RE: Redcat Racing Volcano Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Volcano Thread
Page: <<   < prev  57 58 [59] 60 61 62 63 64 65 66   next >   >>
Login
RE: Redcat Racing Volcano Thread - 2/28/2009 2:13 PM
joeyhatch11
Score: 109
Last Login: 5/16/2013
Status: offline
something has to light the glow plug, to spark the fuel and make it fire. Is this electric start like the TRaxxas electric start? If so then there should be a wire that plugs into the glow plug.
Hide Signatures
(in reply to dlbremer)
       Post #: 1451
RE: Redcat Racing Volcano Thread - 3/2/2009 12:10 AM
richardtf
Score: 100
Last Login: 9/23/2012
Status: offline
hi to all,just want to ask question,its about my volcano sv truck,the question is theres fluid coming out of the exhaust,its like a combination of oil and fuel,even though i stop using it still dripping...i dont know if thats normal
Hide Signatures
(in reply to Chubbysdad)
       Post #: 1452
RE: Redcat Racing Volcano Thread - 3/2/2009 12:36 AM
joeyhatch11
Score: 109
Status: offline
When you run too rich you'll get a build up in the exhaust. So even when your done running it'll tend to drip out. Mine usto do that. Then I leaned it out a bit. No biggie though. Just makes for a bigger mess later.
Hide Signatures
(in reply to richardtf)
       Post #: 1453
RE: Redcat Racing Volcano Thread - 3/2/2009 6:38 AM
richardtf
Score: 100
Status: offline
thank you joeyhatch11,is there a dealer of redcat in plano texas? i just found out that you can't buy redcat parts in local hobby shop
Hide Signatures
(in reply to joeyhatch11)
       Post #: 1454
RE: Redcat Racing Volcano Thread - 3/3/2009 3:25 AM
chevyderek72
Score: 100
Last Login: 11/8/2010
Status: offline
I know there is a dealer from the forums in texas, cant remember who though.
_____________________________
Redcat Racing - Dunerunner, Hurricane XP, Aftershock 8e, Volcano, Volcano epx, Vortex epx, Tremor 18e pro
Its me ti**ta
Hide Signatures
       Post #: 1455
RE: Redcat Racing Volcano Thread - 3/4/2009 6:41 AM
richardtf
Score: 100
Status: offline
help pls. :-) i want to upgrade my volcano sv rims...want brand are compatible with volcano sv...
thanks...
Hide Signatures
(in reply to chevyderek72)
       Post #: 1456
RE: Redcat Racing Volcano Thread - 3/4/2009 7:12 AM
chevyderek72
Score: 100
Status: offline
If i were you i woudl go to your local hobby shop and test fit them and see if they got some you like. if not tower hobbies has a lot of rims. You need some that have a 12mm hex. most should fit, but some may rub, so i would cruise around tower and then post the links to the ones you want to make sure they will fit. And what size were you lookin for? Cause stock they come with 2.8 inch rims and tires. It give a more low profile tire. But i like the 2.2 rims because you get more tire, and it looks more scale.
First pic is of my 2.2 rims and tires.
Second pics is comparing the stock volcano tires to my new ones. They are a little smaller in diameter. But something like the mashers, would be about the same size i think, and those are sick. I wanted those so bad, but ended up gettin these real cheap and i like em. But the mashers would have a big tire. like a real truck would, they look pretty sick.
Its me ti**ta
Hide Signatures
       Post #: 1457
RE: Redcat Racing Volcano Thread - 3/4/2009 10:51 PM
madmarty
Score: 100
Last Login: 1/19/2012
Status: offline
check this guy out. http://allaboutfunhobbies.com. I believe he is in texas, very good guy to deal with
Hide Signatures
       Post #: 1458
RE: Redcat Racing Volcano Thread - 3/5/2009 8:14 PM
richardtf
Score: 100
Status: offline
Thanks...madmarty..tihstae :-)
Hide Signatures
(in reply to madmarty)
       Post #: 1459
RE: Redcat Racing Volcano Thread - 3/5/2009 8:18 PM
richardtf
Score: 100
Status: offline
guys.... i want to upgarde my volcano sv exhaust pipe....somebody told hpi rpm pipe & Hpi header would do.. want kind of hpi model would fit...?
Hide Signatures
       Post #: 1460
RE: Redcat Racing Volcano Thread - 3/5/2009 8:20 PM
numskull223
Score: 100
Last Login: 3/16/2009
Status: offline
I put the wheels off of a Jato on mine. looks real good
Hide Signatures
       Post #: 1461
RE: Redcat Racing Volcano Thread - 3/5/2009 8:59 PM
perhamrocks
Score: 100
Last Login: 2/9/2011
Status: offline
quote:
ORIGINAL: richardtf
get the high flow header from redcat, and an exaust coupler, any 1/10 pipe will work on it.
edit: i have a team associated torque pipe, and i like it alot
< Message edited by perhamrocks -- 3/5/2009 9:00 PM >
Hide Signatures
       Post #: 1462
RE: Redcat Racing Volcano Thread - 3/8/2009 6:05 AM
richardtf
Score: 100
Status: offline
thanks..:-)
Hide Signatures
(in reply to perhamrocks)
       Post #: 1463
RE: Redcat Racing Volcano Thread - 3/8/2009 6:06 AM
richardtf
Score: 100
Status: offline
what brand will fit with volcano sv. i am replacing the body..
thanks...
Hide Signatures
       Post #: 1464
RE: Redcat Racing Volcano Thread - 3/9/2009 6:08 PM
curbsak
Score: 100
Last Login: 9/13/2011
Status: offline
does anyone have any directions to replace the rear hub carriers for a redcat volcano stx. i an new at this. thanks
Hide Signatures
(in reply to AllAboutFunHobbies)
       Post #: 1465
RE: Redcat Racing Volcano Thread - 3/24/2009 7:27 AM
richardtf
Score: 100
Status: offline
I have a problem with my volcano sv, it cant seem to stay in idle,it has a 1mm opening in the carb i recently replace the carburetor i thought it was the problem,everytime i start the truck i have to adjust the throttle trim to high so that the truck would start...pls help i am getting frustrated with volcano sv :-)
Hide Signatures
(in reply to curbsak)
       Post #: 1466
RE: Redcat Racing Volcano Thread - 3/24/2009 8:07 AM
firebird78
Score: 105
Last Login: 12/8/2011
Status: offline
your problem is prolly with your lsn (low speed needle)...sounds rich to me...by opening your trim you are letting more air into the carb which in turn leans it out....of course this also depends on if you have your hsn (high speed needle) set correctly...I would make sure your high speed needle is at approx. 2 1/2 turn from all in....when tuning u need to set your hsn needle first...then u can work on the low...but u need to have it relatively close on both to get it to run then stay running...
if you put your hsn at 2 1/2 turns and your lsn flush with the collar with 1mm gap looking into the carb it should stay running long enuff to tune...if you look up in the sticky part of redcat suppport forum you will see a how to thread...in that thread is a video to help you better understand the carb and guides you to tune your engine....the settings I gave you are general settings that should get you started to be able to tune
keep the shiney side up, the hammer down and the marshalls bored.....himoto rxb-1...himotoracingusa
Hide Signatures
       Post #: 1467
RE: Redcat Racing Volcano Thread - 3/26/2009 3:03 AM
richardtf
Score: 100
Status: offline
got it firebird!! my truck is running now!! whats the best upgrade to increase speed/power of volcano sv? :-) thanks
Hide Signatures
(in reply to firebird78)
       Post #: 1468
RE: Redcat Racing Volcano Thread - 3/26/2009 6:55 AM
chevyderek72
Score: 100
Status: offline
A new motor would be the best, but a pipe and header always help tons.
Its me ti**ta
Hide Signatures
       Post #: 1469
RE: Redcat Racing Volcano Thread - 3/26/2009 9:31 PM
richardtf
Score: 100
Status: offline
what motor would fit? :-)
Hide Signatures
       Post #: 1470
RE: Redcat Racing Volcano Thread - 3/27/2009 2:05 AM
chevyderek72
Score: 100
Status: offline
The sh 18 is a great upgrade, and you can get it half off through the redcat engine replacement program. and the os is better, but its more expensive
Its me ti**ta
Hide Signatures
       Post #: 1471
RE: Redcat Racing Volcano Thread - 3/27/2009 2:33 AM
perhamrocks
Score: 100
Status: offline
i'm not sure if the engine mount holes are the same, but the new sh .21 for the landslide has a side exaust. it would probably give ur drivetrain some issues tho, and it's also a slide carb, but that's not a huge issue to overcome
< Message edited by perhamrocks -- 3/27/2009 2:34 AM >
Hide Signatures
       Post #: 1472
RE: Redcat Racing Volcano Thread - 4/4/2009 4:05 AM
wlind05
Score: 100
Last Login: 5/31/2009
Status: offline
Has anyone noticed the spur gear not being true?
Volcano Sv
Hide Signatures
       Post #: 1473
RE: Redcat Racing Volcano Thread - 4/4/2009 4:15 AM
wlind05
Score: 100
Status: offline
I Have found a solution to fix the rear diff on the volcano sv. THe solution although appearing to be obvious the results in performance are amazing. Heres what you do take out the diff and dissassemble it including the carrier, so you can get to the spider gears. Clean everything real good with brake cleaner, the reason you use brake cleaner is it removes the grease and does not leave a film. With everything in place inside the carrier fill it with 2 ton epoxy or something similar and reassemble. Once cured it will be a locked rear end. Reinstall the diff and enjoy!
Volcano Sv
Hide Signatures
(in reply to wlind05)
       Post #: 1474
RE: Redcat Racing Volcano Thread - 4/4/2009 9:35 AM
chevyderek72
Score: 100
Status: offline
Ya but then its locked, it makes the car harder to turn. You will get better traction but your handling will suffer
Its me ti**ta
Hide Signatures
       Post #: 1475
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.375RCU1
