RE: Redcat Racing Volcano Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Volcano Thread
Page: <<   < prev  56 57 [58] 59 60 61 62 63 64 65   next >   >>
Login
RE: Redcat Racing Volcano Thread - 1/11/2009 4:38 AM
perhamrocks
Score: 100
Last Login: 2/9/2011
Status: offline
as i said in the other thread its gonna give you more speed and less low end
edit: i advise getting direct drive with 13 tooth clutchbell
Hide Signatures
(in reply to DMCB)
       Post #: 1426
RE: Redcat Racing Volcano Thread - 1/11/2009 4:56 AM
ferlopez2k6
Score: 100
Last Login: 2/23/2009
Status: offline
My steering on my volcano is not working.
Hide Signatures
(in reply to DMCB)
       Post #: 1427
RE: Redcat Racing Volcano Thread - 1/11/2009 5:03 AM
perhamrocks
Score: 100
Status: offline
tighten down your servo saver
Hide Signatures
(in reply to ferlopez2k6)
       Post #: 1428
RE: Redcat Racing Volcano Thread - 1/11/2009 6:08 AM
ferlopez2k6
Score: 100
Status: offline
All try that but it sounds like the servo dosent have much power.
Hide Signatures
(in reply to perhamrocks)
       Post #: 1429
RE: Redcat Racing Volcano Thread - 1/12/2009 12:18 AM
DMCB
Score: 100
Last Login: 3/21/2011
Status: offline
How can I add reverse to my volcano sv?
Hide Signatures
       Post #: 1430
RE: Redcat Racing Volcano Thread - 1/12/2009 12:22 AM
Indarican
Score: 100
Last Login: 3/29/2011
Status: offline
From what I have learned it really depends on how you are using it. Racing or bashing? My VX.18 gets my truck to 34mph with minor upgrades.(Thats what Officer Dave clocked it at) Its got like 20 gears in the tranny. I have the single speed tranny to put in it, Im waiting to break the one in it now. Im also pretty sure it comes down to gearing too.
Hide Signatures
(in reply to DMCB)
       Post #: 1431
RE: Redcat Racing Volcano Thread - 1/12/2009 2:29 AM
perhamrocks
Score: 100
Status: offline
quote:
ORIGINAL: DMCB
you don't want to , and i don't know if there is a transmission with reverse that will fit into the volcano without mods.
Reverse is pretty much just an extra hassle to worry about, and when would you actually REALLY need it
Hide Signatures
(in reply to DMCB)
       Post #: 1432
RE: Redcat Racing Volcano Thread - 1/13/2009 6:06 AM
oldblackie
Score: 100
Last Login: 11/6/2009
Status: offline
I got a Volcano for Christmas last year and the thing ran great for four months until my wife drove it and broke the pull start off of it. So I just got me one of the electric starter kits for it and put it all together but now the motor will not start. Any suggestions would help.
Hide Signatures
       Post #: 1433
RE: Redcat Racing Volcano Thread - 1/13/2009 3:55 PM
perhamrocks
Score: 100
Status: offline
did you put after run oil in it before you stored it away, and was all the gas drained out?
Hide Signatures
(in reply to oldblackie)
       Post #: 1434
RE: Redcat Racing Volcano Thread - 1/13/2009 9:21 PM
oldblackie
Score: 100
Status: offline
Yes I used after run oil and did drain the fuel. I was wondering if old fuel would cause this?
Hide Signatures
       Post #: 1435
RE: Redcat Racing Volcano Thread - 1/13/2009 9:34 PM
perhamrocks
Score: 100
Status: offline
that could be it too, but did you check your glow plug to make sure that was working sufficiently?
it might also be that you didn't get the electric start together correctly?
< Message edited by perhamrocks -- 1/13/2009 9:35 PM >
Hide Signatures
       Post #: 1436
RE: Redcat Racing Volcano Thread - 1/14/2009 3:56 AM
Jason535
Score: 100
Last Login: 11/12/2010
Status: offline
what tires and wheels will fit my volcano. is there any aluminun rims or any durable rims and tire sets out there.
Hide Signatures
(in reply to AllAboutFunHobbies)
       Post #: 1437
RE: Redcat Racing Volcano Thread - 1/14/2009 5:01 AM
pushdownandturn
Score: 100
Last Login: 9/21/2009
Status: offline
quote:
ORIGINAL: Jason535
Howdy, the volcano used a 12mm hex hub so any wheel that uses a 12mm hex are good... I personally like the pro-line agitator (rear) wheels. I have them mounted on my volcano with masher 2000 tires and it rocks... and no rubbing... I wouldn't go bigger than a 5 and a 1/2 inch tall wheel unless you get wheel extensions also... Good luck - you can find the agitator rear rims fairly cheap on ebay and you can use any 2.2 type tire with them.
Franko
Hide Signatures
(in reply to Jason535)
       Post #: 1438
RE: Redcat Racing Volcano Thread - 1/14/2009 5:19 AM
Jason535
Score: 100
Status: offline
thank for the info. do they make aluminum rims or durable rims for these.
Hide Signatures
(in reply to pushdownandturn)
       Post #: 1439
RE: Redcat Racing Volcano Thread - 1/14/2009 7:11 AM
pushdownandturn
Score: 100
Status: offline
quote:
ORIGINAL: Jason535
No problem. The pro-line rims are plenty tough, and they made the agitator rim 40% more durable a while back. You CAN get aluminum rims but they cost an arm and a leg... the cheapest place I have found for any type of wheels or tires is ebay, do a 'title and description search' for 12mm wheels in the RC section. Or you can bite the bullet and get 12mm to 14mm wheel extension/adapters and mount 14mm wheels. You still can't run huge tires though, unless you do like me and put in a two speed tranny matched with an HPI 13 / 18 tooth STEEL clutch bell. If you really want a nice Volcano, get some T-MAXX shocks while you're at it (not the XXL or extra longs). They are just a little longer than stock Volcano shocks but fit nicely.
Hide Signatures
       Post #: 1440
RE: Redcat Racing Volcano Thread - 1/14/2009 8:24 AM
Jason535
Score: 100
Status: offline
what tires and rims will work for my volcano s30 the center of my stock ones spun out. im looking for an aggressive mud stle tire and durable rims.
Hide Signatures
(in reply to ehroof)
       Post #: 1441
RE: Redcat Racing Volcano Thread - 1/14/2009 7:41 PM
rclynx
Score: 100
Last Login: 7/25/2011
Status: offline
MASHER's
_____________________________
Custom Cars bring out the stars / Home of the RCLYNX, RC IMPROVEMENT, MOD, SALES & SERVICE Dealer;XTM, CEN, HPI & much more
Hide Signatures
       Post #: 1442
RE: Redcat Racing Volcano Thread - 1/25/2009 8:04 AM
slowell
Score: 100
Last Login: 1/31/2009
Status: offline
i hate to but in but does anyone know who makes a dual exgaust for the volcano they look so nice and i bet they sound nice too thanxs for any help
Hide Signatures
(in reply to rclynx)
       Post #: 1443
RE: Redcat Racing Volcano Thread - 1/25/2009 8:37 PM
rclynx
Score: 100
Status: offline
Tsais is the only after market dual exhaust that I know of but there is no dual exhaust for the small block engines good luck and Happy RC'en
Hide Signatures
(in reply to slowell)
       Post #: 1444
RE: Redcat Racing Volcano Thread - 2/13/2009 6:36 PM
lor35228
Score: 100
Last Login: 3/23/2010
Status: offline
I just got my Red Cat Volcano EPX Pro Brushless RTR on Feb 11th 2009 and it was working fine during that day. After about 20mins of in house run time (I was just testing and driving the truck slow in the house trying to get use to it) the truck started to act up by not responding to the transmitter as good, kept shaking and bouncing back and forth repeatedly fast like a car with a dying engine. I thought it was just the battery so I decided to fully charge and battery and call it a night. The next day, I power on both device (transmitter and truck seem to power up normally like yesterday) and now the truck will not respond to the transmitter at all anymore. I press and twist all buttons on transmitter already and still nothing. Only had the truck for 3 days now and only had the chance to drive it outside for 1 min because it was very cold and about 20mins inside the house on the first day. Please help. Thanks!
Truck specs: Brushless motor with Brushless ESC
Battery: 6cell 7.2v 2000mah
Charger: dynamite vision peak 2
Hide Signatures
       Post #: 1445
RE: Redcat Racing Volcano Thread - 2/14/2009 3:28 AM
joeyhatch11
Score: 109
Last Login: 5/16/2013
Status: offline
Someone in another thread was having the same problem. But he was using bigger batteries. His problem was the connectors. There was too much resistance. He threw some Dean connectors on there and the problem went away. I dont see how a 2000mah battery can give you a problem like this, but then again, I've read a lot of bad things about these brushless systems. Also hear that the stock radios themselves arent that great. I didnt take any chances with my Nitro so I ordered new servos and an extra Futaba FM receiver. Could be your crystals, make sure they arent loose. And look into some new connectors asap. You want Deans......
Hide Signatures
(in reply to lor35228)
       Post #: 1446
RE: Redcat Racing Volcano Thread - 2/26/2009 6:13 AM
big hec
Score: 100
Last Login: 4/3/2011
Status: offline
hay guys i just got a volcano sv s30 and i want to upgrade it to a 2.4 ghz but i want to know if i have to upgrade the servo too can anybody tell me thanks i'am new to the nitro seen
Hide Signatures
       Post #: 1447
RE: Redcat Racing Volcano Thread - 2/26/2009 12:54 PM
rclynx
Score: 100
Status: offline
You don't need to upgrade the servos but it would be as good an idea as the 2.4 ghz radio to do so
Hide Signatures
(in reply to big hec)
       Post #: 1448
RE: Redcat Racing Volcano Thread - 2/26/2009 2:37 PM
joeyhatch11
Score: 109
Status: offline
Most 2.4ghz system will come with servos anyway. So throw them in and keep the stocks for backup.
Hide Signatures
       Post #: 1449
RE: Redcat Racing Volcano Thread - 2/28/2009 5:32 AM
dlbremer
Score: 100
Last Login: 3/3/2009
Status: offline
please help!!!!!!!!!!!!!!!!!!!!!!
i just installed a ele.starter on my volcano sv truck, why do i still have to use my glow plug starter when starting my car?
thanks
Hide Signatures
(in reply to Chubbysdad)
       Post #: 1450
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.750RCU1
