RE: Redcat Racing Volcano Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Volcano Thread
Page: <<   < prev  45 46 47 48 [49] 50 51 52 53 54   next >   >>
Login
RE: Redcat Racing Volcano Thread - 6/1/2008 5:05:56 AM
ugly duck
Status: offline
Judging by the condition of the wristpin, it looks like you were too lean. What kind of fuel were you using?
_____________________________
Sponsored by Redcat-Vancouver
Email: westcoasthobbies@shaw.ca
(in reply to Gelo_USA)
       Post #: 1201
RE: Redcat Racing Volcano Thread - 6/1/2008 5:54:27 AM
Redharris
Status: online
yep.....
My Money is on "too Lean".
Also.....maybe the flywheel nut came loose and the crank was able to move with More play than it normally has.....
Did you bugger up the Spur gear? That would be sign of a wandering crank....
OFFICIAL HIMOTO RACING SUPPORT - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
(in reply to ugly duck)
       Post #: 1202
RE: Redcat Racing Volcano Thread - 6/1/2008 8:27:07 AM
Swamp3r
Status: online
quote:
ORIGINAL: jellypotato
Now I'm craving a mc chicken and fries, you could have used a different napkin in the pic lol. From what I've read the engine replacement isn't a big deal to put up with. I'd use the replacement program and get a new engine, also were you setting your engine to bdc and using after run oil. It's just a thought, but using the wrong glow plug could of caused it for sure if it was too long into the cylinder. I don't know the plugs that your using so I don't know if the depth is different. I hope you don't give up on the truck man they are good rc's.
(in reply to jellypotato)
       Post #: 1203
RE: Redcat Racing Volcano Thread - 6/1/2008 8:49:35 AM
jellypotato
Status: offline
wrong glow plug ???? Even if it's the wrong glow plug, it wont cause the crank to break like that... and I know I'm not running it too lean. I read in some japanese manual for the os glow plug and says that no.3 is for fuel less than 20% and used on airplane engines or .12 car engines... and no.8 is for .18 engine using 20% fuel... So leaning out the engine and wrong glow plug rules out.... My guess is the quality of the material... anyone with me ???
(in reply to Swamp3r)
       Post #: 1204
RE: Redcat Racing Volcano Thread - 6/1/2008 8:51:07 AM
jellypotato
Status: offline
nah..... when I checked the engine, none of the parts or screws were loose.... and the fly wheel were just like brand new
(in reply to Redharris)
       Post #: 1205
RE: Redcat Racing Volcano Thread - 6/1/2008 9:04:02 AM
Swamp3r
Status: online
I doubt the quality of the material I have 3 redcats all sh engines and I have bought 4 gallons of fuel in the past 2 months I still have 3/4 of a gallon but all 3 of my trucks run awesome. So you know I've ran the hell out of these trucks it isn't a quality problem so you can rule that out.
       Post #: 1206
RE: Redcat Racing Volcano Thread - 6/1/2008 9:05:05 AM
Swamp3r
Status: online
can you show me a pic of the top of the piston?
       Post #: 1207
RE: Redcat Racing Volcano Thread - 6/1/2008 11:42:25 AM
Chubbysdad
Status: offline
Just a guess, but to me you might have put it on the bump box wrong. The one way might have caught(only supposed to catch in one direction). You can put a car on bump box wrong.
Cen truggy, Bigfoot 1/5th, Cen buggy, Mg16
       Post #: 1208
RE: Redcat Racing Volcano Thread - 6/1/2008 10:32:46 PM
Gelo_USA
Status: offline
I ran my truck today... but it keeps dying when I release throtle after a few minutes of running... the idle is set right...the motor is not overheating I tried putting some water drops on the head and it takes some secs before it dessapears... it doesnt even sizzles.... and the throthle servo is adjusted....
when it dies like tht its kind of hard to make it come back.....I have no idea what it might be.... I m running a little on the richer side... affraid to damage the engine....
also the clutch bell is starting to get like brownish golden.. like when u heat metal... but I think thts normal right?? I ve seen lots of pics with the clutch bell like tht....
I m buying anyways... a full clutch assembly with clutch bell and bearings jst to keep it as a spare....
(in reply to Chubbysdad)
       Post #: 1209
RE: Redcat Racing Volcano Thread - 6/2/2008 12:25:44 AM
racemaxx24
Status: offline
Lean her out. That will help alot. The clutch bell will turn brown a bit but not much
Life is a pain. Don''''''''''''''''t make it worse by trying to beat my Revo in a drag race...
       Post #: 1210
RE: Redcat Racing Volcano Thread - 6/2/2008 3:49:11 AM
luxuryblue883
Status: offline
Just got my first Nitro a Volcano SV. After the 3rd tank of fuel I have no brakes and only the front wheels drive. I am assuming I need to pull the rear differential out and replace gears. Little dissapointed that I have to start replacing things already. Or could it be something simple?
Thanks. DId some searches but not always sure what people are talking about.
(in reply to racemaxx24)
       Post #: 1211
RE: Redcat Racing Volcano Thread - 6/2/2008 4:18:26 AM
Redharris
Status: online
No rear Drive?
Check the Rear Drive Cup on the Transmission. It is Notorious for comming loose.
In Fact, (with a new Vehicle) Check ALL of your screws and fasteners for Tightness and LocTite any screws that attach to Metal.
Click to see fullsize image.
Click for fullsize
(in reply to luxuryblue883)
       Post #: 1212
RE: Redcat Racing Volcano Thread - 6/2/2008 1:17:47 PM
luxuryblue883
Status: offline
No rear Drive?
[/quote]
Thanks, Will check it tonight and see what happens.
       Post #: 1213
RE: Redcat Racing Volcano Thread - 6/2/2008 2:20:57 PM
ugly duck
Status: offline
Make sure you get the grub screw properly lined up with the flat on the transmission shaft when you tighten it, otherwise you'll lose rear drive again in about 1.5 seconds. And use Loctite - people say blue, I'm gonna say red on this part. In order to release red loctite you need some heat, but you shouldn't need to release it any time soon.
(in reply to luxur
