RE: Redcat Racing Volcano Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Volcano Thread
Page: <<   < prev  20 21 [22] 23 24 25 26 27 28 29   next >   >>
Login
RE: Redcat Racing Volcano Thread - 1/29/2008 2:24 AM
kutzie1793
Score: 100
Last Login: 7/17/2008
Status: offline
louder you say? out it comes!
Hide Signatures
(in reply to ehroof)
       Post #: 526
RE: Redcat Racing Volcano Thread - 1/29/2008 2:38 AM
jaybird84
Score: 100
Last Login: 6/3/2008
Status: offline
i have a volcano sv. the linkage that goes into the gear box broke. i can pull the rod completely out. the engine starts and when you squeeze the throttle it revs but the wheels dont turn. i need some suggestions on what to do.
Hide Signatures
(in reply to kutzie1793)
       Post #: 527
RE: Redcat Racing Volcano Thread - 1/29/2008 2:44 AM
nitrozach54
Score: 100
Last Login: 3/11/2009
Status: offline
what do yall think of the electric starter?
my pull is broken and electric is $7 more
http://cgi.ebay.com/Power-Starter-for-RC-Nitro-Car-Buggy-Trucks_W0QQitemZ150180515156QQihZ005QQcategoryZ1200QQtcZphotoQQcmdZViewItem
_____________________________
Evader ST - Evader EXB - Evader ST PRO
Its all fun and games until someone looses a bodyclip.
Hide Signatures
       Post #: 528
RE: Redcat Racing Volcano Thread - 1/29/2008 3:11 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
quote:
ORIGINAL: jaybird84
do you mean the brake linkage? if so, there is a small grub screw that hold it in place, right on top inside the chrome piece above it. check the grub screws in the drive cups (cups that hold the dogbones). also make sure the slipper clutch is tight on the trans, its the nut behind the spur gear.
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to jaybird84)
       Post #: 529
RE: Redcat Racing Volcano Thread - 1/29/2008 3:13 AM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: nitrozach54
seems like a good deal, i dont like rotostarts, you need that charged battery all the time, not saying its not good, i used to love it on my hpi till i showed up to the track with a dead battery, within a 1/2 hour i had a pull start on it and a starter box.
Hide Signatures
(in reply to nitrozach54)
       Post #: 530
RE: Redcat Racing Volcano Thread - 1/29/2008 3:34 AM
jaybird84
Score: 100
Status: offline
its the chrome piece that goes into were all the gears are that is also attach to the throttle the chrome rod now can be pulled aot easly so do i need to take all that apart and if so is there an easyer way then taking the whole car apart?
Hide Signatures
       Post #: 531
RE: Redcat Racing Volcano Thread - 1/29/2008 3:52 AM
ehroof
Score: 105
Status: offline
thats the brake rod, there is a pad behind the brake that the flat part of that rod sits one. should stay in place if installed right.
Hide Signatures
       Post #: 532
RE: Redcat Racing Volcano Thread - 1/29/2008 4:14 AM
nitrozach54
Score: 100
Status: offline
i had my first run in the snow and first fun in 6 monthes!
any suggestions of after run in the snow
i just take the upper plate off and take all the snow off that i can and put it next to the furnace
any ofther tips to prevent anything bad?
Hide Signatures
       Post #: 533
RE: Redcat Racing Volcano Thread - 1/29/2008 4:18 AM
nitrozach54
Score: 100
Status: offline
god ehroof i was just looking through your gallery
what do you do for work to have that many R/Cs????!!!!
I was like....
Hide Signatures
       Post #: 534
RE: Redcat Racing Volcano Thread - 1/29/2008 5:14 AM
ehroof
Score: 105
Status: offline
spray the whole rc down with wd40 before you run it and after when its dry, blow off the excess if you have a compressor or can of air.
Hide Signatures
       Post #: 535
RE: Redcat Racing Volcano Thread - 1/29/2008 5:15 AM
ehroof
Score: 105
Status: offline
I was like....
lol and thats not all of them. I am a GC in NYC and the 5 boro's but i am looking for something else to do soon, dont know what yet. lol
Hide Signatures
       Post #: 536
RE: Redcat Racing Volcano Thread - 1/29/2008 7:24 PM
Mandoza
Score: 100
Last Login: 12/20/2009
Status: offline
quote:
ORIGINAL: ehroof
I can move my spur gear left and right, there is a space of about an 1/8" between the nut and the side of the case. I assume the spur gear shouldn't slide side to side. I tried to loosen the nut with a wrench but couldn't hold the spur gear. What is the easiest way to adjust this? Do i have to remove the transmission?
Hide Signatures
       Post #: 537
RE: Redcat Racing Volcano Thread - 1/29/2008 9:57 PM
ehroof
Score: 105
Status: offline
you need to tighten it, not loosen it then, just hold the gear with one finger and use a wrench and tighten the slipper nut.
Hide Signatures
(in reply to Mandoza)
       Post #: 538
RE: Redcat Racing Volcano Thread - 1/30/2008 12:02 AM
nitrozach54
Score: 100
Status: offline
does any 1 have an electric starter for volcano?
Hide Signatures
       Post #: 539
RE: Redcat Racing Volcano Thread - 1/30/2008 12:06 AM
ehroof
Score: 105
Status: offline
do you mean the wand or the backplate and do you mean for you to buy?
Hide Signatures
       Post #: 540
RE: Redcat Racing Volcano Thread - 1/30/2008 12:59 AM
nitrozach54
Score: 100
Status: offline
I just wanted to know if any 1 had any experence with the same system
whats a GC?
and how did you stumble upon my video?
http://www.youtube.com/watch?v=Khmm2aOQRc8
Hide Signatures
       Post #: 541
RE: Redcat Racing Volcano Thread - 1/30/2008 1:03 AM
nitrozach54
Score: 100
Status: offline
http://www.redcatracing.com/itemdetail_part.asp?partno=08018
http://www.redcatracing.com/itemdetail_part.asp?partno=08022
will these replace my front and rear drive shaft and drive cups?
Parts below
http://www.redcatracing.com/itemdetail_part.asp?partno=02016
http://www.redcatracing.com/itemdetail_part.asp?partno=08061
http://www.redcatracing.com/itemdetail_part.asp?partno=08060
because one fell off today and i couldnt find it!
< Message edited by nitrozach54 -- 1/30/2008 4:02 AM >
Hide Signatures
       Post #: 542
RE: Redcat Racing Volcano Thread - 1/30/2008 1:46 AM
ehroof
Score: 105
Status: offline
whats a GC?
i had the rotostart on my hpi's and took it off once i had no charged battery and couldnt race
GC=General Contractor
Hide Signatures
       Post #: 543
RE: Redcat Racing Volcano Thread - 1/30/2008 4:19 AM
jaybird84
Score: 100
Status: offline
it does stay in place but i tore the gasket and dont know where to get one any ideas?
Hide Signatures
       Post #: 544
RE: Redcat Racing Volcano Thread - 1/30/2008 4:35 AM
ehroof
Score: 105
Status: offline
what gasket?
Hide Signatures
       Post #: 545
RE: Redcat Racing Volcano Thread - 1/30/2008 4:52 AM
nitrozach54
Score: 100
Status: offline
Parts below
PLEASE help?
Hide Signatures
       Post #: 546
RE: Redcat Racing Volcano Thread - 1/30/2008 4:56 AM
ehroof
Score: 105
Status: offline
Parts below
PLEASE help?
ok
the 2 shafts on the top are for the transmission, the gears go on them
02016 are for the front and rear diff,
02003 goes from the trans to the rear diff
06006 goes from the trans to the front diff
Hide Signatures
       Post #: 547
RE: Redcat Racing Volcano Thread - 1/30/2008 5:07 AM
jaybird84
Score: 100
Status: offline
i need the gasket called the LINING CHIP (02044) WHERE CAN I GET THAT FOR THE volcano sv
Hide Signatures
       Post #: 548
RE: Redcat Racing Volcano Thread - 1/30/2008 5:09 AM
jaybird84
Score: 100
Status: offline
i need the gasket called the LINING CHIP (02044) WHERE CAN I GET THAT from. for THE volcano sv
Hide Signatures
       Post #: 549
RE: Redcat Racing Volcano Thread - 1/30/2008 5:40 AM
ehroof
Score: 105
Status: offline
http://www.redcatracing.com/itemdetail_part.asp?partno=02044
http://www.clermontmotorsports.com/servlet/the-31/Brake-Disc-2PCS/Detail
Hide Signatures
       Post #: 550
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.328RCU1
