RE: Redcat Racing Tornado Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Redcat Racing Tornado Thread
Page: <<   < prev  137 138 139 140 141 142 143 [144] 145 146   next >   >>
Login
RE: Redcat Racing Tornado Thread - 9/16/2011 2:27 AM
jeffie8696
Score: 120
Last Login: 5/15/2013
Status: offline
Ali and I have differences of opinion sometimes, nice guy but I have my own way of looking at things.
I use only SIG 15% nitro 20% oil. It is 50/50 castor to synthethetic and I feel it works great at keeping my engine right.
You may consider heating up the clinder of your engine with a hair dryer before you start it the first time.
_____________________________
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
(in reply to -Mystic-)
       Post #: 3576
RE: Redcat Racing Tornado Thread - 9/16/2011 3:20 AM
-Mystic-
Score: 100
Last Login: 5/2/2012
Status: offline
Thanks again for the advice... I appreciate all I the advice I can get.... what is the reason for heating it up first ? is that simply because of the nitro fuel ?
What type of glow plug should I have on back up ? I see there are cold medium and hot...
Redcat Racing Tornado s30 -
-Mystic-
Hide Signatures
(in reply to jeffie8696)
       Post #: 3577
RE: Redcat Racing Tornado Thread - 9/16/2011 4:09 AM
jeffie8696
Score: 120
Status: offline
Modern ABC/ABN/ACC engines are bored at a taper in order to maintain the compression when warm. That is why their pistons "pinch" at the top . Preheating helps keep it from causing damage to a really new engine, it goes away slightly when it is broke in.
I use Merlin plugs, I use the 2006 in just about everything.
Hide Signatures
       Post #: 3578
RE: Redcat Racing Tornado Thread - 9/16/2011 5:02 AM
-Mystic-
Score: 100
Status: offline
Once again... Thank You Jeffie ... appreciate your expertise
-Mystic-
Hide Signatures
       Post #: 3579
RE: Redcat Racing Tornado Thread - 9/16/2011 5:44 AM
jeffie8696
Score: 120
Status: offline
Thats why I am here. To clarify I use the Merlin 2006 in everything car related, I use 2003 , 2009, 2010 and 2002 in my planes.
Hide Signatures
       Post #: 3580
RE: Redcat Racing Tornado Thread - 9/24/2011 5:56 AM
-Mystic-
Score: 100
Status: offline
Well, got my Volcano fired up and broke in... Had my first accident.. flipped it over the neigbors self standing basketball hoop.... did a roadside repair after a phone call to redcat to figure out how to put the right front dog bone back in.... bent the shock mount back out straight and fired her back up again... drove her for another 3 tanks.... I have a question though..... with the 2 speed trans in this thing it doesn't shift until it is it is well into top speed... is it normal to have to set them from the factory ?
By the way.... This Thing is STUPID FAST !!!!! Hard for this newbie to control    But Oh SO Much FUN!!!!
-Mystic-
Hide Signatures
       Post #: 3581
RE: Redcat Racing Tornado Thread - 9/24/2011 5:43 PM
jeffie8696
Score: 120
Status: offline
The shift point is easy to adjust. Just takes a small allen wrench. http://www.youtube.com/watch?v=BE1nEsknKrA&feature=player_embedded
Hide Signatures
       Post #: 3582
RE: Redcat Racing Tornado Thread - 9/24/2011 8:54 PM
-Mystic-
Score: 100
Status: offline
Out of curiosity.... One other problem that redcat said is "normal" but I don't know.... the plastic body has meltet right at the header and started melting at the muffler... I called redcat and they said the only fix is to cut the body arround where it is burnt.... is this ACUALLY normal? or have i not set something up correctly? I had the body mounted on the lower holes in the rear... they said that is the normal spot to mount the body... Just curious.... or should I investigate a different body for my s30 ?  If i trim off all of the burnt plastic, most of the right side of the body will be missing.....
-Mystic-
Hide Signatures
       Post #: 3583
RE: Redcat Racing Tornado Thread - 9/24/2011 11:11 PM
jeffie8696
Score: 120
Status: offline
The muffler on your engine gets hot just like the exhaust on your car, motorcyle, moped , chainsaw, whatever. Running the engine as rich as you can will help but it will still get hot.
Hide Signatures
       Post #: 3584
RE: Redcat Racing Tornado Thread - 9/25/2011 3:29 AM
-Mystic-
Score: 100
Status: offline
I am going to get a new body for it, is there some way to shield it from the heat? Maybe some sort of heat shielding tape or something I can put on the body or exhaust? any thoughts or advice?
-Mystic-
Hide Signatures
       Post #: 3585
RE: Redcat Racing Tornado Thread - 9/25/2011 4:14 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
fiberglass exhaust tape, usually sold in automotive stores can help, you can put it on the body where the exhaust is.
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
       Post #: 3586
RE: Redcat Racing Tornado Thread - 9/25/2011 5:32 AM
-Mystic-
Score: 100
Status: offline
Thanks eh... and thank you again jeffie for all your advise and insight... I appreciate all the experts advise I can get
-Mystic-
Hide Signatures
(in reply to ehroof)
       Post #: 3587
RE: Redcat Racing Tornado Thread - 9/25/2011 1:22 PM
QSR1
Score: 100
Last Login: 9/29/2012
Status: offline
I want to extend the length of my reciever attenna on Volcano elec, anything more complicated than just splicing on another couple inched of wire?
Hide Signatures
       Post #: 3588
RE: Redcat Racing Tornado Thread - 9/26/2011 1:42 AM
jeffie8696
Score: 120
Status: offline
Did it break or something?
Hide Signatures
(in reply to QSR1)
       Post #: 3589
RE: Redcat Racing Tornado Thread - 9/26/2011 6:45 AM
-Mystic-
Score: 100
Status: offline
I found that 2 speed trans is infact NOT working... took it apart tonight.,... the 2 speed clutch is not engaging... I inspected the little bar that comes out to engage second gear and it was stuck... once i was able to free it up it decides to come out all the time now... I ordered a new 2 speed clutch and I will call them tomorrow to discuss warranty for it... I felt it better to just order a 5.00 part and deal with warranty replacement later on.... Also question, have you guys encountered any issues with the throttle servo making a popping noise? Mine is doing this when braking.... I beleive it to be the servo arm but just curious.... I will discuss it with them tomorrow as well..... so far the car has been fun.... and quite a learning experience so far... but I'm loving the challenge.... You guys have a good night.... I will let you know my progress
-Mystic-
Hide Signatures
       Post #: 3590
RE: Redcat Racing Tornado Thread - 9/26/2011 6:57 AM
jeffie8696
Score: 120
Status: offline
The popping noise I would suspect to be gears inside the servo skipping. The stock servos are not that great. I have replaced mine with decent quality inexpensive servos. I use Hitec HS322HD with good result.
Hide Signatures
       Post #: 3591
RE: Redcat Racing Tornado Thread - 9/26/2011 6:58 AM
-Mystic-
Score: 100
Status: offline
I will look into those... are they faster at responding than the redcat factory ones ?
-Mystic-
Hide Signatures
       Post #: 3592
RE: Redcat Racing Tornado Thread - 9/26/2011 7:09 AM
jeffie8696
Score: 120
Status: offline
I am not sure but they are just a really good quality servo at a decent price.
Hide Signatures
       Post #: 3593
RE: Redcat Racing Tornado Thread - 9/26/2011 7:11 AM
-Mystic-
Score: 100
Status: offline
are they also direct fit? or would I have to modify something?  Throttle and steering servos the same?
-Mystic-
Hide Signatures
       Post #: 3594
RE: Redcat Racing Tornado Thread - 9/27/2011 3:41 AM
-Mystic-
Score: 100
Status: offline
Does anybody know the correct order for the adjustment screw on the 2 speed clutch?  Is it Set screw then ball bearing then spring? or set screw spring then ball ?
-Mystic-
Hide Signatures
       Post #: 3595
RE: Redcat Racing Tornado Thread - 9/27/2011 7:08 AM
-Mystic-
Score: 100
Status: offline
I got it.... It is Ball Spring Set screw.... I took a spring out of an old lighter... cut to what look slike the right size... or not... we will see tomorrow if I get a chance to run it on my lunch break
-Mystic-
Hide Signatures
       Post #: 3596
RE: Redcat Racing Tornado Thread - 10/18/2011 7:50 PM
Undetermined
Score: 100
Last Login: 10/20/2011
Status: offline
It's been a while since I have messed with my Tornado. I also have a Tsunami I bought off a buddy with the same problem.
Transmissions keep stripping. Not sure why, I have been making them tight and feeding paper through to make sure it was not too tight, but I still just stripped a transmission again. Has there been any upgrades to a steel transmission? I would love to go steel single speed and let her rip.
Maybe because I was doing donuts in the grass when the transmission tore up? I wasn't going full throttle, but it shaved it.
I didn''t do it, or at least I don''t remember doing it...
Hide Signatures
       Post #: 3597
RE: Redcat Racing Tornado Thread - 10/20/2011 4:44 AM
neyou86
Score: 105
Last Login: 1/4/2012
Status: offline
debris is hard on spur gears and so is abrupt acceleration. metal gears will just transfer the stress onto something more expensive. metal spur gears are not the way to go. your clutch bell could we warped that has been known on the tornado. dont land with the throttle wide open either. there isnt a slipper clutch in the transmission so be careful for that.
Hide Signatures
(in reply to Undetermined)
       Post #: 3598
RE: Redcat Racing Tornado Thread - 10/21/2011 3:57 PM
rccrazer
Score: 100
Status: offline
that will do it, grass is really hard on trannys and engines and electronics as well, try not to do that.
Hide Signatures
       Post #: 3599
RE: Redcat Racing Tornado Thread - 10/31/2011 2:01 AM
Thebeast38
Score: 100
Last Login: 12/27/2011
Status: offline
Hey guys! I'm new to the nitro car world. My boss gave me his tornado s30 as a thank you for coming into work on a Sunday. He gave me a bunch of extra parts and goodies.  So after running it a few times, my first question is...does my car have reverse? My radio has settings for it, but I have no clue on how to adjust the settings to make it reverse. I'm assuming it has the original servo, so I'm not sure if the servo has reverse? Any help/ suggestions would be great. Thanks guys
Hide Signatures
(in reply to rccrazer)
       Post #: 3600
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.891RCU1
