RE: Redcat Racing Tornado Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  137 138 139 140 141 142 [143] 144 145 146   next >   >>
Login
RE: Redcat Racing Tornado Thread - 3/23/2011 1:52 PM
eggonboost04
Score: 100
Last Login: 4/6/2011
Status: offline
thanks
Hide Signatures
(in reply to neyou86)
       Post #: 3551
RE: Redcat Racing Tornado Thread - 4/8/2011 11:51 PM
sassy123
Score: 100
Last Login: 2/12/2012
Status: offline
yes i have a red cat tornado and when i throtle it it move about like 1 mph and slower some times it dosnt move i need help and ive already replace the transmission
Hide Signatures
(in reply to Chubbysdad)
       Post #: 3552
RE: Redcat Racing Tornado Thread - 4/9/2011 6:20 AM
neyou86
Score: 105
Last Login: 1/4/2012
Status: offline
does your engine rev up?
Hide Signatures
(in reply to sassy123)
       Post #: 3553
RE: Redcat Racing Tornado Thread - 4/18/2011 8:02 PM
sassy123
Score: 100
Status: offline
pok yes it did but ive got tht fixed now i have one more problem wen i first start the car it move but only like 15 mph then if i stop it just shuts off and also wen i start bak up it only goes like 2 mph and its full throtle and i no its not the trans cuz its been replaced im thinking it the clutch or sum any thaughts
Hide Signatures
       Post #: 3554
RE: Redcat Racing Tornado Thread - 4/18/2011 8:04 PM
sassy123
Score: 100
Status: offline
somone help pleas
Hide Signatures
       Post #: 3555
RE: Redcat Racing Tornado Thread - 4/19/2011 1:25 AM
neyou86
Score: 105
Status: offline
sounds like its your idle and throttle linkage... if your motor isnt reving up good that is you problem then when u let off it kills cuz your idle is set to low... when u first start it does it idle? what are ur needle settings on your carb? the highspeed should be 2.5 and low speed flush with the collar. set the idle up until it idles stable. make sure you have good gear mesh. check the conditon of your gears too. if that doesnt help anything make sure all of the dogbones are in place and if everything looks good and the throttle servo functions properly take out the motor and take off the clutch. look to see if the shoes are oval shape or circular and make sure the spring is in tact. let me know how things turn out
Hide Signatures
       Post #: 3556
RE: Redcat Racing Tornado Thread - 4/26/2011 4:58 AM
wilfong45
Score: 100
Last Login: 4/26/2011
Status: offline
i have the tornado s30. got it used. im new to the whole rc thing. where the rear dog bone looking shaft goes into the rear end, keeps coming loose off the rear end. ill be driving once i hit a bump the thing will come undone from the rear end. Im not sure what to do. there is a set screw on it and i tightened it down all the way but it still comes loose, anyone have an idea what i need?
Hide Signatures
       Post #: 3557
RE: Redcat Racing Tornado Thread - 4/26/2011 11:13 PM
neyou86
Score: 105
Status: offline
take little orings and put on the inside of the cup or tiny piece of fuel line make sure to do it to both. that way the rubber oring holds the shaft away from the cup and more securely. if you have more questions let me know
Hide Signatures
(in reply to wilfong45)
       Post #: 3558
RE: Redcat Racing Tornado Thread - 5/4/2011 6:33 AM
05tegtyper
Score: 100
Last Login: 5/19/2011
Status: offline
will i be able to replace my tornado s30 servo's, controller setup with this??? please help. servo blew first day of break in. not even after  the 3rd tank..  http://cgi.ebay.com/NEW-Futaba-2PH-2-Channel-AM-2-S3003-Servos-70-FUTJ14-/390305362369?pt=Radio_Control_Parts_Accessories&hash=item5ae00331c1#ht_960wt_911
Hide Signatures
       Post #: 3559
RE: Redcat Racing Tornado Thread - 5/4/2011 12:59 PM
neyou86
Score: 105
Status: offline
yes that should work aslong as you only have 2 servos on your car
Hide Signatures
(in reply to 05tegtyper)
       Post #: 3560
RE: Redcat Racing Tornado Thread - 5/13/2011 7:16 PM
subcaptian
Score: 100
Last Login: 2/17/2013
Status: offline
Hey guys, a while back I purchased an exceed rc Sunfire and the motor burnt out within a month. It has sat around ever since. Recently I've found out that it is actually a tornado and have thought about racing it. I want to get two sets of tires, Proline Calibers and JConcepts Goosebumps, Calibers for dry and Goosebumps for wet. The problem is that I don't know what wheels will work. Anyone have some suggestions on wheels?
Hide Signatures
(in reply to frekbynature2002)
       Post #: 3561
RE: Redcat Racing Tornado Thread - 5/16/2011 6:23 PM
subcaptian
Score: 100
Status: offline
Anyone?
Hide Signatures
(in reply to subcaptian)
       Post #: 3562
RE: Redcat Racing Tornado Thread - 5/16/2011 10:02 PM
rccrazer
Score: 100
Last Login: 5/16/2013
Status: offline
nitro rustler wheels seem to work well as do the hpi 2.2 dish with a 12mm hex
Hide Signatures
       Post #: 3563
RE: Redcat Racing Tornado Thread - 5/17/2011 3:52 AM
neyou86
Score: 105
Status: offline
any wheel will work with a little modification and different size hex... i would switch to its either 17 or 18mm hexes with buggy wheels then buy some sets of tires to test out.
Hide Signatures
(in reply to rccrazer)
       Post #: 3564
RE: Redcat Racing Tornado Thread - 5/18/2011 9:10 PM
subcaptian
Score: 100
Status: offline
So, how would I go about converting the hex? Do the 17mms just drop on?
Hide Signatures
       Post #: 3565
RE: Redcat Racing Tornado Thread - 5/19/2011 1:21 AM
neyou86
Score: 105
Status: offline
just buy the size you want and they should snap on like the old ones or cover the old hex or you might have to screw them on. i believe redcat has a kit if you need. dont quote me on this though. i do know it is possible.
Hide Signatures
       Post #: 3566
RE: Redcat Racing Tornado Thread - 5/20/2011 4:34 PM
subcaptian
Score: 100
Status: offline
OK. Also, I've heard that they aren't very durable for jumping. Any comments on this?
Hide Signatures
       Post #: 3567
RE: Redcat Racing Tornado Thread - 5/20/2011 10:08 PM
neyou86
Score: 105
Status: offline
only thing ive ever had trouble with on mine was the dogbones falling out when jumping. the other problems were just worn out. i fixed my problem with orings which i stated before... also the wing mount sometimes breaks if you land on it.
Hide Signatures
       Post #: 3568
RE: Redcat Racing Tornado Thread - 5/20/2011 10:23 PM
subcaptian
Score: 100
Status: offline
Well, I'm looking at CVDs along with all carbon shock towers and top plate, plus aluminum wing mounts and arms with hub carriers. Will this have much chance of breaking? Also, can I get an aluminum or carbon chassis anywhere?
Hide Signatures
       Post #: 3569
RE: Redcat Racing Tornado Thread - 5/21/2011 4:25 AM
neyou86
Score: 105
Status: offline
i bent a couple shock towers too... look into that. there is a vehicle that hpi makes that is very similar, maybe look into that for abetter chasis. mine was aluminum and was strong. im not sure about yours.
Hide Signatures
       Post #: 3570
RE: Redcat Racing Tornado Thread - 6/12/2011 10:24 PM
mjj002
Score: 100
Last Login: 5/22/2012
Status: offline
 my 47 tooth in my trany keeps having its teeth worn away by the metal gear super fast is this normal. i also checked my gear mesh setting and it is the best i can do. is their a metal gear i could buy.
Hide Signatures
(in reply to ehroof)
       Post #: 3571
RE: Redcat Racing Tornado Thread - 6/13/2011 12:38 AM
neyou86
Score: 105
Status: offline
dont put a metal spur gear in... it will just transfer the stress to more expensive parts.. maybe your clutch bell is warped.. is the 47 tooth the big gear or the smaller of the two? i cant remember. it could be the area you run too. sand and little rocks are hard on spur gears. there is many things that can cause a spur gear to wear out, rocks, sand, bad gear mesh, warped gear, misalinged trannsmission or motor, or just alot of stress on it, like too much power or a really bad drag when turning the wheels.
Hide Signatures
(in reply to mjj002)
       Post #: 3572
RE: Redcat Racing Tornado Thread - 9/16/2011 1:14 AM
-Mystic-
Score: 100
Last Login: 5/2/2012
Status: offline
So from what I have read, the Tornado S30 is a descent starter car? I am very BEW to Nitro... infact, I ordered my first car 2 days ago... and it is the Tornado S30.... price was a big factor in my choosing it.... I figured, Since I have't been in to RC in about 20 years and NEVER had anything to do with gas much less nitro... better to spend less to figure out if I like it or not.... but seems most of what I read is that it isnt a bad little starter vehicle.... any advice on what spare parts I should get ahold of to keep on hand asside from dog bones spurr gears?
_____________________________
Redcat Racing Tornado s30 -
-Mystic-
Hide Signatures
       Post #: 3573
RE: Redcat Racing Tornado Thread - 9/16/2011 1:36 AM
jeffie8696
Score: 120
Last Login: 5/25/2013
Status: offline
Front lower A Arms, glow plugs, Patience. It is a good starter vehicle and should teach you a lot about glow  without breaking the bank.
If you keep after the maintenance you should have little trouble but it certainly is a learning curve.
Dont run it lean, use fuel with enough oil (I prefer 20%) .
Adjust the ball joints often, they loosen and the driveshafts fall out.
Tighten the nuts and bolts but not the one on top the servo saver cause it will bind.
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
(in reply to -Mystic-)
       Post #: 3574
RE: Redcat Racing Tornado Thread - 9/16/2011 2:10 AM
-Mystic-
Score: 100
Status: offline
Thanks alot jeffie... I appreciate the opinion... My car should be here hopefully by wednesday... then I can start on the engine break in..... On  you tube... Ali Shamnonm supposed to be an expert on redcat, said he recommends running 30% ... They sell that at my local hobby shop, do you think that would be ok or would 20% or so be better?
-Mystic-
Hide Signatures
(in reply to jeffie8696)
       Post #: 3575
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.563RCU1
