like that the truck just took off on me full speed. It wasn't more than 20 feet away when it took off. Luckily it ran into some tall grass and stopped with out crashing into anything.
Hide Signatures
(in reply to AllAboutFunHobbies)
       Post #: 205
RE: Redcat Racing Volcano Thread - 6/23/2007 3:38 PM
ehroof
Score: 105
Status: offline
did you set the failsafe up or just plug it in? it has to be set to set the brake on when it kicks in, some of mine made it go to full throttle until i set it up.
Hide Signatures
(in reply to leemunger)
       Post #: 206
RE: Redcat Racing Volcano Thread - 6/24/2007 1:16 AM
ehroof
Score: 105
Status: offline
i have a couple of those too and they seem to work fine, maybe the battery's are low in the car?
Hide Signatures
       Post #: 207
RE: Redcat Racing Volcano Thread - 6/24/2007 3:17 AM
leemunger
Score: 100
Status: offline
i use recharable batteries in the car and transmitter and always charge them before driving i tried using fresh rayovac but didn't help matters the rechargeable battieries are Energizer 1.2v 2500 mAH http://www.energizer.com/products/rechargeables/sizes.aspx i might try to run it with the fail safe again but if it doesn't work any suggestions on a good one
Hide Signatures
       Post #: 208
RE: Redcat Racing Volcano Thread - 6/24/2007 3:55 AM
ehroof
Score: 105
Status: offline
venom but with out the temp gauge
Hide Signatures
       Post #: 209
RE: Redcat Racing Volcano Thread - 6/24/2007 4:04 AM
leemunger
Score: 100
Status: offline
why with out the temp gauge
Hide Signatures
       Post #: 210
RE: Redcat Racing Volcano Thread - 6/24/2007 4:21 AM
AllAboutFunHobbies
Score: 100
Status: offline
The venom fail safes with the temp gauge has some issues and actual fail more often than not.
Hide Signatures
       Post #: 211
RE: Redcat Racing Volcano Thread - 6/24/2007 11:06 AM
leemunger
Score: 100
Status: offline
alright ill be pricing them out then has anyone had problems with bending shocks i must have bent about 4 shocks already some were the same shock i just straitened them and ran again no biggie is it because the plastic control arms and which gears is everyone having a problem stripping
Hide Signatures
       Post #: 212
RE: Redcat Racing Volcano Thread - 6/24/2007 5:14 PM
jonnzzo
Score: 100
Last Login: 9/15/2007
Status: offline
has anyone ever hear of a metal spur gear for the sv pro? the factory plastic one is number #08013. I have a problem with the clutch slipping I think. the bell gets hot enough to melt the teeth off the plastic gear.
Hide Signatures
       Post #: 213
RE: Redcat Racing Volcano Thread - 6/24/2007 7:08 PM
ehroof
Score: 105
Status: offline
sounds like your shoes are slipping and heating the bell up.
Hide Signatures
(in reply to jonnzzo)
       Post #: 214
RE: Redcat Racing Volcano Thread - 6/24/2007 9:21 PM
jonnzzo
Score: 100
Status: offline
yeah. no ideas on a metal replacment though?.
I am using the factory trans and slipper. I put in tha direct drive trans and 13 tooth bell. the truck would hardly move. no take off at all.and I had to change the location of the throttle linkage in the trottle servo because the engine is so close to the trans.
should that direct drive trans have less take off then the factory trans with the 13 tooth bell that came with the direct drive trans?.
the thing was screaming until the gear melted.
Hide Signatures
       Post #: 215
RE: Redcat Racing Volcano Thread - 6/24/2007 9:24 PM
ehroof
Score: 105
Status: offline
no, there take off and top end should be much better, sounds like a clutch shoe problem, what shoes do you have, aluminum or teflon?
Hide Signatures
       Post #: 216
RE: Redcat Racing Volcano Thread - 6/24/2007 10:04 PM
jonnzzo
Score: 100
Status: offline
factory shoes with t-maxx spring. but I put the factory trans back in and it ran great. didn't even tough the clutch at all. just put the factory trans back in with the new clutch bell and spring. maybe I will try it one more time. since the factory spur geat is now shot. I'd like to see that direct drive work. you say it should have better low end?. it was a real slug. maybe there was another problem that day. of coarse I will have to replace the clutch. isn't there a HPI cluch that works real well in these?
< Message edited by jonnzzo -- 6/24/2007 10:10 PM >
Hide Signatures
       Post #: 217
RE: Redcat Racing Volcano Thread - 6/24/2007 10:22 PM
ehroof
Score: 105
Status: offline
yes, the one for the firestorm, clutch and spring will fit
Hide Signatures
       Post #: 218
RE: Redcat Racing Volcano Thread - 6/27/2007 9:32 PM
05mustang05
Score: 100
Status: offline
I have been doing the "spit test" as ehroof calls it, and after around 5 minutes of running, the engine is overheating. Should I richen then air/fuel, or what's the best way to help it run cooler?
Hide Signatures
       Post #: 219
RE: Redcat Racing Volcano Thread - 6/27/2007 10:39 PM
Chubbysdad
Score: 100
Last Login: 12/22/2009
Status: offline
richen the high speed needle.
Cen truggy, Bigfoot 1/5th, Cen buggy, Mg16, Redcat Earthquake, Redcat Drifter
Hide Signatures
       Post #: 220
RE: Redcat Racing Volcano Thread - 6/30/2007 9:18 PM
05mustang05
Score: 100
Status: offline
Well, I have gone through almost a full gallon of fuel, and havn't broken a thing... until yesterday. I broke an axel on the right front... and completely lost it too. I am still really impressed with how well it has held up. Since it was only the front right, it still runs, but it's only 2 wheel drive now.
Hide Signatures
(in reply to Chubbysdad)
       Post #: 221
RE: Redcat Racing Volcano Thread - 7/1/2007 5:06 AM
Chubbysdad
Score: 100
Status: offline
Next time spray paint the dogbones a bright color incase you lose one again. (easier to find)
Hide Signatures
       Post #: 222
RE: Redcat Racing Volcano Thread - 7/2/2007 4:36 PM
rclynx
Score: 100
Last Login: 7/25/2011
Status: offline
And there real pretty like that too
Custom Cars bring out the stars / Home of the RCLYNX, RC IMPROVEMENT, MOD, SALES & SERVICE Dealer;XTM, CEN, HPI & much more
Hide Signatures
       Post #: 223
RE: Redcat Racing Volcano Thread - 7/20/2007 5:38 AM
retiredcutter
Score: 100
Last Login: 1/19/2008
Status: offline
Ehroof, do you have any idea who might have 12mm to 12mm or 12mm to 14 mm wheel extenders? I want to put some larger tires on my Volcano SV, but cannot seem to find any extenders ! I would prefer 3/4 to 1". Any ideas would be great. Thanks in advance.Pete.
Hide Signatures
(in reply to rclynx)
       Post #: 224
RE: Redcat Racing Volcano Thread - 7/20/2007 5:48 AM
rclynx
Score: 100
Status: offline
Which Volcano do you have?
Hide Signatures
(in reply to retiredcutter)
       Post #: 225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.172RCU1
