RE: Redcat Racing Volcano Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Volcano Thread
Page: <<   < prev  40 41 [42] 43 44 45 46 47 48 49   next >   >>
Login
RE: Redcat Racing Volcano Thread - 4/1/2008 3:58 AM
racemaxx24
Score: 100
Last Login: 2/15/2011
Status: offline
Did u hit the trim for the throttle servo? That could cause your brakes to lock the wheels
Hide Signatures
(in reply to perhamrocks)
       Post #: 1026
RE: Redcat Racing Volcano Thread - 4/1/2008 4:08 AM
perhamrocks
Score: 100
Last Login: 2/9/2011
Status: offline
no, and i just unatached the break linkage, and it's still, locked up, and the brake is set to off
Hide Signatures
(in reply to racemaxx24)
       Post #: 1027
RE: Redcat Racing Volcano Thread - 4/1/2008 4:11 AM
racemaxx24
Score: 100
Status: offline
So the differentils are fine right. Are there any gears stripped in the gearbox?
Hide Signatures
       Post #: 1028
RE: Redcat Racing Volcano Thread - 4/1/2008 4:14 AM
perhamrocks
Score: 100
Status: offline
yes, the diffs are fine, and there are no stripped gears, i just installed my new direct drive, got it meshed good, took it out for a little drive, and now i'm here.
Hide Signatures
       Post #: 1029
RE: Redcat Racing Volcano Thread - 4/1/2008 4:16 AM
racemaxx24
Score: 100
Status: offline
Wel IDK. U will have to wait for ehroof to reply. Sorry
Hide Signatures
       Post #: 1030
RE: Redcat Racing Volcano Thread - 4/1/2008 5:56 AM
mtkgmc
Score: 100
Last Login: 9/23/2012
Status: offline
hi everyone im new to redcats and nitros.
i have gotten a question i have a stock volcano sv and was wondering why my rear differential would blow up. i have already ordered a complete one to replace it i was just wondering why it would die so quickly. The four little spider gears inside of it were taken out in about 10 pieces. Also what i could do not to blow up the next one??
Hide Signatures
       Post #: 1031
RE: Redcat Racing Volcano Thread - 4/1/2008 6:11 AM
perhamrocks
Score: 100
Status: offline
make sure they are all meshed, which they should have been, and make sure there is grease in their, whch there should be when you buy it.
i used all purpose lithium grease, but that helps to stop the diffs from working and gives me more power off the line. you may want some thinner grease, or even diff oil, but i thought eroof said to stick to grease on the volcano.
< Message edited by perhamrocks -- 4/1/2008 6:12 AM >
Hide Signatures
(in reply to mtkgmc)
       Post #: 1032
RE: Redcat Racing Volcano Thread - 4/1/2008 7:17 AM
mtkgmc
Score: 100
Status: offline
hey thanks yeah i know all that from the real size. i was kind of more curious on why it failed. to much beating maybe i dont know front wheel drive is kind of cool for burnouts haa
Hide Signatures
       Post #: 1033
RE: Redcat Racing Volcano Thread - 4/1/2008 7:48 AM
Redharris
Score: 105
Last Login: 12/9/2012
Status: offline
quote:
ORIGINAL: perhamrocks
My volcano just locked up, The car wont go forward the flywheel is spinning, and it looks like the cluthch is trying to engage but it wont. If i try to roll the car on the ground it wont move because the wheels are locked up, but i can spin one wheel at a time and the opposite wheel will go the other direction like usual because of the diffs. PLEASE HELP This was all caused from landing on the rear wheels from a small jump
Sounds like your Transmission is Seized for some reason.
Put the truck on a block of wood (so that the tires are not touching the ground) and Manually turn the Spur gear.
All four tires should spin(if you can turn the gear fast enough).
If the spur gear wont move, or is VERY hard to move, then there is probably something STICKING in your tranny assembly.
Maybe a bad bearing, stripped gear, broken gear tooth, or just a rock Jamming the geartrain.
You Might remove the Engine and tear down the Clutch assembly to inspect it too.
_____________________________
OFFICIAL HIMOTO RACING SUPPORT - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
Hide Signatures
       Post #: 1034
RE: Redcat Racing Volcano Thread - 4/1/2008 5:48 PM
aaeandcee
Score: 100
Last Login: 5/13/2009
Status: offline
Hi-
I'm looking to replace my bronze bushings in the Front/Rear Hub Carrier. I saw the bronze replacement parts, but wanted to double check if these were the same things..only ball bearings instead of bronze.
Part Number: 02139
Part Number: 02138
Thanks!
Hide Signatures
(in reply to Macanan)
       Post #: 1035
RE: Redcat Racing Volcano Thread - 4/1/2008 9:16 PM
bkfamily1
Score: 100
Last Login: 5/17/2013
Status: offline
aaeandcee,
Yes, those are the ball bearing replacements for the brass bushings. The numbers are the size in millimeters. The inner (closer to the diff) bearings are 10x15x4 (10mm inner diameter, 15mm outer diameter, 4mm thick). The outers (closer to the tires) are 5x10x4. The ball bearings are a nice improvement over the bushings. However, you may want to take a look at some other ball bearing options. It is not clear from the pics of the 02139 (outers) on Redcat's site, but it is clear for the 02138 (inners) that those bearings are shielded, not sealed. That means that the guts of the bearings (the balls themselves) are isolated from dirt and such with a metal "washer" on the sides of the bearings between the inner and outer races. While that provides a decent amount of protection, dirt and moisture can still get in. A sealed bearing has a rubber seal instead of the metal shield, and they will typically last longer in dirty and wet applications.
Clermont carries Boca bearings which are pretty well known. The B 10x15x4 and B 5x10x4 are black sealed. If you want to stay with shielded, he also has economy bearings which are shielded and similar to Redcat's . They are E 10x15x4 and E 5x10x4.
http://www.clermontmotorsports.com/servlet/the-Boca-Bearings/searchpath/85193/start/1/total/60/Categories
I also found Team FastEddie who has them for less, but I am not sure what brand. I got mine from Eddie, and I got them right away. They are running well, but they have not been in for long.
http://www.teamfasteddy.com/index.php?main_page=index&cPath=203_216
Good luck!
September 11, 2001
Never Forget
Hide Signatures
(in reply to aaeandcee)
       Post #: 1036
RE: Redcat Racing Volcano Thread - 4/1/2008 9:30 PM
aaeandcee
Score: 100
Status: offline
bkfamily1,
Thank you! That is an awesome response! It is just a buggy my 3 year old and I play with (I have the Nitro toy for myself), but I still want it to perform well.
Hide Signatures
(in reply to bkfamily1)
       Post #: 1037
RE: Redcat Racing Volcano Thread - 4/6/2008 6:10 PM
race_addict
Score: 100
Last Login: 8/10/2009
Status: offline
Hey guys i have a quick question do any of you know what the part number or where i can get a pullstart for the vx.18? I have ordered one before from all about fun hobbies but i couldnt find it on there today or clermont hobbies either. I have bad luck with these pull starts lol on my third... and i dont really pull em hard. It would be nice it they had rotostart for these engines. I got all my stuff i needed to run from hobby shop, its the first nice day in like a week and first pull it breaks. That can ruin some fun. Ive already fixed the pullstart like 10 times and its not liking it at all now.
Hide Signatures
       Post #: 1038
RE: Redcat Racing Volcano Thread - 4/6/2008 7:12 PM
bkfamily1
Score: 100
Status: offline
raceaddict,
The following link will take you to search results from the Redcat site. I searched for "start" in the volcano parts. You will see 3 different pull starts depending on your specific engine. Also, you will see the backplates for electric starting and a wand for using a drill to start the engine. All of them are in stock at Redcat, although do not expect lightning speed on your order.
http://www.redcatracing.com/parts_searchresult.asp?basepartno=VOLCANO+SV&q=start
You can also email Dennis at Clermont. Even though ti does not show in his on line catalog, he often has things that do not. The following has his email and phone number.
http://www.clermontmotorsports.com/servlet/Service
I would also try himotoracingusa.com. It is recently started by Ed/ehroof, and the Himoto parts are interchangeable with Redcats. The following has his email and phone.
http://store02.prostores.com/servlet/himotoracingusacom/the-template/about/Page
You could also pm Ed or Dennis if you see them online in the forum.
Finally, I am curious how they keep breaking. Although an electric would eliminate that issue, the pullstart is nice since it is always ready - no charging, no drill to lug around, etc. What is breaking? The string?
Good luck!
September 11, 2001
Never Forget
Hide Signatures
(in reply to race_addict)
       Post #: 1039
RE: Redcat Racing Volcano Thread - 4/6/2008 9:44 PM
perhamrocks
Score: 100
Status: offline
quote:
ORIGINAL: race_addict
get this if you have a cordless drill http://www.redcatracing.com/itemdetail_part.asp?partno=11011H12
or this if you dont http://www.redcatracing.com/itemdetail_part.asp?partno=70111t
if you have a cordless drill this is cheaper, and more reliable
Hide Signatures
       Post #: 1040
RE: Redcat Racing Volcano Thread - 4/6/2008 10:21 PM
numskull223
Score: 100
Last Login: 3/16/2009
Status: offline
What would you use to stick in the drill to crank it? I hate a pull start.
Hide Signatures
       Post #: 1041
RE: Redcat Racing Volcano Thread - 4/6/2008 11:22 PM
Redharris
Score: 105
Status: offline
If you decide to go with a roto start(or buy another pullstart), be aware that Redcat shipped the VX.18 with TWO different sized back plates that had DIFFERENT screw patterns.
There is the LARGE one with a 1 1/2 inch pattern and a SMALL one with a 1 inch pattern. I have 2 Volcanos, and they have different backplates and pullstarts.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Redharris -- 4/7/2008 4:23 AM >
Hide Signatures
       Post #: 1042
RE: Redcat Racing Volcano Thread - 4/7/2008 4:06 AM
perhamrocks
Score: 100
Status: offline
quote:
ORIGINAL: numskull223
i'm sure you'll find something that will fit, and if not just jam this into ur drill http://www.redcatracing.com/itemdetail_part.asp?partno=11003
Hide Signatures
(in reply to numskull223)
       Post #: 1043
RE: Redcat Racing Volcano Thread - 4/8/2008 12:30 AM
lucasaf
Score: 100
Last Login: 4/11/2008
Status: offline
Hi guys, i'm back...i receive my volcano parts today and i having a big problem to mount the front arm.
Some one can post pictures of the front complete?
With details?
Please.
tks
Hide Signatures
       Post #: 1044
RE: Redcat Racing Volcano Thread - 4/15/2008 8:44 PM
aaeandcee
Score: 100
Status: offline
Can someone recommend a replacement driveshaft. I''ve got the electric motor and the driveshaft keeps breaking. The one that keeping breaking is the hollow tube aluminum one, I''m looking for a solid one. Thanks!
Hide Signatures
(in reply to lucasaf)
       Post #: 1045
RE: Redcat Racing Volcano Thread - 4/16/2008 5:37 AM
V-dog
Score: 100
Last Login: 5/13/2008
Status: offline
Hey guyz havent talked in a while Today i was runnin my volcano ( well trying to ) and the wheels are spinning without pressing the throttle/brake. We adjusted the high speed and low speed needle but it still keeps going. Plus i adjusted my throttle (idle) needle both ways nothin. Maybe if someone could show me a picture of the throttle control thing on your controller in the right position i could work from that. Cuz Idk what to do im about to pour gasoline all over it and throw a match.
Should i jus find a local hobby shop that does tune ups? if so how much does that range from?
< Message edited by V-dog -- 4/16/2008 5:45 AM >
(\_/)
(o.o)
Hide Signatures
       Post #: 1046
RE: Redcat Racing Volcano Thread - 4/16/2008 5:42 AM
Swamp3r
Score: 100
Last Login: 4/30/2010
Status: offline
Just a thought but have you checked to see if the carb is seized, you could try and move it manually to see if your getting the 1mm gap inside. Maybe the servo horn slipped. Thats about all I can think of if you adjusted the idle.
Edit btw have you been using after run oil. I don`t know how long your truck sat is the reason I ask.
< Message edited by Swamp3r -- 4/16/2008 9:03 AM >
Hide Signatures
(in reply to V-dog)
       Post #: 1047
RE: Redcat Racing Volcano Thread - 4/16/2008 8:48 AM
Boxhead from MN
Score: 100
Last Login: 12/29/2012
Status: offline
V-dog-
May be a broken clutch spring. Springs keep the clutch shoes from engaging.
Try putting the rc on a block of wood with tires off the ground. Start it and use the brake.
If car dies, it''s probably a broken spring.
< Message edited by Boxhead from MN -- 4/16/2008 8:50 AM >
I came into this world with nothing and I plan on having most of it left when I leave.
Hide Signatures
(in reply to V-dog)
       Post #: 1048
RE: Redcat Racing Volcano Thread - 4/16/2008 11:44 PM
nitrozach54
Score: 100
Last Login: 3/11/2009
Status: offline
i took the clutchbell off my volcano with VX .18
i dont remember how it was so can someone show me what order the stuff goes on the spindle thing?
i have 3 bearings, 2 big , 1 medium, and one small washers.
pictures would be great
Evader ST - Evader EXB - Evader ST PRO
Its all fun and games until someone looses a bodyclip.
Hide Signatures
(in reply to Boxhead from MN)
       Post #: 1049
RE: Redcat Racing Volcano Thread - 4/16/2008 11:53 PM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
here you go bro:
Click for fullsize
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to nitrozach54)
       Post #: 1050
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.078RCU1
