RE: Redcat Racing Volcano Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Volcano Thread
Page: <<   < prev  45 46 [47] 48 49 50 51 52 53 54   next >   >>
Login
RE: Redcat Racing Volcano Thread - 5/8/2008 2:47 PM
kutzie1793
Last Login: 7/17/2008
Status: offline
heyy i have a volcano sv. i broke a front axle, so i pulled out the other one so its just rear wheel drive. is this bad for it?? what should i take out to make it run better as rear wheel drive? and also, my trucks pretty stock. where can i get an engine just big enough to pull a wheelie (used, very cheap[like under 30bucks])??
Hide Signatures
(in reply to Gelo_USA)
       Post #: 1151
RE: Redcat Racing Volcano Thread - 5/9/2008 12:50 AM
kutzie1793
Status: offline
heyy its me again. i completely stripped the gear thats driven directly from the clutchbell. is this common? can i get one cheaper than on redcat's website? and can i get a metal one?
Hide Signatures
(in reply to kutzie1793)
       Post #: 1152
RE: Redcat Racing Volcano Thread - 5/9/2008 1:51 AM
ranger4x4
Last Login: 9/17/2010
Status: offline
that gear is called a spur gear, and no metal spur gears are a bad idea for them. they are plastic so that part fails if there is a problem and to save the rest of the driveline. you could look at allaboutfunhobbies or send an email or pm himotoracingusa. he might be able to help you out as well.
_____________________________
mxt 2-s mega e mt10 viper
Hide Signatures
       Post #: 1153
RE: Redcat Racing Volcano Thread - 5/9/2008 5:26 AM
RACINFORFUN
Last Login: 5/12/2008
Status: offline
I OWN A VOLCANO SV HOW DO YOU TAKE THE STEERING HUB OFF?
Hide Signatures
(in reply to Chubbysdad)
       Post #: 1154
RE: Redcat Racing Volcano Thread - 5/10/2008 12:12 AM
RCToysNh
Last Login: 6/26/2011
Status: offline
You want part number 08013
We have them on our site.
Always Best prices and Cheap S/H at RCToysNH, NHwoods, ToystoreNH, VP Ent. Inc.
RedCat Traxxas DuraTrax AE
Hide Signatures
       Post #: 1155
RE: Redcat Racing Volcano Thread - 5/10/2008 1:08 AM
Gelo_USA
Last Login: 7/30/2009
Status: offline
is the rear differential the same as the front?? what are all the parts tht build a full differential?? I want to keep a whole one extra cause my front one seems to be the CLICLKING problem I am having... so I think its about to go soon.... I want to have an extra for when it breaks....
EdIT** also... what kind of oil/grease do I use inside the differential when rebuilding it...
< Message edited by Gelo_USA -- 5/10/2008 1:09 AM >
Hide Signatures
(in reply to RCToysNh)
       Post #: 1156
RE: Redcat Racing Volcano Thread - 5/10/2008 8:08 AM
numskull223
Last Login: 3/16/2009
Status: offline
Yes the same. It catually looks just like a real life rearend. It has a ring gear and a pionion gear. Check to see if the c clip as came off the Pionion gear, could cause clicking souund.
I have noticed that when I apply the brakes, you can hear a lil clicking sound, but I knoe its the brakes, but I havent had the brakes lock up by there self. Good Luk.
Hide Signatures
       Post #: 1157
RE: Redcat Racing Volcano Thread - 5/10/2008 5:26 PM
Gelo_USA
Status: offline
also when I rev it full thortle from stopped I hear the click too... I will open up the differential todayy.. see if I find anything wrong....
Hide Signatures
(in reply to numskull223)
       Post #: 1158
RE: Redcat Racing Volcano Thread - 5/10/2008 7:38 PM
Gelo_USA
Status: offline
diff is all ok... all metal gears.. I thought they were plastic... my problem is on the trans then for sure.. I got an spur gear kit.. I will try replacing the smaller metal gear cause the big one is fine the small is a little worn.. not too much but might be it.....
Hide Signatures
       Post #: 1159
RE: Redcat Racing Volcano Thread - 5/11/2008 3:24 AM
Gelo_USA
Status: offline
man its frustrating... I've taken the whole truck apart everysingle screw.... I cant find anything wrong.... today I finally found the sweet spot on tunning truck is running like hell... almost doing wheelies on grass but now its clicking way more when I rev it and when I brake... I tried braking and reving it to 100% for a while just full speed stop full speed stop but the damn part thts cliclking WONT BREAK ... I just want it to break now so I can see it and replace it... all differential gears are fine... clutch bell has no wear spur gear has no wear... I am starting to notice tht when it clicks I loose performance.... and when braking and it clicks its like the car runs loose for a sec of the click and locks again...I am already annoying everyone here I knw but this is suppost to be the official redcat racing support and I cant get any answer from them.......
I knw I am not doing anythign wrong... and there is no broken or stripped gears... now I m starting to regret saving 100$ cause I would've been better of paying more and not having this S#!T problem and no support
srry guys its nothing against u guys in the forum... I m pissed at redcat cause I email them and NOTHING.. I post here and NOTHING... its just frustrating....
Hide Signatures
       Post #: 1160
RE: Redcat Racing Volcano Thread - 5/11/2008 4:11 AM
Boxhead from MN
Last Login: 12/29/2012
Status: offline
Have you checked that the set screws on the drive cups are set on the flat spot? Just a suggestion.
maybe the linkage for the brake is binding? Had mine out yesterday and didn't hear a clicking sound.
Hope you find the problem.
Chris
I came into this world with nothing and I plan on having most of it left when I leave.
Hide Signatures
       Post #: 1161
RE: Redcat Racing Volcano Thread - 5/11/2008 4:17 AM
Gelo_USA
Status: offline
what are set screws exactly... I took it all aprt but dnt knw what those are.... what cups are u talking about?? the ones on the wheels.. transmission or diferentials???
< Message edited by Gelo_USA -- 5/11/2008 4:38 AM >
Hide Signatures
(in reply to Boxhead from MN)
       Post #: 1162
RE: Redcat Racing Volcano Thread - 5/11/2008 8:01 AM
chevyderek72
Last Login: 11/8/2010
Status: offline
the drive cups are what the dog bones go into, there is a grub screw that tightens on a flat spot ot hold it
Redcat Racing - Dunerunner, Hurricane XP, Aftershock 8e, Volcano, Volcano epx, Vortex epx, Tremor 18e pro
Its me ti**ta
Hide Signatures
       Post #: 1163
RE: Redcat Racing Volcano Thread - 5/11/2008 8:13 AM
Gelo_USA
Status: offline
the screw is inside the cup?
Hide Signatures
(in reply to chevyderek72)
       Post #: 1164
RE: Redcat Racing Volcano Thread - 5/11/2008 8:32 AM
numskull223
Status: offline
Check ur servos, I had one clicking on mine tonight, when I was adjusting the throttle, It was constantly clicking as long as I held the throttle down.
also, set the truck off the ground and crank it, run it, that way you can investigate the sound, while its running.
< Message edited by numskull223 -- 5/11/2008 8:34 AM >
Hide Signatures
       Post #: 1165
RE: Redcat Racing Volcano Thread - 5/11/2008 8:36 AM
numskull223
Status: offline
quote:
ORIGINAL: kutzie1793
2.5r traxxas engine or 3.3
Hide Signatures
       Post #: 1166
RE: Redcat Racing Volcano Thread - 5/11/2008 8:38 AM
ugly duck
Last Login: 11/17/2010
Status: offline
Is it under light braking or heavy braking? Have you checked the rotor for warp? Have you checked the brake "caliper" squareness to the driveline? (If the two bolts holding the brake pads are tightened down differently so that the pads are trying to twist the rotor on the transmission output shaft, you'll get a clicking)
There are things to check out, but ultimately you've got to be the one to find it.
Sponsored by Redcat-Vancouver
Email: westcoasthobbies@shaw.ca
Hide Signatures
       Post #: 1167
RE: Redcat Racing Volcano Thread - 5/11/2008 9:01 AM
Swamp3r
Last Login: 4/30/2010
Status: offline
I`d do like numskull said. If your lacking performance maybe the throttle servo is slipping and would cause breaking problems too. You can take it out of the truck and take the top off the servo and look for stripped gears. I hope you find the problem but thats where I`d start.
OFFICIAL HIMOTO RACING SUPPORT - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
Hide Signatures
(in reply to ugly duck)
       Post #: 1168
RE: Redcat Racing Volcano Thread - 5/11/2008 10:01 AM
Greenf41
Last Login: 8/6/2008
Status: offline
Hey all found this thread about redcats, lot more posts than I thought.. wanted to post pics of my volcano and show it off, my friend and I have done two big block conversions now, and the truck works pretty well now with the metal spur gear. the next thing we need is a stronger diff, let me know if you have a way to upgrade the ring and pinion.. it pulls very nice wheelies, want to get a video up on youtube and try to get a top speed on this thing, whats the easiest way to do a top speed test? we were thinking of driving next to a real vehicle.. just seems to risky, is there a cheap radar gun?
http://www.rcuniverse.com/gallery/galleryItem.cfm?itemID=138401&dummy=7571.48080232751&opener=/community/profile.cfm%3Fsection%3Dgallery%26memid%3D415327
http://www.rcuniverse.com/gallery/galleryItem.cfm?itemID=138399&dummy=1662.2727452330825&opener=/community/profile.cfm%3Fsection%3Dgallery%26memid%3D415327
sorry if the links dont work im not familiar with the forum yet
Hide Signatures
(in reply to Swamp3r)
       Post #: 1169
RE: Redcat Racing Volcano Thread - 5/11/2008 10:14 AM
Gelo_USA
Status: offline
nahh.. problem is not with the servo.... the calipers of the brake are square..... the problem happens when I brake fully or only slightly... when I rev it.. it clicks too..
i tried running it on my hand to hear the clicks where they are comming from but it only happens under load.. when the whells are off the ground it runs smoothly
Hide Signatures
(in reply to Greenf41)
       Post #: 1170
RE: Redcat Racing Volcano Thread - 5/11/2008 10:42 AM
Swamp3r
Status: offline
I`d still check inside the servo if under load it does it it could be a stripped gear. Not under load means the servo doesn`t have to work as hard hence no clicking. I`m just trying to help you, if you have ripped the truck apart then why not go the extra step and look at the servo.
Hide Signatures
       Post #: 1171
RE: Redcat Racing Volcano Thread - 5/11/2008 5:48 PM
ugly duck
Status: offline
quote:
ORIGINAL: Greenf41
Nice truck! What transmission are you running and what is this metal spur gear you speak of?
Hide Signatures
       Post #: 1172
RE: Redcat Racing Volcano Thread - 5/11/2008 8:21 PM
Gelo_USA
Status: offline
thanks for the patience everyone...
BROKEN TOOTH on a gear inside the rear gear box... damaged the ring differential gear... so now I need a ring gear and the gear tht drives the ring gear..... can anyone ship it to me FAST??
Hide Signatures
       Post #: 1173
RE: Redcat Racing Volcano Thread - 5/11/2008 10:23 PM
Greenf41
Status: offline
Ugly duck Thanks! the tranny is a redcat 2 speed that with some tweaking we put an hpi 47 tooth savage gear on.. the plastic redcat gears would actually MELT when we would idle for a bit with the .32 so the most we ever got out of a plastic gear was 5 or 6 tanks and that was really annoying changing that gear all the time. now im on my third ring and pinion.. So welcome to the club Gelo lol..
anyway, as far as the metal gear goes.. I dont know how well it would work with a small block, since the redcat 2 speed wouldnt work on the volcano.. it had no power. I think 47 tooth is the 2nd gear, but with 3 horsepower it still has plenty of torque. to keep the small block and have a better tranny I dont know how to help... 47 tooth is just about the bigest one I can fit on my truck so unless you add more power I dont know how to get away from that gear reduction.
Hide Signatures
       Post #: 1174
RE: Redcat Racing Volcano Thread - 5/11/2008 10:30 PM
Boxhead from MN
Status: offline
Gelo USA,
Got your PM. Sent you one.
Hide Signatures
       Post #: 1175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
