RE: Redcat Racing Volcano Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Volcano Thread
Page: <<   < prev  19 20 [21] 22 23 24 25 26 27 28   next >   >>
Login
RE: Redcat Racing Volcano Thread - 1/26/2008 5:32 AM
kuppler
Score: 100
Last Login: 11/8/2011
Status: offline
OMG... yes they are so much Stronger.......Just me but i think its a Good upgrade to do.... you do have to do a few small mods... but other then that.. its SWEET...
< Message edited by kuppler -- 1/26/2008 5:36 AM >
_____________________________
OFFICIAL HIMOTO RACING SUPPORT http://himotoracing.com, http://himotoracingusa.com
Owner of The 805 Hobbies
Hide Signatures
(in reply to pede_187)
       Post #: 501
RE: Redcat Racing Volcano Thread - 1/26/2008 5:52 AM
Macanan
Score: 100
Last Login: 4/10/2011
Status: offline
Your ready to bash now : } just as long as your tires hold up
OFFICIAL HIMOTO RACING SUPPORT - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
Hide Signatures
(in reply to kuppler)
       Post #: 502
RE: Redcat Racing Volcano Thread - 1/26/2008 6:19 AM
kuppler
Score: 100
Status: offline
quote:
ORIGINAL: Macanan
hey now.. heheheh yea well i would bash right now but its RAINING...
maybe later this weekend or week....
Hide Signatures
(in reply to Macanan)
       Post #: 503
RE: Redcat Racing Volcano Thread - 1/26/2008 6:28 AM
truckenizer
Score: 100
Last Login: 2/9/2008
Status: offline
quote:
ORIGINAL: uncle everett
My suspension travel is crushing my dogbones. I've orderd the cvds, but they are too long and also get crushed. I've limited my suspension travel by putting spacers into my suspension, but would like full travel and am wondering if you can recomend shorted cvds? 08046 is the cvd I ordered, but they won't come even close to fitting in the rear.
I don't have a nitro Volcano but I hope some experience with the brushless version can help:
I own an HSP Brontosaurus, it's basically a 1:10 Redcat Volcano EPX.
They are all from the same factory (according to my supplier who claimed he had been there).
I am running 3300kv brushless on 8.4V NiMH.
And I am also bending dogbones during jumps/crashes/cartwheels/half tube stunts etc.
Remedy: adjust the camber of both wheels just a lil more positive. It'll give a little more gap for suspension travel. I also stiffened up the springs with preloaders.
They helped because I bash instead of race.
Other problems:
- Aluminium propeller shaft (long shaft) was twisted broken at the joint between the ball head and the tube shaft. The pin simply spins off due to centrifugal force (i guess).
Damage: it ate a hole in my motor can.
Remedy: replaced the pin and secured it with epoxy.
- Servo saver always comes loose, so I locktite it, same as wheel nuts and motor mouting screws.
- Stock servo is too weak. During full throttle acceleration, steering would go out of alignment. So I changed it with a left over high torque servo from a previous 1:8 truggy. Tighten the servo saver a lil more and steering is smooth....but...servo saver is 'deforming', if that's the right word. - got to find a metal one.
- stock composite chassis is too soft, and bending even with the double deck design. My upper deck aluminum plate had gone all wavy so every now and then I'll have to flatten it.
- spur and pinion worn out fast due to dust/debris. I spray them with silicone dry lube.
- remember to locktite all screws on metals especially the grub screw in drive cups. I had bad experience.
quote:
ORIGINAL: ehroof
did you put a small piece of fuel tubing in each drive cup to take up the slack? you need to leave a little slack but you need to keep it even with 2 pieces of tubing
I don't understand, won't this limit the gap on both ends? I am new to RC and still have lots to learn. Pls help explain.
Thanks & just my 2 cents.
Hide Signatures
(in reply to uncle everett)
       Post #: 504
RE: Redcat Racing Volcano Thread - 1/26/2008 6:31 AM
jrags
Score: 100
Last Login: 2/5/2008
Status: offline
how much do you have to use after run oil
Hide Signatures
(in reply to truckenizer)
       Post #: 505
RE: Redcat Racing Volcano Thread - 1/26/2008 6:34 AM
jrags
Score: 100
Status: offline
another question do tou tune your engine until the engine is clearly not running better then turn the screw 1/8 turn counter clockwise
Hide Signatures
(in reply to jrags)
       Post #: 506
RE: Redcat Racing Volcano Thread - 1/26/2008 7:08 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
quote:
ORIGINAL: ehroof
the reason that you may be bending dogbones is because there is too much "slop" in the dogbone and when you jump and hit the ground they bind and bend, the fuel tubing will take up the "slop" and they wont bind anymore, you can make them tight, there has to be a little play.
< Message edited by ehroof -- 1/26/2008 7:09 AM >
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
       Post #: 507
RE: Redcat Racing Volcano Thread - 1/26/2008 7:10 AM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: jrags
i use it at the end of every running day before i put my rc away
Hide Signatures
(in reply to jrags)
       Post #: 508
RE: Redcat Racing Volcano Thread - 1/26/2008 7:11 AM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: jrags
pretty much, you lean until you dont see any difference then you richen it a little so yes, your right!!!
Hide Signatures
(in reply to jrags)
       Post #: 509
RE: Redcat Racing Volcano Thread - 1/27/2008 6:15 PM
kutzie1793
Score: 100
Last Login: 7/17/2008
Status: offline
heyy does anyone know if trains&lanes in the easton area is open on sundays?
Hide Signatures
(in reply to ehroof)
       Post #: 510
RE: Redcat Racing Volcano Thread - 1/27/2008 6:29 PM
pede_187
Score: 100
Last Login: 8/10/2012
Status: offline
Try calling them at (610)253-8850
Hide Signatures
(in reply to kutzie1793)
       Post #: 511
RE: Redcat Racing Volcano Thread - 1/27/2008 7:50 PM
kutzie1793
Score: 100
Status: offline
sorry my phones dead for a little while. does anyone know if they are or not?
Hide Signatures
       Post #: 512
RE: Redcat Racing Volcano Thread - 1/27/2008 8:20 PM
jaybird84
Score: 100
Last Login: 6/3/2008
Status: offline
i have a volcano sv truck and was planing on changing the remote control because i herd it was junk what should i be looking for and does anyone have a suggestion on what to get?
Hide Signatures
       Post #: 513
RE: Redcat Racing Volcano Thread - 1/27/2008 8:28 PM
jaybird84
Score: 100
Status: offline
im also have the hardest time getting my volcano gas truck running right i thouhgt i knew what i was doing but the fine tuning is killing me can any one help? is there a way to set it back to factory to just get it back to normal i went to extreme on ajustments.
Hide Signatures
       Post #: 514
RE: Redcat Racing Volcano Thread - 1/27/2008 10:11 PM
ben283
Score: 100
Last Login: 6/24/2008
Status: offline
my pullstart will not recoil
please help
Hide Signatures
(in reply to jaybird84)
       Post #: 515
RE: Redcat Racing Volcano Thread - 1/27/2008 10:20 PM
kuppler
Score: 100
Status: offline
the spring inside might of popped..
take the pull start off and take a look. its not hard to reset. almost anyone can do it..
Hide Signatures
(in reply to ben283)
       Post #: 516
RE: Redcat Racing Volcano Thread - 1/28/2008 10:12 AM
Redharris
Score: 105
Last Login: 12/9/2012
Status: offline
quote:
ORIGINAL: kuppler
Just be aware that it may Pop out (SPROINNNG!) when you disassemble it. But it s not too hard to put back together if you have strong fingers.
< Message edited by Redharris -- 1/28/2008 10:13 AM >
Hide Signatures
       Post #: 517
RE: Redcat Racing Volcano Thread - 1/28/2008 3:36 PM
jaybird84
Score: 100
Status: offline
Hide Signatures
(in reply to Redharris)
       Post #: 518
RE: Redcat Racing Volcano Thread - 1/28/2008 10:17 PM
ehroof
Score: 105
Status: offline
put the high needle to 2 1/2 out from closed and the low needle flush with the collar around the set screw. this setting should get you going then you can tune from there, here are a couple of tuning video's.
http://youtube.com/watch?v=oSmMzpZM_As
http://youtube.com/watch?v=BJFsJAxNoRg
Hide Signatures
       Post #: 519
RE: Redcat Racing Volcano Thread - 1/28/2008 11:21 PM
nitrozach54
Score: 100
Last Login: 3/11/2009
Status: offline
i have the sv
can some 1 please show me with pictures and directions of how to set up my my throttle and brake servo?
im having trouble of where to set the arms and all
please help so i can run my truck
Evader ST - Evader EXB - Evader ST PRO
Its all fun and games until someone looses a bodyclip.
Hide Signatures
       Post #: 520
RE: Redcat Racing Volcano Thread - 1/28/2008 11:24 PM
kutzie1793
Score: 100
Status: offline
has anyone ever taken the exhaust off, taken it apart, and found that baffle piece in the front half? does it hurt anything to take that out? and whats it sound like without it?
Hide Signatures
(in reply to nitrozach54)
       Post #: 521
RE: Redcat Racing Volcano Thread - 1/28/2008 11:27 PM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: kutzie1793
you can take it out, it will sound a little louder. you wont hurt anything, you may just need to retune the engine.
Hide Signatures
       Post #: 522
RE: Redcat Racing Volcano Thread - 1/28/2008 11:30 PM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: nitrozach54
i have the sv
basically you put the transmitter and car on, put the trim knobs on the transmitter to the center, try to put the throttle arm on the throttle servo so the carb is 1mm open and the brake is not on or as close as possible, put the arm on the steering servo so the wheels are as close to straight as possible then trim them the rest of the way with the trim knobs. is this what you wanted to know? there is no real set way, if you need, check out the pictures on the redcatracing.com website at the volcano to get a basic idea of how they go.
Hide Signatures
       Post #: 523
RE: Redcat Racing Volcano Thread - 1/28/2008 11:32 PM
nitrozach54
Score: 100
Status: offline
thanks ehroof
ill do it right now
Hide Signatures
       Post #: 524
RE: Redcat Racing Volcano Thread - 1/29/2008 12:08 AM
ehroof
Score: 105
Status: offline
maybe this will help you a little
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 525
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.984RCU1
